    ONE PING ONLY --- M42
    Using Duet Controllers
    797
      jay_s_uk @tecno
      @tecno dunno, i'm not really an electronics guy
      tecnoundefined 1 Reply Last reply Reply Quote 1
      • tecnoundefined
        tecno @jay_s_uk
        @jay_s_uk said in ONE PING ONLY --- M42:
        Tested = same issue 😉
        Hopefully sombody else chimes in ta advice what to try next.
        Thanks !
        • fcwiltundefined
          fcwilt @tecno
          @tecno
          What are the specs on the device you have connected to that output?
          What does it expect to see in the way of signal voltage and duration?
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @fcwilt
            @fcwilt said in ONE PING ONLY --- M42:
            @tecno
            The IO output goes go GND to trigger camera ( switch is NO and swithes to ground )
            https://forum.duet3d.com/topic/23976/mini5-bt-dongle-for-transmit/19
              jay_s_uk @tecno
              @tecno can you change the M950 to
              M950 P0 C"^io1.out" Q1
              • tecnoundefined
                tecno @jay_s_uk
                Tried that still same issue with serial 1K, will test with no serial 1K
                • tecnoundefined
                  tecno @tecno
                  @fcwilt @jay_s_uk
                  IT WORKS NOW !!!
                  ;Camera trigger
                  M950 P0 C"!io1.out" Q1
                  Thank you guys, this forum is so helpful !
                  fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 4
                  • fcwiltundefined
                    fcwilt @tecno
                    @tecno said in ONE PING ONLY --- M42:
                    @fcwilt @jay_s_uk
                    IT WORKS NOW !!!
                    ;Camera trigger
                    Glad to hear you got it working.
                    Do you understand why you needed that ! character?
                    • alankilianundefined
                      alankilian @tecno
                      @tecno
                      Excellent.
                      I did say:
                      I would put a series resistor inline.
                      Maybe 100 Ohms to 1,000 Ohms and try it.
                      So I was already thinking 1,000 Ohms might be too large.
                      I'm glad you stuck with the experiments and got it working!
                      • tecnoundefined
                        tecno @fcwilt
                        @fcwilt @jay_s_uk
                        IT WORKS NOW !!!
                        ;Camera trigger
                        This inverts the signal and by that the level rises above the trigg point in the BT circuit, right?
                        • tecnoundefined
                          tecno @alankilian
                          @alankilian said in ONE PING ONLY --- M42:
                          @tecno
                          Excellent.
                          I did say:
                          Experiments are always good as long one tries to follow good practis, in my case ask questions frequently.
                          Thanks for guidance!
                          • fcwiltundefined
                            fcwilt @tecno
                            @fcwilt @jay_s_uk
                            IT WORKS NOW !!!
                            ;Camera trigger
                            Correct.
                            Without that ! character the normal state of the output is low which is the state that triggers the camera. Adding that ! character makes the normal state of the output high.
