    First layer issues-Extrusion volume dropping on first layer?
    2.2k
    • fcwiltundefined
      fcwilt @rkaronde
      @rkaronde
      The thing that helped me the most with first layer adhesion was slow speed -15 mm/s.
      I use plain old "rectilinear" infill for all surface layers.
      I have no idea what those infill types are.
      I've never experienced any sort of extruder slow down so I have no idea what might be causing it.
      Fredeick
      rkarondeundefined 1 Reply Last reply Reply Quote 0
      • rkarondeundefined
        rkaronde @fcwilt
        @fcwilt Adhesion is not a problem, and the first layer speed is slow 20mm/s.
        Monotonic is just rectilinear if there are no other patterns in the first layer.
        I used Hilbert Curve for the first time because I wanted to make the infill start from left side and go to right to make sure this is not an issue with bed leveling.
        • fcwiltundefined
          fcwilt @rkaronde
          @rkaronde said in First layer issues-Extrusion volume dropping on first layer?:
          When you tried mesh compensation did you create the height map with the bed hot? That can make a big difference.
          When I start a print I pre-heat the bed for 15 mins.
          • rkarondeundefined
            rkaronde @fcwilt
            @fcwilt Yup. I ran about 25 test with all the tweaks I mentioned, and most of the time I kept the bed hot when just changing config.g, etc.
            For any hardware change I let the bed heat for a while, not 15 min, but around 5.
            • fcwiltundefined
              fcwilt @rkaronde
              @rkaronde
              I posted your files using the </> tag.
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 22:28:24 GMT-0500 (Eastern Standard Time)
              G90                                            ; send absolute coordinates...
              M83                                            ; ...but relative extruder moves
              M550 P"SKGo"                                   ; set printer name
              M669 K1                                        ; select CoreXY mode
              M552 S1                                        ; enable network
              M586 P0 S1                                     ; enable HTTP
              M586 P1 S0                                     ; disable FTP
              M586 P2 S0                                     ; disable Telnet
              ;Set PanelDue 7i
              M575 P1 B57600 S1
              M584 X0 Y1 Z2:4 E3                             ; set drive mapping (dual Z on driver 2 and 4)
              ;M584 X0 Y1 Z2 E3                               ; set drive mapping
              M569 P0 S1                                     ; physical drive 0 goes forwards
              M569 P1 S1                                     ; physical drive 1 goes forwards
              M569 P2 S1                                     ; physical drive 2 goes forwards
              M569 P3 S0                                     ; physical drive 3 goes backwards
              ;Z Leadscrew locations
              M671 X-10:310  Y150:150 S5  ;left, Right  S5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
              M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
              ;motor currents
              M906 X1100 Y1100 Z1100 E800 I60                ; LDO LDO-42STH40-1684MAC  ZZZ Motor Currents (mA). 2.375A is peak of 1.68A RMS, 1.9A is 80% of 2.375A
                                                             ; set motor currents (mA) and motor idle factor in
              ; Accelerations
              M201 X4000 Y4000                               ; Accelerations (mm/s^2)
              M201 Z1000                                     ; LDO ZZZ Acceleration
              M201 E1500.00                                  ; Extruder acceleration (mm/s^2)
              M203 X24000.00 Y24000.00 Z900.00 E3600.00      ; set maximum speeds (mm/min)
              M566 X1000.00 Y1000.00 Z300 E1500.00           ; set maximum instantaneous speed changes (mm/min)
              ;M92 X200.00 Y200.00 Z1600.00 E830              ; set steps per mm
              M92 X200.00 Y200.00 Z800.00 E415              ; set steps per mm
              M84 S30                                        ; Set idle timeout
              M208 X0 Y0 Z0 S1                               ; set axis minima
              M208 X305 Y302 Z340 S0                         ; set axis maxima
              M574 X1 Y1 S3					; set X endstops to use motor stall
              M574 Z1 S2      				; set z-Probe
              ; Z-Probe PINDA
              M574 Z1 S2 ; Set endstops controlled by probe
              M558 P5 C"^zprobe.in" I1 H0.7 F800 T6000 A20 S0.03 ; PINDA
              ;M308 S2 P"e1_temp" A"PINDA" Y"thermistor" T100000 B3950    ;thermistor on the PINDA
