    ONE PING ONLY --- M42
    Using Duet Controllers
    817
      jay_s_uk @tecno
      @tecno maybe 0.5s is too long, try reducing to P100
      Otherwise it sounds like you might need to add something to pull it back down to ground once released?
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @jay_s_uk
        @jay_s_uk
        Tested that still same issue
        • tecnoundefined
          tecno @tecno
          @jay_s_uk said in ONE PING ONLY --- M42:
          Take away the 1K serial resistor on output?
            jay_s_uk @tecno
            @tecno dunno, i'm not really an electronics guy
            tecnoundefined 1 Reply Last reply Reply Quote 1
            • tecnoundefined
              tecno @jay_s_uk
              Tested = same issue 😉
              Hopefully sombody else chimes in ta advice what to try next.
              Thanks !
              • fcwiltundefined
                fcwilt @tecno
                @tecno
                What are the specs on the device you have connected to that output?
                What does it expect to see in the way of signal voltage and duration?
                • tecnoundefined
                  tecno @fcwilt
                  @fcwilt said in ONE PING ONLY --- M42:
                  @tecno
                  The IO output goes go GND to trigger camera ( switch is NO and swithes to ground )
                  https://forum.duet3d.com/topic/23976/mini5-bt-dongle-for-transmit/19
                    jay_s_uk @tecno
                    @tecno can you change the M950 to
                    M950 P0 C"^io1.out" Q1
                    • tecnoundefined
                      tecno @jay_s_uk
                      Tried that still same issue with serial 1K, will test with no serial 1K
                      • tecnoundefined
                        tecno @tecno
                        @fcwilt @jay_s_uk
                        IT WORKS NOW !!!
                        ;Camera trigger
                        M950 P0 C"!io1.out" Q1
                        Thank you guys, this forum is so helpful !
                        fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 4
                        • fcwiltundefined
                          fcwilt @tecno
                          @tecno said in ONE PING ONLY --- M42:
                          @fcwilt @jay_s_uk
                          IT WORKS NOW !!!
                          ;Camera trigger
                          Glad to hear you got it working.
                          Do you understand why you needed that ! character?
                          • alankilianundefined
                            alankilian @tecno
                            @tecno
                            Excellent.
                            I did say:
                            I would put a series resistor inline.
                            Maybe 100 Ohms to 1,000 Ohms and try it.
                            So I was already thinking 1,000 Ohms might be too large.
                            I'm glad you stuck with the experiments and got it working!
                            • tecnoundefined
                              tecno @fcwilt
                              @fcwilt @jay_s_uk
                              IT WORKS NOW !!!
                              ;Camera trigger
                              This inverts the signal and by that the level rises above the trigg point in the BT circuit, right?
                              • tecnoundefined
                                tecno @alankilian
                                @alankilian said in ONE PING ONLY --- M42:
                                @tecno
                                Excellent.
                                I did say:
                                Experiments are always good as long one tries to follow good practis, in my case ask questions frequently.
                                Thanks for guidance!
                                • fcwiltundefined
                                  fcwilt @tecno
                                  @fcwilt @jay_s_uk
                                  IT WORKS NOW !!!
                                  ;Camera trigger
                                  Correct.
                                  Without that ! character the normal state of the output is low which is the state that triggers the camera. Adding that ! character makes the normal state of the output high.
