    CoreXY or Cartesian which is better ?
    53
    6.2k
    • jens55undefined
      jens55 @fcwilt
      @fcwilt, that list puts you well above my level of experience. I just know that throwing a large bed (or really any substantial mass) in x/y is a mistake. I currently use the same speed range that you describe but speed really isn't the issue but rather acceleration or change in speed per given time unit. I can s l o w way down and all of a sudden there is no issue with moving a heavy bed.
      I am sure that my understanding of 'cartesian' motion system is not complete either so if there is a 'cartesian' setup that doesn't move the bed in x/y, my comments don't hold water (or filament)
      • Michael Hathawayundefined
        Michael Hathaway @Hiroaki
        @hiroaki The less you move the bed, the better. Linear rails is a plus. My new printers have lifting/flying gantry with a solid non-moving bed. I have all screw drive with no belts which I think is better, but that is debatable.
        Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
        www.MatterHackers.com - https://discord.gg/Ked7GREqux
        • Hiroakiundefined
          Hiroaki @Hiroaki
          @hiroaki said in CoreXY or Cartesian which is better ?:
          Hello there.
          I have made some CoreXY printers and one Cartesian (which moves heating bed for X axis) but I am wondering if Cartesian which moves the nozzle X and Y axis is better than CoreXY to make the machine more accurate.
          If there is anyone who has made both CoreXY and Cartesian which moves the Nozzle for both axis, please give me your idea.
          Regards
          Everybody Thank you.
          Please take a look at the photo.
          My question is whether COREXY or cartesian has better position accuracy, assuming a printer like this one. γ€€Sorry for confusing...IMG_6425.JPG
          • fcwiltundefined
            fcwilt @jens55
            @jens55 said in CoreXY or Cartesian which is better ?:
            A bed slinger always struck be as a less than good idea and I never considered having one of those.
            My first non-delta printer was the FT5 which moves the bed on the Z axis.
            Two steppers move the X gantry along the Y axis.
            One stepper, mounted ON the X gantry moves, the extruder assembly along the X axis.
            This to me was the "classical" Cartesian printer but perhaps a bed slinger is a Cartesian as well.
            As I understand it one of the goals of the CoreXY design (and perhaps others) was to get the X axis stepper OFF of the moving bits thus reducing the mass of the moving bits - in theory.
              CoreXY is a lot easier to build than an ultimaker style cross gantry. I'd say it's hard to beat in general for a good all around printer.
              fcwiltundefined oliofundefined 2 Replies Last reply Reply Quote 2
              • fcwiltundefined
                fcwilt @Michael Hathaway
                @tinken said in CoreXY or Cartesian which is better ?:
                Ya gotta love it.
                My current favorite printer has all belt drive.
                I guess these differences are what keep life interesting.
                Hiroakiundefined 1 Reply Last reply Reply Quote 1
                • fcwiltundefined
                  fcwilt @Phaedrux
                  @phaedrux said in CoreXY or Cartesian which is better ?:
                  I can see that it is easier to build - with the cross gantry system getting everything lined up just right so there was no binding took a bit of fussing and cussing.
                  Now I'm no expert and I have seen the math on the different kinematics but I let my eyes glaze over and move on to something else.
                  My "MarkForged" style printer with the two Y steppers seems to avoid the racking issues folks talk about. What I like is that the belt paths are are shorter even though it takes three belts instead of two as in a CoreXY.
                  I've got a couple of Chinese CoreXY kits that have been sitting in boxes for a year or more - perhaps I will decide to re-visit the design.
                  Hiroakiundefined 1 Reply Last reply Reply Quote 0
                  • Hiroakiundefined
                    Hiroaki @fcwilt
                    @fcwilt I agree! Thanks
                    • Hiroakiundefined
                      Hiroaki @fcwilt
                      @fcwilt I have thought about to make one with lead screws(or ball screws) . But when I calculate the travel speed between belt drive and screw drive, and also wear out of the screws, I gave up making one. What is the lead of screws of yours? I feel that with the belt drive, it goes too much and with leadscrews it goes too small....
                      o_lampeundefined fcwiltundefined Michael Hathawayundefined 3 Replies Last reply Reply Quote 0
                      • o_lampeundefined
                        o_lampe @Hiroaki
                        @hiroaki
                        There are leadscrews with 8mm lead. They'd be faster, but IMHO also wear out faster and need stronger motors (higher risk of loosing steps).
                        I went for ballscrews right away, but not for XY axes. They run easier and don't wear out fast.
                        • oliofundefined
                          oliof @Phaedrux
                          @phaedrux CoreXY may be easier to build, but it's ultimately (pun intended) harder to square. An ultimaker style sheet-based box printer is more or less self-squaring ...
                          o_lampeundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                          • o_lampeundefined
                            o_lampe @oliof
                            @oliof said in CoreXY or Cartesian which is better ?:
                            Do you talk about belt tensioning?
                            TBH, I made up an easy to implement "belt tension-equalizator". But never felt the urge to implement it.
                            Lazyness: 1
                            Difficult to square: 0
                            oliofundefined 1 Reply Last reply Reply Quote 1
                            • oliofundefined
                              oliof @o_lampe
                              @o_lampe no, I mean getting the frame square, especially when using aluminum extrusions. Belt tension is another issue, looking forward to see your fix (-:
                              • fcwiltundefined
                                fcwilt @Hiroaki
                                @fcwilt What is the lead of screws of yours?
                                I don't understand the question. The one printer I mentioned, in response to your post about having all screw drive, has all belt drives.
                                • fcwiltundefined
                                  fcwilt @oliof
                                  What do you think about the E3D motion system in that regards?
                                  • fcwiltundefined
                                    fcwilt @oliof
                                    Can you provide a link to a design like that?
                                    • mrehorstdmdundefined
                                      mrehorstdmd
                                      You don't "tune" belt tension in a corexy printer. The exact and even the relative tensions of the belts isn't important (of course, you don't want them flopping around and you don't want them so tight that they destroy the motor bearings). All that matters is that the x and y axes are square when you're finished. That's easily verified in different ways depending on how your machine is built. The way most corexy mechanisms are laid out, the belts will be about the same tension when the axes are square.
                                      It can be pretty easy to align the linear guides in a corexy printer if you build the xy mechanism on a flat plate. That's probably true of any other xy motion system, too.
                                      You can design any printer to be easy to align or alignment can be an afterthought, and then you suffer the consequences.
                                      • Hiroakiundefined
                                        Hiroaki @mrehorstdmd
                                        @mrehorstdmd I understand! Thank you!
                                          @hiroaki I don't use T8 lead screw (too slow), I use Igus high helix lead screws. I will never be as fast as the corexy guys, but I have no belts.
                                          https://youtu.be/I-3kKkkonrs
                                          Hiroakiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                          • Hiroakiundefined
                                            Hiroaki @Michael Hathaway
                                            @tinken I see, how much is the lead ?
                                            Michael Hathawayundefined 1 Reply Last reply Reply Quote 0
