    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    32.2k
      Phaedrux Moderator @carcamerarig
      @carcamerarig said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
      link text
      This one you can definitely hear the clunk on travel.
        dc42 administrators @carcamerarig
        @carcamerarig, thanks! The M569.2 R111 results show that the drivers are running in stealthChop mode. Therefore, the issue could be due to stealthChop/spreadCycle changeover. What M569 V parameter are you using? Are you still getting banging if you set spreadCycle mode instead?
        carcamerarigundefined 1 Reply Last reply Reply Quote 0
        • carcamerarigundefined
          carcamerarig @Phaedrux
          @phaedrux that 1st one was the wrong video lol, my bad.... so many damn videos now Ive shared the wrong one, it was the same as the last video definitely a bang.
            carcamerarig @dc42
            @dc42 said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
            Yes its happening in all modes, at the moment its still as it was configured from Ian's
            ; Drive Mappings
            M569 P0.0 S0 D3 V0 ; Drive 0: X Axis
            M569 P0.1 S0 D3 V0 ; Drive 1: Y Axis
            M569 P0.2 S0 D3 V0 ; Drive 2: Z Axis
            M569 P0.3 S0 D3 V0 ; Drive 3: E Axis
            M569 P0.4 S0 D3 V0 ; Drive 4: E1 used for Z1
              OK, please try setting spreadCycle (D2 in the M569 command, once you have finished stall homing). If/when you are sure that banging has occurred, send the M569.2 P# R111 commands again, while it is still printing.
                carcamerarig @dc42
                Home it in stealthchop, send M569 D2 in console then run the print making sure there's no homing in the gcode right?
                  Correct.
                  carcamerarigundefined 3 Replies Last reply Reply Quote 0
                    carcamerarig @dc42
                    bang 1
                    Date	Event
                    19/04/2021, 23:06:54	M569.2 P0.4 R111
                    Register 0x6f value 0x40080000
                    19/04/2021, 23:06:49	M569.2 P0.3 R111
                    19/04/2021, 23:06:45	M569.2 P0.2 R111
                    19/04/2021, 23:06:40	M569.2 P0.1 R111
                    Register 0x6f value 0x00080000
                    19/04/2021, 23:06:34	M569.2 P0.0 R111
                    Register 0x6f value 0x80080000
                    19/04/2021, 23:02:19	M32 "0:/gcodes/Sat1.gcode"
                    File 0:/gcodes/Sat1.gcode selected for printing
                    19/04/2021, 23:02:13	M569 P0.1 D2
                    19/04/2021, 23:02:06	M569 P0.0 D2
                      carcamerarig @dc42
                      So in spreadcycle its banging like a hooker on smack..... I let it run for a bit but something going to break again so ive quit it! The supposed switchover banging on infill is even more prominent but its not supposed to switching in D2 right??
                      I'll upload the video of the infill bangs (mini bangs) but I didn't catch a travel move bang, too busy reporting M569.2 P# R111's...
                      19/04/2021, 23:16:24	Printing paused at X186.4 Y40.6 Z3.0
                      19/04/2021, 23:16:20	M25
                      Resume state saved
                      19/04/2021, 23:16:13	M569.2 P0.4 R111
                      19/04/2021, 23:16:10	M569.2 P0.3 R111
                      19/04/2021, 23:16:06	M569.2 P0.2 R111
                      Register 0x6f value 0xc0080000
                      19/04/2021, 23:16:01	M569.2 P0.1 R111
                      19/04/2021, 23:15:56	M569.2 P0.0 R111
                      19/04/2021, 23:14:30	M569.2 P0.0 R111
                      19/04/2021, 23:14:26	M569.2 P0.1 R111
                      19/04/2021, 23:14:22	M569.2 P0.2 R111
                      19/04/2021, 23:14:16	M569.2 P0.3 R111
                      19/04/2021, 23:14:13	M569.2 P0.4 R111
                      19/04/2021, 23:13:39	M569.2 P0.4 R111
                      19/04/2021, 23:13:35	M569.2 P0.3 R111
                      19/04/2021, 23:13:32	M569.2 P0.2 R111
                      19/04/2021, 23:13:29	M569.2 P0.1 R111
                      19/04/2021, 23:13:26	M569.2 P0.0 R111
                      19/04/2021, 23:11:35	M569.2 P0.0 R111
                      19/04/2021, 23:11:33	M569.2 P0.1 R111
                      19/04/2021, 23:11:29	M569.2 P0.2 R111
                      19/04/2021, 23:11:24	M569.2 P0.3 R111
                      19/04/2021, 23:11:19	M569.2 P0.4 R111
                      m122
                      RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+2 (2021-04-15 16:55:30) running on Duet 3 Mini5plus WiFi (standalone mode)
                      Board ID: Z9NZN-A296U-D65J0-40KM4-LY03Z-ZPQPD
                      Used output buffers: 3 of 40 (30 max)
                      Static ram: 100104
                      Dynamic ram: 106340 of which 32 recycled
