    No WiFi this morning !?
    Using Duet Controllers
    1.4k
      jay_s_uk @tecno
      @tecno is there a file called config.bak?
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @jay_s_uk
        @jay_s_uk
        Morning Jay,
        Have copy on my PC but not 100% updated, so now there is a .bak file 😉
        Noticed that filaments is empty.
        /Bengt
        • tecnoundefined
          tecno @tecno
          @tecno
          Now X and Y are moving in wrong direction (I know the did work OK with that copy of config.g
          What is going on here?
          • o_lampeundefined
            o_lampe @tecno
            @tecno said in No WiFi this morning !?:
            Check the forum, there are others with SD-Card issues on Duet Mini5. Might be a bad batch or soldering issues?
            • tecnoundefined
              tecno @o_lampe
              @jay_s_uk
              Got it all sorted out .................. phuu 😉
              How do I ge a backup of 0:/system ?
              How to move firmware files to 0:/firmware ?
              jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                jay_s_uk @tecno
                @tecno you can either tick the little check box at the top of the system files tab and then right click and download as zip or you can use something like FTP to download everything. There is a utility for this here
                To move things to the firmware folder its going to be a case of deleting whatever is present in system and let the firmware handle it going forwards. Or pull the sd card and manually move the files over
                • tecnoundefined
                  tecno
                  @jay_s_uk
                  Right clikck > download does not exist here! Did read about it but nothing here. That would someting I prefere rather that be using RFM.
                  Is this a bug in latest RC ?
                  ps. Why do I get ERROR down in right corner when I want to Submit?? I have to restart forum
                    jay_s_uk
                    @tecno I get that restart error sometimes when submitting
                    latest RC
                    Make sure you right click in the area of the files, not on the tick box itself
                    tecnoundefined 1 Reply Last reply Reply Quote 1
                    • tecnoundefined
                      tecno @jay_s_uk
                      @jay_s_uk
                      This is what I get
                        jay_s_uk @tecno
                        @tecno you can't download directories as part of the zip. uncheck them and you should be good to go
                        • tecnoundefined
                          tecno @jay_s_uk
                          @jay_s_uk
                          Thank you very much Jay, much appreciated!
                            Phaedrux Moderator @tecno
                            WiFi firmware version 1.24beta2-05b1
                            Your wifi server version needs to be updated.
                            Place this bin file in your firmware folder and then boot up and send M997 S1 to re-flash the wifi module.
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.3RC3/DuetWiFiServer.bin
                            Then check M122 again it should show the wifi server version as 1.26.
                            tecnoundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            • tecnoundefined
                              tecno @Phaedrux
                              Well here I am again with no connection with my Mini 5+ other that terminal connects but accepts no commands at all !
                              Urgent help needed how to proceed .
                              • o_lampeundefined
                                o_lampe @tecno
                                @tecno
                                You might need a USB hub to have enough power to feed the Duet? Just guessing...
                                What kind of commands did you try?
                                • tecnoundefined
                                  tecno @o_lampe
                                  @o_lampe
                                  Power via printers PSU
                                  M552 to check if WiFi is active or not
                                  • o_lampeundefined
                                    o_lampe @tecno
                                    @tecno
                                    Fair enough. What about M115 or M122? Just to see, if the SD-card has been read or not
                                    • tecnoundefined
                                      tecno
                                      @o_lampe
                                      In red, terminal response to what ever command is sent
                                      Warning : x bytes not sent anymore
                                      • tecnoundefined
                                        tecno
                                        Anyone to help me?
                                          jay_s_uk @tecno
                                          @tecno sounds like you lost your config.g again?
                                          • tecnoundefined
                                            tecno @jay_s_uk
                                            @jay_s_uk
                                            Maybe, how do I get the board to respond?
