    always on fan not working ( 0.2V )
    617
    • micheldb14undefined
      micheldb14
      Hello everyone,
      Right now I have a 24V 30mm extruder fan connected to Fan 1 (turns on when temp exceeds around 40 degrees C )
      Now I have bought a 5V 40mm Noctua fan to replace the 30mm fan.
      I wanted to connect the fan to the always on fan connector set to 5V but the fan didnt do anything. when using a multimeter I read 0.2V on the always on fan pins. when I switch the jumper to VIN (24V) I still read 0.2V on the pins.
      Is there something wrong with the board, or do I need to turn some settings on to get the fan to work?
      It would be strange if there is something broken because I have never used the always on fan pins before.
      Thanks in advance,
      Michel
      • alankilianundefined
        alankilian @micheldb14
        @micheldb14
        What kind of board do you have?
        • Is your 2-pin fan-voltage-selction jumper working?
        • Do you read 5 Volts on the 5V pin in the three-pin fan voltage selection jumper?
        • Can you check the continuity between the center pin of the fan-voltage-selection and the V-FAN pin on the always-on 2-pin fan connector?
        micheldb14undefined 1 Reply Last reply Reply Quote 0
          micheldb14 @alankilian
          @alankilian
          Oh yeah forgot to mention... It's a Duet 2 maestro.
          I guess Its working, he looks fine and if tested another jumped with the same results.
          When testing between the ground (2-pin) and the 5V (3-pin) I got 0.15 volt.
          When testing between the ground (2-pin) and the VIN (3-pin) I got 0.22 volt.
          Yes I do have continuity between the center pin and the V-FAN pin on the 2-pin
            If you don't have +5 on the fan voltage selector, maybe you have a bad solder joint?
            There's nothine else between that pin and +5 and I ASSUME you have +5.
              @alankilian
              Is there another way to test if my +5V is working?
                @micheldb14 I don't think ANYTHING would work if you don't have +5
                • There's a RED LED that lights up saying if +5 is working.
                  (I think they are Blue = Vin, Red = +5 and green=+3.3)
                  @alankilian
                  yeah all the leds (VIN, 5V and 3,3V) are on
                    @micheldb14 I would say check the solder joints to see if they look poor.
                    I can't think of a reason to have the 5 Volt LED on and not have 5 Volts at the fan voltage connector.
                    Maybe @dc42 has an idea about +5 voltage routing.
                      Can you post a photo of the board and close up of the fan headers?
                      You're saying the 5v V_fan pin on the voltage selector block isn't providing 5v at all?
                        micheldb14 @Phaedrux
                        @phaedrux
                        Here you can see I only have 0.3V right now on the 5V connector
                        Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @micheldb14
                          @micheldb14 And that's measuring fan2 header, correct?
                          What do you get on the 5v pin of the jumper block itself?
                          micheldb14undefined 2 Replies Last reply Reply Quote 0
                            @phaedrux
                            Yes, the 2 wires are connected to the FAN2 pins as shown in the 3rd picture
                              droftarts administrators @micheldb14
                              @micheldb14 You are measuring FAN2. That's a PWM fan, not an always on fan.
                              micheldb14undefined 1 Reply Last reply Reply Quote 1
                                @phaedrux
                                I think this is how to measure from the 3 pin connector right?
                                  micheldb14 @droftarts
                                  @droftarts
                                  oh man..... thanks! I thought FAN2 was the always on fan because it a had a seperate 5V/VIN switch...now it all makes sense...
                                    @micheldb14 You are still measuring onto a PWM pin (yellow wire), ie it's turned off unless you've defined a fan on it in config.g and turned it on. MOSFETs that controls PWM are always on the negative (ground) side, because they need to be placed after the 'load'.
                                    Edit: Glad you got it figured out!
                                      @droftarts
                                      So just to clear things up.
                                      There is one jumper just to switch between 5V and VIN on FAN2
                                      And the other Jumper is to switch 5V and VIN for FAN1, FAN0 and ALWAYS-ON FAN?
                                      If this is the case, is there a way to set FAN2 as extruder fan so it will turn on when the hotend gets hot? (what now is the case with FAN1)
                                        @micheldb14 said in always on fan not working ( 0.2V ):
                                        @droftarts
                                        Yes, that is correct.
                                        Post your config.g and response to M115, so we know how it’s currently set and what firmware you are on.
                                          @droftarts
                                          M115
                                          FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-05-19b2
                                          config.g:
                                          ; Configuration file for Duet Maestro (firmware version 3)
                                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 14 2020 22:20:39 GMT+0200 (Midden-Europese zomertijd)
                                          M550 P"AM8-BLV" ; set printer name
                                          M918 P1 E4 F2000000 ; configure direct-connect display
                                          M586 P0 S1 ; enable HTTP
                                          M586 P1 S0 ; disable FTP
                                          M586 P2 S0 ; disable Telnet
                                          M569 P0 S1 D2 ; physical drive 0 goes forwards in spreadcycle
                                          M569 P1 S1 D2 ; physical drive 1 goes forwards in Stealthchop2 till about 150 mm/sec
                                          M569 P2 S0 D2 ; physical drive 2 goes forwards in Stealthchop2
                                          M569 P3 S1 D2 ; physical drive 3 goes forwards in spreadcycle
                                          M92 X200.00 Y200.00 Z1600.00 E411.00 ; set steps per mm
                                          M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                          M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                                          M201 X1000.00 Y800.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                                          M906 X1100 Y1100 Z1100 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30 ; Set idle timeout
                                          M208 X-25 Y-25 Z0 S1 ; set axis minima
                                          M208 X215 Y215 Z250 S0 ; set axis maxima
                                          M574 X1 S1 P"!^xstop" ; configure active-high endstop for low end on X via pin xstop
                                          M574 Y1 S1 P"!^ystop" ; configure active-high endstop for low end on Y via pin ystop
                                          M574 Z1 S1 P"!^zstop" ; configure active-high endstop for low end on Z via pin zstop
                                          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                          M557 X10:200 Y10:195 S20 ; define mesh grid
                                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                                          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                          M572 D0 S0.035 ; Set pressure advance
                                          M501
                                            This defines and sets Fan 1
                                            Add this for Fan2:
                                            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                            M106 P2 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                                            micheldb14undefined 1 Reply Last reply Reply Quote 2