                      Never used RAM 34372, free system stack 134 words
                      Tasks: NETWORK(ready,202) HEAT(delaying,294) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,334) TMC(delaying,71) MAIN(running,337) IDLE(ready,20) AIN(notifyWait,266)
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 00:15:48 ago, cause: power up
                      Last software reset at 2021-04-18 12:27, reason: User, GCodes spinning, available RAM 34372, slot 2
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      Aux1 errors 0,0,0
                      MCU revision 3, ADC conversions started 1090996, completed 1090995, timed out 0, errs 0
                      Step timer max interval 26927
                      Supply voltage: min 23.4, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/620/566, gc cycles 11
                      Driver 0: position 35612, ok, SG min/max 0/400, read errors 0, write errors 0, ifcnt 21, reads 889, writes 0, timeouts 0, DMA errors 0
                      Driver 1: position 10295, ok, SG min/max 0/504, read errors 0, write errors 0, ifcnt 20, reads 889, writes 0, timeouts 0, DMA errors 0
                      Driver 2: position 1096, ok, SG min/max 0/206, read errors 0, write errors 0, ifcnt 17, reads 890, writes 0, timeouts 0, DMA errors 0
                      Driver 3: position 0, ok, SG min/max 16/416, read errors 0, write errors 0, ifcnt 13, reads 890, writes 0, timeouts 0, DMA errors 0
                      Driver 4: position 0, ok, SG min/max 0/112, read errors 0, write errors 0, ifcnt 18, reads 889, writes 0, timeouts 0, DMA errors 0
                      Driver 5: position 0, assumed not present
                      Driver 6: position 0, assumed not present
                      Date/time: 2021-04-19 23:15:13
                      Cache data hit count 1354624958
                      Slowest loop: 87.00ms; fastest: 0.09ms
                      === Storage ===
                      Free file entries: 9
                      SD card longest read time 1.0ms, write time 5.0ms, max retries 0
                      DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                      === MainDDARing ===
                      Scheduled moves 12869, completed moves 12829, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 17, 0], CDDA state 3
                      === AuxDDARing ===
                      Bed heaters = 0 -1, chamberHeaters = -1 -1
                      Heater 0 is on, I-accum = 0.3
                      Heater 1 is on, I-accum = 0.6
                      Segments left: 1
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is doing "G1 X185.485 Y57.962 E0.01508" in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      SBC is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Aux2 is idle in state(s) 0
                      Code queue is empty.
                      === Filament sensors ===
                      Extruder 0 sensor: ok
                      === CAN ===
                      Messages queued 160, send timeouts 160, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                      Last cancelled message type 30 dest 127
                      === Network ===
                      Slowest loop: 216.27ms; fastest: 0.09ms
                      HTTP sessions: 1 of 8
                      - WiFi -
                      Network state is active
                      Failed messages: pending 0, notready 0, noresp 1
                      WiFi firmware version 1.25beta0
                      WiFi MAC address f4:cf:a2:6f:e9:78
                      WiFi Vcc 3.36, reset reason Power up
                      WiFi flash size 2097152, free heap 21784
                      WiFi IP address 192.168.1.226
                      WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
                      Clock register 00002002
                      19/04/2021, 23:23:46	M569 P0.4
                      Drive 4 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 64, pwmScaleAuto 9, pwmOfsAuto 255, pwmGradAuto 24, pos 168
                      19/04/2021, 23:23:43	M569 P0.3
                      Drive 3 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 19, pwmScaleAuto 0, pwmOfsAuto 90, pwmGradAuto 18, pos 680
                      19/04/2021, 23:23:40	M569 P0.2
                      Drive 2 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 0 (inf mm/sec), pwmScaleSum 60, pwmScaleAuto 5, pwmOfsAuto 255, pwmGradAuto 22, pos 72
                      19/04/2021, 23:23:33	M569 P0.1
                      Drive 1 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 644
                      19/04/2021, 23:23:27	M569 P0.0
                      Drive 0 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 516
                        carcamerarig @dc42
                        For clarity
                        G90                                         ; Send absolute coordinates...
