    Software package 3.3beta3 released
    Beta Firmware
    34
    96
    10.7k
    • ctilley79undefined
      ctilley79
      Height map disappears in DWC with attached SBC. If you go to the height map tab in DWC and refresh the browser. The height map will not reload in the 3D viewport with error "height map not available". In order to get it back, you have to go to the system tab, edit hieghtmap.csv and then navigate back to the height map.
      In addition to this error, I've had a couple instances where commands completely halt the 6HC main board. I'm not sure if the process is dying on the SBC or whether the board is panicking and indeed shutting off.
      • sebkritikelundefined
        sebkritikel @dc42
        @dc42 Alright, what am I doing wrong? Likely something simple
        Duet2 Wifi +Duex5
        Duet Web Control 3.3.0-b3
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.3beta3 (2021-04-22)
        Wiring diagram (tried some variations of this, including using duex.cs5, duex.cs6). Green LED on each of the boards tested.
        M955 P0 C"spi.cs3+spi.cs4"
        Error: M955: Accelerometer not found on specified port
        Update - I'm quite confident the cable assembly was good, but likely was too long (~11ft). Trimmed 4ft off the Duet side, re-terminated and now we're good to go.
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
        Diamondbackundefined 1 Reply Last reply Reply Quote 2
        • Topherundefined
          Topher @dc42
          @dc42 Will there be proper speaker support using M300 for the duet 2 at any point down the road? Currently with the speaker output on the expansion header, M300 can only trigger on and off and a duration of the pulse to the speaker pin, no oscillation.
          • joekoundefined
            joeko
            the mcu temperture is 10 degrees above room temperture.
            do i have to do a pid tuning like in the wiki and if so how ?
              dc42 administrators @joeko
              @joeko said in Software package 3.3beta3 released:
              There are instructions for calibrating the MCU temperature reading at https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature.
              joekoundefined 2 Replies Last reply Reply Quote 0
              • joekoundefined
                joeko @dc42
                @dc42 said in Software package 3.3beta3 released:
                yes i know but when i send Send command M912 P0 STr or Tc i get the error message that i have to set the sensor number.
                • joekoundefined
                  joeko @dc42
                  sorry, i got it.
                  this set the correction and now it is ok 🙂
                  thx
                    deckingman
                    I am once again unable to print anything since upgrading from 3.3. beta2 to 3.3. beta 3. This macro (which is called from my gcode files) causes the board to reset as soon as the hot end and bed reach their set temperatures (immediately after the M116). PrePrintPLAUVAB.g The reset loses the network connection temporarily, turns off all the heaters, and causes the axes to lose their homing status. Just what I need before starting a print (not).
                    EDIT. Reverted back to 3.3. beta2 and all is well again. So it's definitely caused by 3.3. beta 3 (either the firmware or DWC version).
                      deckingman
                      Update on this. It seems to be consistent whenever I try beta 3. M122 reports a software reset as soon as macro finishes heating and the M116 completes. Reason: HardFault and a load of codes and with "bad marker". DC has been provided with more details via a different channel to these forums.
                      • Lorisundefined
                        Loris
                        Hi all, i have a strange behaviour using rrf 3.3b3.
                        I printed a file already in my SD (when i use 3.3b1).
                        This file is a simple testing cube sliced in simplify3d having 1 perimeter only.
                        Printed with 3.3b1 is perfect.
                        Printed with 3.3b3 seems that first layers are smaller than normal.
                        I also confirm that the probe z-offset with 3.3b3 seems different, it print al little far away from bed, 3.3b1 perfect.
                        Same config.g and same configuration.
                        I only changed the firmware.
                        To do a test, i rollback to 3.3b1 and it prints perfectly the same file.
                        Here a picture about the print with 3.3b3
                        matt3oundefined 1 Reply Last reply Reply Quote 0
                        • matt3oundefined
                          matt3o @Loris
                          @loris could it be a temperature issue? have you tried to re-run the pid calibration?
                          • Diamondbackundefined
                            Diamondback @sebkritikel
                            @sebkritikel said in Software package 3.3beta3 released:
                            @dc42 ~~Alright, what am I doing wrong? Likely something simple
                            Duet2 Wifi +Duex5
                            Wiring diagram (tried some variations of this, including using duex.cs5, duex.cs6). Green LED on each of the boards tested.~~
                            I have the same issue, but much shorter wiring already. (about 1.5m in total or so)
                            @dc42 are there any known limitations to SPI cable length and/or crimp connection quality?
                            • PaulHewundefined
                              PaulHew
                              Noticed that the Layer Chart does not display info.
                              P.
                              Stephen6309undefined 1 Reply Last reply Reply Quote 0
                              • Stephen6309undefined
                                Stephen6309 @PaulHew
                                @paulhew If you are using PrusaSlicer you need to add to the Before layer change G-Code: ;LAYER:[layer_num]
                                It's under Custom G-Code in Printer Settings.
                                PaulHewundefined Sytac072undefined 2 Replies Last reply Reply Quote 1
                                • PaulHewundefined
                                  PaulHew @Stephen6309
                                  @stephen6309 said in Software package 3.3beta3 released:
                                  LAYER:[layer_num]
                                  Thanks, appreciate the info.
                                  I will try it after this tophat.
                                  Regards,
                                  Paul
                                  • Sytac072undefined
                                    Sytac072
                                    Hello... I have tried to upgrade my Tevo delta today from RRF 3.2.2 to 3.3 beta 3 but after the upgrade, the extruder disappeared from the DWC and from the paneldue.
                                    This is how the motors are configured:
                                    I don't what is wrong.
                                      Stephen6309 @Sytac072
                                      @sytac072 I have a 1LC with my 6HC & Mini 5+, mine is M584 X0.0 Y0.1 Z0.2 E121.0
                                      If you have a Duet 3, try adding 0. to the drive numbers. That's what the reprapfirmware configurator does.
                                      Sytac072undefined 1 Reply Last reply Reply Quote 0
                                      • Sytac072undefined
                                        Sytac072 @Stephen6309
                                        @stephen6309 Thank you very much for your tip. I have a duet2 Wifi. I am not sure if your settings may also work on mine.
                                          @sytac072 Have you tried the good ol' turnoff/turnon fix? 🙂
                                          The config.g is still valid?
                                          • Sytac072undefined
                                            @stephen6309 Yes, I did it... The config.g is the same I was using with RRF 3.2.2. I reinstalled it and the printer was working again.
                                            SIamundefined 1 Reply Last reply Reply Quote 0