              G31 P500 X0 Y-27 Z2.23                                    ;yellow sheet   ; set Z probe trigger value, offset of 0 in X and -27 in Y and trigger height
              M557 X5:290 Y5:270 S20                                ; define mesh grid
              ; Z-Probe BLTouch
              ;M574 Z1 S2 ; Set endstops controlled by probe
              ;M558 P9 C"^zprobe.in" H4 F150 T8000
              ;M950 S0 C"exp.heater3"
              ;G31 P25 X23 Y0 Z3.485                                   ; set Z probe trigger value, offset of -22 in X and 0 in Y and trigger height (Slice 0.4)
              ;G31 P25 X23 Y0 Z3.196                                   ; set Z probe trigger value, offset of -22 in X and 0 in Y and trigger height  (E3D 0.8)
              ;M557 X10:295 Y10:295 S20                                ; define mesh grid
              ;Filament sensor
              M591 D0 P5 C"e0stop" R100:350 E10.0 S1  ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 100 to 350%, 10mm comparison length, Enabled
              ; Bed Heater
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4138            ; configure sensor 0 as thermistor on pin bedtemp
              M950 H0 C"bedheat" T0                                     ; create bed heater output on bedheat and map it to sensor 0
              M140 H0                                                   ; map heated bed to heater 0
              M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
              M307 H0 A191.5 C435.9 D4.3 V24.3 B0                       ; disable bang-bang mode for bed heater and set PID autotune PWM values
              ; Extruder Heater
              ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725  C7.06e-8   ; configure sensor 1 as Hemera thermistor on pin e0temp
              M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.196220e-7
              M950 H1 C"e0heat" T1                                      ; create nozzle heater output on e0heat and map it to sensor 1
              M143 H1 S440                                              ; set temperature limit for heater 1 to 390C
              M950 F0 C"fan0" ;Q200                           ; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"fan2" Q15000                           ; create fan 1 on pin fan1 and set its frequency
              M106 P1 S0.7 H1 ;L200 X250 H1 T60:140                ; set fan 1 value. Thermostatic control is turned on. Min speed of 120 as 60 deg, and max speed for 200 (255 is 100%) at 140+degrees
              M563 P0 D0 H1 F0                               ; define tool 0
              G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
              G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
              M501						; Load config-override.g
              T0                                             ; select first tool
              M561                         ; clear any existing bed transform
              G28 ; home
              M558 H1
              G30 P0 X15 Y150 Z-99999 ; probe near a leadscrew, half way along Y axis
              G30 P1 X285 Y150 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
              ;do it again
              ;finally home Z again at the center of the bed
              G1 X150 Y177 F6000
              G30 ;single z probe
              • fcwiltundefined
                fcwilt @rkaronde
                @rkaronde
                When you create or load the height map are you first setting the Z=0 datum using G30?
                • rkarondeundefined
                  rkaronde @fcwilt
                  @fcwilt Yes, in bed.g, at the end, there is a G30 at the center on the bed. The mesh leveling happens after bed.g is run.
                  • fcwiltundefined
                    fcwilt @rkaronde
                    Have you tried upping the extrusion multiplier using M221 or the DWC slider control?
                      Calibrate your extruder and tune your extrusion multiplier.
                      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                      I wouldn't use hilbert curve as an indicator of first layer quality. It's not really a suitable pattern for first layer with all the direction changes. The extrusion could become so slow that the filament starts to cook in the hotend.
                      Show us your slicer settings. Upload a sliced gcode file.
                      • rkarondeundefined
                        rkaronde @Phaedrux
                        @phaedrux Calibrated the Esteps and extrusion multiplier. ESteps did not change, the extrusion multiplier changed by 0.01, so went from 1 -> 1.01.
                        Still the issue persists.
                        Running a few more tests it looks like an issue with Z distance between bed and nozzle increasing as the first layer progresses.
