    Fans vs Berd-Air
    Smart effector for delta printers
    23
    49
    19.5k
    • c310undefined
      c310
      i found that
      70% of berd-air noise is from pump air flow
      30% is from the motor
      there are simple solutions for both
      Motor noise
      use flex mount. for myself i made this one
      there are other mounts with even vibration-canceling ones, but require more space. most simple solution (even no print needed) is to hang the motor on the rubber band 🙂
      AND use 22500 Hz PWM frequency. as a bonus this trick also keeps pump motor cold 🆒
      Pump airflow noise
      use silencers my design makes it silent. very silent. it is a bit tricky to print, but once printed, you will be surprised 🙂
      Phaedruxundefined 1 Reply Last reply Reply Quote 2
        deckingman @klcjr89
        @klcjr89 The flow rate in the data you posted is in H/L which I read as Hours per Litre. I'm assuming that's a typo and should be Litres/Hour. (Or does it really take >600 hours to shift one Litre of air ☺ ).
          Phaedrux Moderator @c310
          @c310 said in Fans vs Berd-Air:
          my design
          Link is broken.
          • laelundefined
            lael
            ok, so this is an old post, but it seems to be the most popular on google and useful. Does anyone have any reports on how their berd air systems have held up over time? Have they been excellent or a waste of time? How is their reliability?
            Does anyone have any followup data on the brushless aliexpress pump listed? It looks like the choice I am most tempted by at the moment.
            Surgikillundefined 1 Reply Last reply Reply Quote 0
              Phaedrux Moderator @Phaedrux
              @Phaedrux said in Fans vs Berd-Air:
              my design
              Link is broken.
              Hey look the link is working now.
              https://www.thingiverse.com/thing:3429324
              • Surgikillundefined
                Surgikill @lael
                @lael I just picked up a brushed system from the makerhive. Much cheaper than the brushless option. I might see if I can make the pump brushless at some point, but for now it's working great. I made my own air mount with some brass tube from Lowe's. Quieter and much easier to work with.
                lord binkyundefined 1 Reply Last reply Reply Quote 0
                • lord binkyundefined
                  lord binky @Surgikill
                  @Surgikill I'm curious what size brass tubing you use? I've tried using small hobby brass tubing and even packing the tube with salt powder it would still collapse in on itself in bad ways when i'd try to bend it. I'd much rather use brass than aluminum since the brass would deform without tearing/ breaking as easy as the aluminum, and the akuminum gets more break prone after exlosure to hotend buuut i have not been able to shape it without issues.
                  Hergonowayundefined deckingmanundefined Surgikillundefined 3 Replies Last reply Reply Quote 0
                  • Hergonowayundefined
                    Hergonoway @lord binky
                    @lord-binky don't use salt, use electric wire. Put it in the tube, bend it and pull the wire. For example, iirc, K&S soft brass (something like 8121) tube is a perfect match for heater cartridge electric wire gauge.
                    Edit: yes heater cartridge cable perfect fit 8121 K&S soft brass tube
                    Delta goes BrrrRRRRrrrrrRRRRrrr
                      deckingman @lord binky
                      @lord-binky said in Fans vs Berd-Air:
                      Invest in a small tube bender (min version of what plumbers use to bend pipes). Something like this https://www.amazon.co.uk/Tubing-Bender-Degrees-Manual-Bending/dp/B088H1MHWN/ref=sr_1_7?adgrpid=119993429162&dchild=1&gclid=Cj0KCQjwi7yCBhDJARIsAMWFScPk-xcgly9PRIz5mgxBPKlnamYT_OstJqT7pmfj1g5J3HHZ2Dz1Xs8aAohjEALw_wcB&hvadid=501516551233&hvdev=c&hvlocphy=9046150&hvnetw=g&hvqmt=e&hvrand=14776184315352084993&hvtargid=kwd-295847543910&hydadcr=1596_1935511&keywords=small+tube+bender&qid=1615808871&sr=8-7
                        Surgikill @lord binky
                        @lord-binky I didn't bend the tube. I just made jigs to drill it, then glued it into a tusk mount.
                          lord binky
                          Thanks, I'll try again with some of the cloth covered wire and see if that won't get stuck. I used jig's and spring tube benders which worked ok for the aluminum but that brass I tried before was just determined to fold in on itself.
                          • jens55undefined
                            jens55
                            A wild suggestion ... try freezing some water in it and then do the spring tube bender thing. I have not tried that myself, just read about it.
                            • c310undefined
                              c310
                              try tube bender https://www.thingiverse.com/thing:2869014
                              and my tube drilling mask https://www.thingiverse.com/thing:3608733
                              perhaps other berd-air useful parts :
                              Silencer https://www.thingiverse.com/thing:3429324
                              motor holder https://www.thingiverse.com/thing:3429374