                        M83                                         ; ...but relative extruder moves
                        M550 P"Duet Caribou 420"                        	; Set machine name
                        M552 S1                                     	; Enable network
                        ;*** Access point is configured manually via M587
                        ;M586 P0 S1                                  ; Enable HTTP
                        ;M586 P1 S0                                  ; Disable FTP
                        ;M586 P2 S0                                  ; Disable Telnet
                        M575 P1 S1 B57600							; Panel Due
                        ; Drive Mappings
                        ; Motor remapping for dual Z and axis Limits
                        M584 X0 Y1 Z2:4 E3				; two Z motors connected to driver outputs Z and E1
                        M671 X-37:287 Y0:0 S4			; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                        ; Micrpstepping and Speed
                        M350 X32 Y32 E16 Z16 I1                     ; Configure microstepping with interpolation
                        M92 X200.00 Y200.00 Z400.00 E830.00         ; Set steps per mm
                        ; Speeds, Acceleration and Jerk
                        M566 X900 Y900 Z25.00 E600.00 P1      ; Set maximum instantaneous speed changes (mm/min)
                        M203 X18000.00 Y18000.00 Z720.00 E1200.00     ; Set maximum speeds (mm/min)
                        M201 X1500.00 Y1500.00 Z1200.00 E4000.00     ; Set accelerations (mm/s^2)
                        ; Motor currents
                        M906 X700.00 Y700.00 Z700.00 E700.00 I20    ; Set motor currents (mA) and motor idle factor in percent X,Y,Z=1000/1.414 E=1400/1.414
                        M84 S30                                     ; Set idle timeout
                        ; Printer geometry
                        M208 X0:250 Y-4:215 Z-0.5:410               ; Axis Limits
                        M564 H0							            ; allow unhomed movement
                        ; Endstops for each Axis
                        M574 X1 S3								 	; Set endstops controlled by motor load detection
                        M574 Y1 S3                               	; Set endstops controlled by motor load detection
                        ; Stallgaurd Sensitivy
                        ;M915 X S-2 F0 H200 R0		                ; Set X axis Sensitivity  MOVED TO HOMEALL.G
                        ;M915 Y S15 F0 H200 R0		                ; Set y axis Sensitivity
                        ; Input Shaper
                        ;M593 F58.5 P4 S0.2  ; Input Shaping 3.3/3.4
                        ;M593 F54.26
                        ; Z-Probe Super PINDA
                        M574 Z1 S0 ; Set endstops controlled by probe
                        M558 P5 C"^io3.in" I1 H1 F500 T4800 A30 S0.004
                        ; Mesh Grid
                        M557 X24:221 Y10:195 P8	                         ; Define mesh grid for probing
                        ; Sheets
                        ;G31 P1000 X23 Y5 Z1.730 	                    ; Satin Sheet
                        G31 P1000 X23 Y5 Z1.95 	  	                  ; Textured Sheet
                        ;G31 P1000 X23 Y5 Z1.445 					    ; PEI Sheet
                        ;G31 P1000 X23 Y5 Z1.445 					    ; PEI Sheet 0.6 nozzle -10 offset
                        ; Heatbed Heaters and Thermistor Bed
                        M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8       ; Set thermistor + ADC parameters for heater 0 Bed
                        M950 H0 C"out0" T0 Q10					                        ; Creates Bed Heater Qnn PWM frequency in Hz. Valid range: 0-65535, default: 500. (optional) 10hz stopped clicking
                        M307 H0 R0.273 C345.3 D10.89 S1.00 V23.8 B0						; PID 3.2
                        M140 H0										                    ; Bed uses Heater 0
                        M143 H0 S120                                                    ; Set temperature limit for heater 0 to 120C Bed
                        ; HotEnd Heaters and Thermistor HotEnd
                        M308 S1 P"temp1" Y"thermistor" T500000 B4725 C1.19622e-7	       	; define E0 temperature sensor e3d
                        M950 H1 C"out1" T1 						                            ; Create HotEnd Heater
                        M307 H1 R2.383 C178.5:130.6 D5.32 S1.00 V23.9 B0						; PID
                        M143 H1 S285                                                    	; Set temperature limit for heater 1 to 285C HotEnd
                        M302 S185 R185
                        M950 F1 C"out5" Q250				; Creates HOTEND Fan
                        M106 P1 T45 S235 H1                 ; HOTEND Fan Settings
                        M950 F0 C"out6" Q100				; Creates PARTS COOLING FAN
                        M106 P0 H-1                         ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN
                        M563 P0 D0 H1 F0                            ; Define tool 0
                        G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
                        G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
                        ; StealthCop calibration - MOVED TO HOMEALL.G
                        ; M17
                        ; G4 P150
                        ; G1 X2 Y2 Z2 F2000
                        ; G4 S2
                        ; M84 ; disable motors
                        ; Filament Sensor Logic
                        M98 P"0:/macros/02_Functions/StartupFilamentSensorCheck"  ; Runout Sensor Logic: Startup with filament = runout sensor active   Startup without filament = autoload active
                        Spreadcycle Video
                          droftarts administrators
                          Seems like we might, finally, have nailed this one. After testing all day today, @dc42 noticed the longest loop time in @carcamerarig's M122 reports was very long, often over 100ms. Looking through the M122 reports taken during printing in this thread, he noticed the SD card read times were very long, too, eg:
                          SD card longest read time 91.0ms, write time 5.2ms, max retries 0
                          By comparison, my loop time and SD card longest read, running the same code:
                          Slowest loop: 12.28ms; fastest: 0.10ms
                          SD card longest read time 7.9ms, write time 0.0ms, max retries 0
                          dc's current theory is that either the SD card is faulty, or the SD card interface is faulty. We're waiting for @carcamerarig to let us know if replacing the SD card helps.