                        On a 150x150mm square print with reclinear infill the layer stops sticking halfway through the layer, I then reduced the distance using baby step, and kept doing that as the print stops sticking again. At the end of the layer I had to move the nozzle closer by 0.2mm (-0.2)!!!. That is a lot.
                        I tried heating bed for 15 min before starting print/probing to see if thermal expansion is somehow involved. But that did not help and the print still did not stick halfway through.
                        Next heated the bed for a while and then ran mesh bed leveling. Then moved the head to various points on the bed with a piece of paper under it to see if the nozzle is close to the bed. And the paper is being gripped by the nozzle correctly. If I raise the bed by 0.2mm the paper does not grip. So the moving the bed using the bed using the Dashboard is maintaining the nozzle distance correctly.
                        Attaching the gcode of the file I used, and slicer settings.IMG_1974.jpg Platter.png Layers.png Filament.png Cooling.png Speeds.png
                        150x150_center_0.2mm_PLA__50m.gcode
                        Also adding the height map, it is pretty level in the middle of the bed.
                          Instead of a large flat full infill print try something like this STL instead.
                          bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                          • o_lampeundefined
                            o_lampe @rkaronde
                            @rkaronde
                            Do you see skipped steps for the Z-axis?
                            That's the only explanation, why it keeps gripping the paper when moved manually, but building up a gap when it does mesh levelling
                            • rkarondeundefined
                              rkaronde @Phaedrux
                              Printed without an issue.
                              The lines are pretty well stuck to the bed, and I could see the Z motors move when printing near the bump in the front part of the bed.
                              • rkarondeundefined
                                rkaronde @o_lampe
                                @o_lampe I have not heard any skipping, not sure if there is any way to measure the skipping.
                                Also in the middle of the bed the Z motors don't actually have to move since the bed is pretty flat. I also marked the Z motor pulley with a Sharpie and it does not move from the initial position printing infill in the center of the bed.
                                This is a CoreXY with bed moving up/down, so if Z is stable then I would think the X gantry is somehow moving up (not sure how that can happen). I also did the bedlevel_nozzel print suggested by Phaedrux and that stuck well all through.
                                The reason I am trying large flat full infill print as test is because I ran into this issue when printing large footprint models/STLs and got into debugging.
                                I am going to recheck for any mechanical issues.
                                engikeneerundefined Phaedruxundefined o_lampeundefined 3 Replies Last reply Reply Quote 0
                                • engikeneerundefined
                                  engikeneer @rkaronde
                                  @rkaronde silly question time... you don't have any PLA parts supporting your hot bed that are warping under heat/load during the print are you? When I first started printing ABS on my printer I spent days trying to figure out why my z offset ket changing before realised my bed supports had basically melted... 😛
                                  i3 clone with a bunch of mods
                                  • rkarondeundefined
                                    rkaronde @engikeneer
                                    @engikeneer Fair question.
                                    Except for the cooling duct and PINDA holder this printer does not use any plastic parts, it is all metal.
                                    https://seckit3dp.design/kit/sk-go2-essential
                                      Phaedrux Moderator @rkaronde
                                      This may be more of an extrusion or cooling issue then.
                                      Can you confirm the fan is off for the first layer?
                                      Have you tried upping the first layer hotend and bed temp a bit? Maybe 65c bed, 225c nozzle?
                                      What is your first layer extrusion width?
                                      • rkarondeundefined
                                        rkaronde @Phaedrux
                                        @phaedrux Yes the cooling fan is OFF for the first layer
                                        The first layer extrusion width is 0.42mm (nozzle is 0.4mm), should I try a different extrusion width?
                                        I will try upping the temps.
                                        Thanks
                                        • fcwiltundefined
                                          fcwilt @rkaronde
                                          Thanks
                                          What is your first layer speed
                                          What is the first layer height as opposed to the normal layer height?
                                          • rkarondeundefined
                                            rkaronde @fcwilt
                                            @fcwilt First layer speed is 20mm/sec
                                            First Layer height is 0.2mm
                                            In a post above I have attached screenshots of most of the slicer settings.
