Solved PANEL CONTROL DUET WIFE
@luca-massimiliano Check that the SD card specification will work with Duet: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Specification
(Class 4, maximum 32GB, formatted as FAT32)How did you format the SD card? Using the SD card formatting tool is best: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Formatting
@droftarts
la formatazione profonda fatta con sd card format.
prima di procedere devo spiegare cosa ho fatto ora:
1 inserita scheda vecchia ottengo il collegamento dwc al pc.
2 spengo la stampante levo scheda inserisco la scheda non funzionante , il pc si conette e la vede ora posso vedere tutta la scheda che ha il problema , avete consigli sui parametri da controllare o comparare , grazie mille ?
ps la scheda funziona fino al giorno prima ( cmq riformattata e ricopiata no) -
@luca-massimiliano The PanelDue shows that the config.g is working, so the card is being read. If it is not connecting, most probably something is corrupted in the /www directory of the SD card. Check what firmware version you are using with M115.
Put the 'non-working' SD card in your PC, delete the /www folder. Find the matching firmware version on Github: https://github.com/Duet3D/RepRapFirmware/releases
Find the 'DuetWebControl.zip' file that matches your firmware. eg if you are using RRF 3.2.2, this file: https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zip
Download this, extract it on your PC, and copy the contents to the SD card, in a new /www folder. Then try it in your Duet.
@droftarts
HO COPIATO LA SCHEDA OK SU QULLA DANNEGGIATO DEDUCO CHE LA SCHEDA SD FUNZIONIONA QUINDI DANNEGGIAMENTO DI FILE COME DICI TU . -
@droftarts
CARO AMICO ho risolto tutto perfettamente seguendo le tue indicazioni chiare , ti faccio i miei complimenti per intuito determinato, grazie cordiali saluti -
@droftarts
ciao ho scoperto che ,non mi compare piu' la vista 3d , -
@luca-massimiliano if you mean the gcode 3D view? It should be built-in in DWC 3.2.2, you just need to enable it. See https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_Plugins_tab_built_in
@droftarts
perfetto risolto mole grazie. buona serata -
This post is deleted! -
@droftarts
buonasera
ho un problema config g
; Riscaldatori
M308 S0 P "termistore" Y "T100000 B3950; configurare il sensore 0 come termistore sul pin bedtemp
M950 H0 C "bedheat" T0; crea l'uscita del riscaldatore del letto sul riscaldamento del letto e mappala al sensore 0
M307 H0 B1 S1.00; abilitare la modalità bang-bang per il riscaldatore del letto e impostare il limite PWM
M140 H0; mappa piano riscaldato su stufa 0
M143 H0 S120; limite di temperatura impostato per il riscaldatore da 0 a 120C
M308 S1 P "e0temp" Y "termistore" T100000 B4388; configurare il sensore 1 come termistore sul pin e0temp
M950 H1 C "e0heat" T1; crea l'uscita del riscaldatore ugello su e0heat e mappala al sensore 1
M307 H1 B0 S1.00; disabilitare la modalità bang-bang per il riscaldatore e impostare il limite PWM
M143 H1 S280; limite di temperatura impostato per il riscaldatore 1 ... 280C
M308 S2 P "e1temp" Y "termistore" T100000 B4388; configurare il sensore 2 come termistore sul pin e1temp
M950 H2 C "e1heat" T2; crea l'uscita del riscaldatore ugello su e1heat e mappala al sensore 2
M307 H2 B0 S1.00; disabilitare la modalità bang-bang per il riscaldatore e impostare il limite PWM
M143 H2 S280; impostare il limite di temperatura per il riscaldatore 2 a 280Csensore
di temperatura sensore di temperatura 100KΩ precisione di ± 1%. NTC 3950
cartuccia 12 V, potenza: 40 W. fino 280 g
comando:
M303 H1 P1 S260
M98 P "0: / macro / RISCALDATORI / HEATER 1"
Auto tuning riscaldatore 1 con temperatura target 260.0 ° C e PWM 1.00 - non lasciare stampante incustodita
risultato:
Sintonizzazione automatica annullata perché la temperatura target non è stata raggiunta -
What does the heater graph in DWC look like when tuning?
@luca-massimiliano said in PANEL CONTROL DUET WIFE:
If your thermistor is NTC 3950 your B value in M308 is incorrect. Change from B4388 to B3950 for both your heaters that use that NTC thermistor.
@phaedrux cambiato
provo subitio -
@phaedrux
perfetto ma dove trovo la comparazione tra NTC 3950 o altri i comando m308 b 3950 NTC thermistor -
@phaedrux
perfetto ma dove trovo la comparazione tra NTC 3950 o altri i comando m308 b 3950 NTC thermistorperfect but where do I find the comparison between NTC 3950 or other i command m308 b 3950 NTC thermistor
I dont understand the question as translated.
@phaedrux
il secondo se
mbra non andareM308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T100000 B3950 -
the second if
mbra not goM308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T100000 B3950I still do not understand.
@phaedrux said in PANEL CONTROL DUET WIFE:
B3950
niente da fare , domani cambio thermistor e riscaldatore , potrebbe avere un mal funzionamento grazie ti aggiorno domani
Are you saying that changing it to B3950 did not help the tuning complete?
Can you show a photo of the hotend? Possibly there is a problem with the assembly keeping it from reaching the expected temp.
Have you tried tuning to a lower temp that it is able to reach?
