    No WiFi this morning !?
    Using Duet Controllers
    1.4k
      jay_s_uk @tecno
      @tecno you can either tick the little check box at the top of the system files tab and then right click and download as zip or you can use something like FTP to download everything. There is a utility for this here
      To move things to the firmware folder its going to be a case of deleting whatever is present in system and let the firmware handle it going forwards. Or pull the sd card and manually move the files over
      • tecnoundefined
        tecno
        @jay_s_uk
        Right clikck > download does not exist here! Did read about it but nothing here. That would someting I prefere rather that be using RFM.
        Is this a bug in latest RC ?
        ps. Why do I get ERROR down in right corner when I want to Submit?? I have to restart forum
          jay_s_uk
          @tecno I get that restart error sometimes when submitting
          latest RC
          Make sure you right click in the area of the files, not on the tick box itself
          tecnoundefined 1 Reply Last reply Reply Quote 1
          • tecnoundefined
            tecno @jay_s_uk
            @jay_s_uk
            This is what I get
              jay_s_uk @tecno
              @tecno you can't download directories as part of the zip. uncheck them and you should be good to go
              tecnoundefined 1 Reply Last reply Reply Quote 0
              • tecnoundefined
                tecno @jay_s_uk
                @jay_s_uk
                Thank you very much Jay, much appreciated!
                  Phaedrux Moderator @tecno
                  @tecno said in No WiFi this morning !?:
                  WiFi firmware version 1.24beta2-05b1
                  Your wifi server version needs to be updated.
                  Place this bin file in your firmware folder and then boot up and send M997 S1 to re-flash the wifi module.
                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.3RC3/DuetWiFiServer.bin
                  Then check M122 again it should show the wifi server version as 1.26.
                  tecnoundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  • tecnoundefined
                    tecno @Phaedrux
                    Well here I am again with no connection with my Mini 5+ other that terminal connects but accepts no commands at all !
                    Urgent help needed how to proceed .
                    • o_lampeundefined
                      o_lampe @tecno
                      @tecno
                      You might need a USB hub to have enough power to feed the Duet? Just guessing...
                      What kind of commands did you try?
                      • tecnoundefined
                        tecno @o_lampe
                        @o_lampe
                        Power via printers PSU
                        M552 to check if WiFi is active or not
                        • o_lampeundefined
                          o_lampe @tecno
                          @tecno
                          Fair enough. What about M115 or M122? Just to see, if the SD-card has been read or not
                          • tecnoundefined
                            tecno
                            @o_lampe
                            In red, terminal response to what ever command is sent
                            Warning : x bytes not sent anymore
                            • tecnoundefined
                              tecno
                              Anyone to help me?
                                jay_s_uk @tecno
                                @tecno sounds like you lost your config.g again?
                                • tecnoundefined
                                  tecno @jay_s_uk
                                  @jay_s_uk
                                  Maybe, how do I get the board to respond?
                                    jay_s_uk @tecno
                                    @tecno well i suggest following this https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond#Section_Check_the_voltage_indication_LEDs
                                    check your sd card to see if config.g is there and what its contents is
                                    • tecnoundefined
                                      tecno @jay_s_uk
                                      @jay_s_uk
                                      LED's are lit
                                      config.g is there and all looks familiar
                                        jay_s_uk @tecno
                                        @tecno send these over USB
                                        M552 S0
                                        M552 S1
                                        let us know what the output is
                                        • tecnoundefined
                                          tecno @jay_s_uk
                                          @jay_s_uk
                                          As I wrote earlier this morning:
                                            jay_s_uk @tecno
                                            @tecno no idea then. never seen that warning, especially not in red. all terminal programs I use are black and white
