    Analyze Thermistor?
    30
    1.2k
    • fcwiltundefined
      fcwilt @Veti
      @Veti said in Analyze Thermistor?:
      @fcwilt said in Analyze Thermistor?:
      When confronted with a machine with existing thermistors without specifications
      my first place to go is look at the marlin config if it exists.
      That is a good idea - it did come with a SD card that might have that information.
      • Vetiundefined
        Veti
        https://github.com/MarlinFirmware/Configurations/tree/import-2.0.x/config/examples
        • fcwiltundefined
          fcwilt @droftarts
          @droftarts said in Analyze Thermistor?:
          @fcwilt what printer is it?
          This one:
          Link to printer
          • fcwiltundefined
            fcwilt @Veti
            @Veti
              droftarts administrators @fcwilt
              @fcwilt Looks like github repo is here, this is the best line I could find quickly: https://github.com/my3dltd/F1-B-V2-NANO/blob/31874e09f71b465f56eeb7b6ba4938376e794848/robin_nano35_cfg.txt#L168
              • Vetiundefined
                Veti
                that does make sense. its an ultimaker 2 clone.
                ultimaker 2 uses thermocouples. so this clone does too.
                • fcwiltundefined
                  fcwilt
                  Thanks for the help.
                  I will investigate these resources later today.
                  engikeneerundefined 1 Reply Last reply Reply Quote 0
                  • engikeneerundefined
                    engikeneer @fcwilt
                    @fcwilt for a quick & dirty check, you could always stick the bed in your oven, set the temperature to ~80deg and leave the wires dangling out the door. Even better if you have a reliable thermistor/thermocouple setup to put in to get an accurate reading of how hot the oven is. Repeat for a few temps and see how different the generated parameters are?
                    i3 clone with a bunch of mods
                    • fcwiltundefined
                      fcwilt @Veti
                      Well I treated them as thermistors in RRF3 and they seem to work.
                      At least I was able to complete M303 but I used the B value from a thermistor I knew which is not likely to be correct.
                      • fcwiltundefined
                        fcwilt @engikeneer
                        @engikeneer said in Analyze Thermistor?:
                        I do have an good meter for measuring temps.
                          Is the text config file a new thing in Marlin? It still only seems to set the hot end temp sensor, but it is Thermistor #1, so you should be able to look that up in Marlin. Really they should be posting their full Marlin source, where I guess the bed sensor is hard coded.
                          • fcwiltundefined
                            fcwilt @droftarts
                            I will see what I can find but the web sites are sometimes a bit confusing.
                              @fcwilt can you use the Robin Nano electronics with the STM32 port of RRF? I don’t see it in @gloomyandy ’s wiki. https://teamgloomy.github.io/getting_started.html
                              droftartsundefined gloomyandyundefined fcwiltundefined 3 Replies Last reply Reply Quote 0
                                droftarts administrators @droftarts
                                Looks like the Robin Nano uses STM32F103VET6, so I guess not.
                                • gloomyandyundefined
                                  gloomyandy @droftarts
                                  Robin Nano
                                  Short answer is no, not supported.
                                  Longer answer is that there are different versions 1.x/2.x uses the STM32F1 mcu which we don't support. 3.x has an STM32F4 which we do support. However it uses a different SPI unit for SD card access to all of the other currently supported boards (plus a bunch of other differences). Given that we normally read the SD card to get a config file that describes the hardware this means it won't currently work. There are changes in the (currently unreleased) V3.3 version of the port that may make it possible to support the V3 board, but it is not something we have tested so far.
                                  • fcwiltundefined
                                    fcwilt @droftarts
                                    I have no idea where you are going with that.
                                    What are you thinking I could use it for?
                                      jay_s_uk @fcwilt
                                      @fcwilt it appears as though the printer is powered by an MKS Robin Nano board.
                                      There is a port of Reprapfirmware that supports STM32 processors and droftarts thought it might be compatible with it.
                                      Unfortunately its not as it uses an STM32F1 processor rather than an F4
                                      • fcwiltundefined
                                        fcwilt @jay_s_uk
                                        @jay_s_uk said in Analyze Thermistor?:
                                        Sorry - I failed to mention something that is very relevant. My bad.
                                        The printer came with some kind of board but I am strictly a Duet user - their board went into the trash and I am using a Duet 3 Mini 5.
                                        jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                          jay_s_uk @fcwilt
                                          @fcwilt
                                          the software would've functioned no different to a duet board, but fair enough
                                            Great! Though the Robin Nano is probably worth €30, as it’s Marlin and probably Klipper compatible. Usually has TMC2208 or 2209 (same as Mini 5+) drivers on plug in boards. Or donate it to Andy or Jay to see if they can port RRF to it!
                                            fcwiltundefined 1 Reply Last reply Reply Quote 2
