    ONE PING ONLY --- M42
    Using Duet Controllers
    819
    • tecnoundefined
      tecno @jay_s_uk
      @jay_s_uk said in ONE PING ONLY --- M42:
      M42 P0 S1 G4 P500 M42 P0 S0
      Still continious, so question is if my M950 needs editing?
        jay_s_uk @tecno
        @tecno what do you mean its still continuous?
        Are you using M42 in your config.g?
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @jay_s_uk
          @jay_s_uk
          No M42 in config.g
          M950 in config.g
          M5000.g in sys
          Console command M5000
          It triggers but does it coninously instead of one shot
            jay_s_uk @tecno
            @tecno maybe 0.5s is too long, try reducing to P100
            Otherwise it sounds like you might need to add something to pull it back down to ground once released?
            • tecnoundefined
              tecno @jay_s_uk
              @jay_s_uk
              Tested that still same issue
              • tecnoundefined
                tecno @tecno
                Take away the 1K serial resistor on output?
                  jay_s_uk @tecno
                  @tecno dunno, i'm not really an electronics guy
                  tecnoundefined 1 Reply Last reply Reply Quote 1
                  • tecnoundefined
                    tecno @jay_s_uk
                    Tested = same issue 😉
                    Hopefully sombody else chimes in ta advice what to try next.
                    Thanks !
                    • fcwiltundefined
                      fcwilt @tecno
                      @tecno
                      What are the specs on the device you have connected to that output?
                      What does it expect to see in the way of signal voltage and duration?
                      • tecnoundefined
                        tecno @fcwilt
                        @fcwilt said in ONE PING ONLY --- M42:
                        @tecno
                        The IO output goes go GND to trigger camera ( switch is NO and swithes to ground )
                        https://forum.duet3d.com/topic/23976/mini5-bt-dongle-for-transmit/19
                          jay_s_uk @tecno
                          @tecno can you change the M950 to
                          M950 P0 C"^io1.out" Q1
                          • tecnoundefined
                            tecno @jay_s_uk
                            Tried that still same issue with serial 1K, will test with no serial 1K
                            • tecnoundefined
                              tecno @tecno
                              @fcwilt @jay_s_uk
                              IT WORKS NOW !!!
                              ;Camera trigger
                              M950 P0 C"!io1.out" Q1
                              Thank you guys, this forum is so helpful !
                              fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 4
                              • fcwiltundefined
                                fcwilt @tecno
                                @tecno said in ONE PING ONLY --- M42:
                                @fcwilt @jay_s_uk
                                IT WORKS NOW !!!
                                ;Camera trigger
                                Glad to hear you got it working.
                                Do you understand why you needed that ! character?
                                • alankilianundefined
                                  alankilian @tecno
                                  @tecno
                                  Excellent.
                                  I did say:
                                  I would put a series resistor inline.
                                  Maybe 100 Ohms to 1,000 Ohms and try it.
                                  So I was already thinking 1,000 Ohms might be too large.
                                  I'm glad you stuck with the experiments and got it working!
                                  • tecnoundefined
                                    tecno @fcwilt
                                    @fcwilt @jay_s_uk
                                    IT WORKS NOW !!!
                                    ;Camera trigger
                                    This inverts the signal and by that the level rises above the trigg point in the BT circuit, right?
                                    • tecnoundefined
                                      tecno @alankilian
                                      @alankilian said in ONE PING ONLY --- M42:
                                      @tecno
                                      Excellent.
                                      I did say:
                                      Experiments are always good as long one tries to follow good practis, in my case ask questions frequently.
                                      Thanks for guidance!
                                      • fcwiltundefined
                                        fcwilt @tecno
                                        @fcwilt @jay_s_uk
                                        IT WORKS NOW !!!
                                        ;Camera trigger
                                        Correct.
                                        Without that ! character the normal state of the output is low which is the state that triggers the camera. Adding that ! character makes the normal state of the output high.
