    Option to prompt "are you sure" before cancelling a print?
    Duet Web Control wishlist
    9
    18
    719
    • Blacksheep99undefined
      Blacksheep99 @OwenD
      @owend said in Option to prompt "are you sure" before cancelling a print?:
      If you add
      M291 R"Confirm" P"Do you really want to cancel" S3
      To the start of cancel.g it should do what you want.
      i.e. If you hit OK, it will run the rest of what is in cancel.g
      if you hit cancel it will bail out.
      Of course if cancel.g is called programmatically (M25) by anything else it will also wait for a prompt.
      I'm not aware of anything that does call cancel.g other than pressing the cancel button, but just so you take it into consideration.
      I don't have a cancel.g. Is it part of the standard config? I can create it but thought it worth asking.
      Thanks for the code
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @Blacksheep99
        @blacksheep99
        If cancel.g isn't present then stop.g would be run
        Look up M0 (runs stop.g if present ) and M25 (runs cancel.g if present)
        So, in your case, create cancel.g and put in it anything you want to happen when a print is canceled.
        I'm pretty sure if cancel.g is present the print won't stop unless it's so dictated by the contents of cancel.g whereas if stop.g isn't present the print will still stop if M0 is sent.
        Not near a computer so can't test.
          T3P3Tony administrators
          I have moved this to the Duet Web Control wishlist as it would be good to have an optional setting in DWC to prompt before cancelling that is independent of prompts within cancel.g
          • o_lampeundefined
            o_lampe @T3P3Tony
            @t3p3tony
            It would already help to have the two buttons further apart. There's no problem for users with a mouse, but touchpad-tablet users with 'ten thumbs' will appreciate that for sure 😉
            jens55undefined A Former User? 2 Replies Last reply Reply Quote 1
            • jens55undefined
              jens55 @o_lampe
              @o_lampe said in Option to prompt "are you sure" before cancelling a print?:
              @t3p3tony
              Been peaking at me operating my laptop, have you .....
              • TheBasedDogeundefined
                TheBasedDoge
                An option to add "are you sure" on the Emergency Stop would be nice as well... I have accidentally tapped it while using DWC on my phone before 😞
                chimaeraghundefined A Former User? 2 Replies Last reply Reply Quote 0
                • chimaeraghundefined
                  chimaeragh @TheBasedDoge
                  @thebaseddoge I don't think waiting to answer a prompt in the middle of an emergency is a good idea.
                  Duet 2 Wifi, Ooznest Workbee CNC 1510
                  TheBasedDogeundefined 1 Reply Last reply Reply Quote 0
                    TheBasedDoge @chimaeragh
                    @chimaeragh True I guess. But i usually just press the power button on my printer if there is an actual need for E STOP
                    chimaeraghundefined 1 Reply Last reply Reply Quote 0
                      @thebaseddoge I use my duet to control a CNC. We don't have the luxury of time 3d printing applications have. If I need to stop the machine from moving, it has to be instant.
                        A Former User @TheBasedDoge
                        @o_lampe
                        The suggestion with more screen-space instead of a confirmation is definetly the right for the "emergency stop"-button
                        @thebaseddoge
                        emergency is something critical, rather then having a "are you sure" you might consider to ask for more blank screenspace around it to lower to risk to hit it accidentally...
                        I would support this new wish, as this might be somehting most people can live with and touch-users also benefit from. Put the link here if you posted it in the wishlist and you have my thumbs up.
                          A Former User @o_lampe
                          This post is deleted!
                          • jens55undefined
                            jens55
                            FWIW,
                            'Emergency stop' means just that. Stop NOW.
                            What I suggested is a confirmation for a non emergency abort which is a totally different kettle of rabbits.
