Analyze Thermistor?
@fcwilt what printer is it?
@Veti said in Analyze Thermistor?:
@fcwilt said in Analyze Thermistor?:
When confronted with a machine with existing thermistors without specifications
my first place to go is look at the marlin config if it exists.
That is a good idea - it did come with a SD card that might have that information.
@fcwilt Looks like github repo is here, this is the best line I could find quickly: https://github.com/my3dltd/F1-B-V2-NANO/blob/31874e09f71b465f56eeb7b6ba4938376e794848/robin_nano35_cfg.txt#L168
that does make sense. its an ultimaker 2 clone.
ultimaker 2 uses thermocouples. so this clone does too. -
Thanks for the help.
I will investigate these resources later today.
@fcwilt for a quick & dirty check, you could always stick the bed in your oven, set the temperature to ~80deg and leave the wires dangling out the door. Even better if you have a reliable thermistor/thermocouple setup to put in to get an accurate reading of how hot the oven is. Repeat for a few temps and see how different the generated parameters are?
ultimaker 2 uses thermocouples. so this clone does too.Well I treated them as thermistors in RRF3 and they seem to work.
At least I was able to complete M303 but I used the B value from a thermistor I knew which is not likely to be correct.
@engikeneer said in Analyze Thermistor?:
I do have an good meter for measuring temps.
Is the text config file a new thing in Marlin? It still only seems to set the hot end temp sensor, but it is Thermistor #1, so you should be able to look that up in Marlin. Really they should be posting their full Marlin source, where I guess the bed sensor is hard coded.
@droftarts said in Analyze Thermistor?:
I will see what I can find but the web sites are sometimes a bit confusing.
@fcwilt can you use the Robin Nano electronics with the STM32 port of RRF? I don’t see it in @gloomyandy ’s wiki. https://teamgloomy.github.io/getting_started.html
Looks like the Robin Nano uses STM32F103VET6, so I guess not.
Robin Nano
Short answer is no, not supported.
Longer answer is that there are different versions 1.x/2.x uses the STM32F1 mcu which we don't support. 3.x has an STM32F4 which we do support. However it uses a different SPI unit for SD card access to all of the other currently supported boards (plus a bunch of other differences). Given that we normally read the SD card to get a config file that describes the hardware this means it won't currently work. There are changes in the (currently unreleased) V3.3 version of the port that may make it possible to support the V3 board, but it is not something we have tested so far.
I have no idea where you are going with that.
What are you thinking I could use it for?
@fcwilt it appears as though the printer is powered by an MKS Robin Nano board.
There is a port of Reprapfirmware that supports STM32 processors and droftarts thought it might be compatible with it.
Unfortunately its not as it uses an STM32F1 processor rather than an F4 -
@jay_s_uk said in Analyze Thermistor?:
Unfortunately its not as it uses an STM32F1 processor rather than an F4Sorry - I failed to mention something that is very relevant. My bad.
The printer came with some kind of board but I am strictly a Duet user - their board went into the trash and I am using a Duet 3 Mini 5.
@fcwilt
the software would've functioned no different to a duet board, but fair enough
