Independently leveled Z axis Issue
@martin7404 said in Independently leveled Z axis Issue:
I am not bragging
I know, I'm just giving you a hard time.
MY new board is here tomorrow so I will be able to go back to original setup.
P.S , Until now I was using prusa slicer profiles of GUI for left and right tools that activates only needed tool and today started calibration prints with dual material, and as far both tools are activated in the beginning , there is difference and it is that during print the standby tool cariage is not moving at least visualy -
@martin7404 That's strange, not sure how that would make a difference.
@fcwilt My bed is definitely bent in the back corner. I'm not sure if this is entirely the issue because it gives a deviation of .1mm but its definitely more than that. I did not consider this as I didn't have any issue for the first six months of use. I'll take it into work and have them make a skim cut to see if this helps.
Do you know why the mesh is not centered but in the negative?
@3DPrintingWorld said in Independently leveled Z axis Issue:
That's usually because you're not setting Z0 with G30 before doing the mesh.
@Phaedrux It homes first which has a G30 at the end so I thought that would apply but Ill try a G30 right after the G28 and before the G29.
I'd have to see exactly what gcode is happening in order and what your probe is etc. Normally the Z0 point would be green and the differences above or below. But it's all below, so that means where ever Z0 was set is above the surface of where it thinks the bed is when the mesh was created.
The total deviation is quite small though so the heightmap can appear exaggerated. There's also only 4 points, so it could very well be obscuring the Z0 position because it's very far away from the probed points of the mesh. I think a higher resolution height map would tell a more accurate story.
@3DPrintingWorld Today while comisioning my new coreXY and as far my plate was givin 0.15 mm deviation on the G29, I played a little with G32
Try this as bed.g and see what is the resultG29 S2 ;M561 ;G28 home G30 P0 X15 Y15 Z-99999 ; Probe Left ;G30 P0 X15 Y285 Z-99999 ; Probe Left G30 P1 X200 Y285 Z-99999 ; Probe Middle ;G30 P0 X200 Y15 Z-99999 ; Probe Left ;G30 P0 X331 Y285 Z-99999 ; Probe Middle G30 P2 X331 Y15 Z-99999 S3 ; Probe Right G30 P0 X15 Y285 Z-99999 ; Probe Left G30 P1 X200 Y15 Z-99999 ; Probe Middle ;G30 P0 X331 Y285 Z-99999 ; Probe Middle G30 P2 X331 Y285 Z-99999 S-1 ; Probe Right
@fcwilt I will answer for me. No, my issue was never resolved.
@mrenz999 said in Independently leveled Z axis Issue:
Well I'm sorry to hear that but I have no idea what we are talking about.
This is a very long thread with multiple people involved. If you're still having some issues, please start a new thread with all the relevant info and we can take another go at it.