                          dc42undefined 1 Reply Last reply Reply Quote 4
                            dc42 administrators @droftarts
                            To add to that, we also now have a firmware build that doesn't have these problems despite the excessively slow SD card read performance.
                              All testing I was doing was with 0.9° motors (48mm long NEMA 17 motors, one from E3D, one from Wantai) with similar specs to LDO motors, running at x32 micro stepping with interpolation. These were quiet in stealthchop, and noisier in spreadcycle, but not noticeably noisier than 1.8° motors.
                              I kept jerk settings high at 900mm/m (15mm/s) with Marlin jerk policy, acceleration at 2000mm/s^2, speeds up to 18,000mm/m (300mm/s). Motor current was 1000mA on X and Y, though these are 1.7A motors.
                              With these setting (which are probably close to the limit my poor old machine can cope with!) I didn’t have any banging problems, though as noted in previous posts, we think these are actually related to an SD card problem.
                              I also didn’t have problems in hybrid mode, so long as changeover speed was low, but could replicate the “micro banging” @carcamerarig experienced in gyroid fill if set around 35mm/s, which is to be expected as this is the speed gyroid fill was being printed at, so X and Y axes speed up and slow down through the changeover speed on each gyroid curve.
                              One caveat is that I was using endstops for homing, not sensorless homing. We did get that working on @carcamerarig’s machine, I think reliably, though with 1.8 motors. I’ll test sensorless homing my setup when I can.
                              I’ll update the documentation with best practices for all of that we’ve learnt in this process!
                                All, we have tracked down this issue. It affects Duet 3 Mini boards running all released firmware versions when a heater output is configured to a low PWM frequency - for example, when the bed heater is set to run at 10Hz because it is driven via a SSR. Unfortunately, there is a synchronisation delay between the heater management task and the PWM port, which causes the heater task to hog the CPU for up to one cycle at the PWM frequency, and that occasionally causes the movement system to fail to finalise moves before they are due to be executed.
                                We already have Duet 3 Mini firmware with improved motion planning that works around this, and I expect to fix the underlying issue shortly. The fix will be in the 3.3beta3 release, which I hope to make available within the next few days. Meanwhile, for anyone not using SSRs to drive heaters, the workaround is to use a higher PWM frequency, e.g. 100Hz or 500Hz.
                                Special thanks to @carcamerarig, who has worked closely with us over the last few days to help us get to the bottom of this.
                                oc_geekundefined ctilley79undefined Argoundefined 3 Replies Last reply Reply Quote 7
                                • oc_geekundefined
                                  oc_geek @dc42
                                  @dc42 good catch !
                                  that might also be the issue behind slicer output .g files not completing the upload when the heater is turned on. They reach 100% but then start over again and again...
                                  thanks
                                    carcamerarig
                                    Thanks to everyone involved in this, there are a few of you LOL made especially testing for some with my lack of knowledge of RRF, Gcode and 3d printing in general. I've learned a lot in a short space of time and glad I didn't quit on the mini, I'm especially impressed with the level of support from the Duet team to find the cause and then produce a number fixed fw / workarounds until resolved.
                                    Looking forward to 3.3b3 in few days 🙂
                                    Phaedruxundefined 1 Reply Last reply Reply Quote 3
                                    • ctilley79undefined
                                      ctilley79 @dc42
                                      @dc42 You owe @carcamerarig a bottle of Macallan lol.
                                        @carcamerarig Thanks for sticking with it.
                                        • Argoundefined
                                          Argo @dc42
                                          Oh that explains why I had trouble with slow downs at 10Hz and swiftly switched back to 100Hz because the slow downs were already obvious during the probing procedure.
                                          https://forum.duet3d.com/topic/22142/slowdowns-pauses-pid-algorithm-and-pwm-freq?_=1619033412104
                                          I already suspected it had something to do with internal cycles as Prusa explained that they also had issues with that.
                                          https://blog.prusaprinters.org/dev-diary-2-how-we-made-the-heatbed-silent_30946/
                                            dc42 administrators @oc_geek
                                            @oc_geek said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                                            @dc42 good catch !
                                            thanks
                                            Yes. I did some tests on the old firmware with 5Hz PWM frequency and found that it completely disrupted file uploading. Anyway, a 1-line change has fixed the underlying issue, so we're hoping to release 3.3beta3 tomorrow.
                                            fulgundefined 1 Reply Last reply Reply Quote 4
