    Tool Board Heater Tuning Leading To Faults
    101
    5.4k
    • Dougal1957undefined
      Dougal1957 @DIY-O-Sphere
      @diy-o-sphere said in Tool Board Heater Tuning Leading To Faults:
      @kevinmar
      Put in the R value
      doesn't need it as it will default correctly
        Dougal1957 @fcwilt
        @fcwilt said in Tool Board Heater Tuning Leading To Faults:
        @dougal1957 said in Tool Board Heater Tuning Leading To Faults:
        yes but the T100000 is for a ntc100k thermistor should not be required for a pt1000 nor a beta value as they are linear and don't have a c param either so not sure if having those params are confusing the issue
        I was trying to point out that R, L and N are the only additional parameters for PT1000 devices.
        The B,C and T are clearly incorrect but are the affecting the heater or are they ignored since they don't apply?
        I don't know.
        I agree neither do I know but it has to be worth a try
        • fcwiltundefined
          fcwilt @KevinMar
          @kevinmar said in Tool Board Heater Tuning Leading To Faults:
          @fcwilt s
          Rnnn Series resistor value. Leave blank to use the default for your board.
          Lnnn ADC low offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)
          Hnnn ADC high offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)
          So Lnnn can offset the higher ambient reading?
          I have no idea. Never used PT1000 devices.
          And how does one know if the hardware supports automatic ADC gain and offset calibration?
          Again I have no idea but I suspect @dc42 would.
            Dougal1957 @fcwilt
            @fcwilt I do use PT1000 and 100's as well and do prefer them and don't have any need for the additional Params as yet but we will see Hopefully Kevin gets it all sorted
            • fcwiltundefined
              fcwilt @Dougal1957
              Do those devices require additional hardware to connect to a Duet board?
              Dougal1957undefined KevinMarundefined DIY-O-Sphereundefined 3 Replies Last reply Reply Quote 0
                Dougal1957 @fcwilt
                pt1000 no but the pt100 does need the daughter board
                • KevinMarundefined
                  KevinMar @fcwilt
                  This post is deleted!
                  • DIY-O-Sphereundefined
                    DIY-O-Sphere @fcwilt
                    @fcwilt
                    Not required for PT1000 on Duet3 and Maestro
                    (UTC+1)
                    Dougal1957undefined 1 Reply Last reply Reply Quote 1
                      @fcwilt
                      nor on a wifi/ethernet duet 2 board either just not quite as accurate due to the 4k7 sense resistor rather than the 2k2 one
                      • KevinMarundefined
                        KevinMar @Dougal1957
                        @dougal1957
                        New parameters: M307 H2 R2.050 C309.100:130.600 D6.20 S1.00 V24.3 B0
                        Another fault:
                        (I had been using the fan to cool the hotend down, so ignore values before 11:00)
                        • fcwiltundefined
                          fcwilt @KevinMar
                          @dougal1957
                          Another fault:
                          Did you check your config-override.g file to see if it included M307 commands?
                          KevinMarundefined 1 Reply Last reply Reply Quote 0
                          • KevinMarundefined
                            KevinMar @fcwilt
                            @fcwilt it included M307 commands that were generated from the autotuning and saved using M500
                            • fcwiltundefined
                              fcwilt @KevinMar
                              So we can ignore the ones in your config.g file?
                              • KevinMarundefined
                                KevinMar @fcwilt
                                @fcwilt They're identical
                                • fcwiltundefined
                                  fcwilt @KevinMar
                                  So you copied the lines from the config-override.g file and put them into your config.g file?
                                  I assume you re-booted.
                                  • KevinMarundefined
                                    KevinMar @fcwilt
                                    @fcwilt Affirmative
                                    • fcwiltundefined
                                      fcwilt @KevinMar
                                      @fcwilt Affirmative
                                      Strange problem you are having.
                                      You posted a screen shot showing heaters Ex0, Ex1 and Ex3 faulted.
                                      Were all three heating at the time?
                                        @KevinMar
                                        M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Ex0"
                                        On T0 you use a thermistor but not with the other tools?
                                        What is your tuning command.
                                        (UTC+1)
                                        • KevinMarundefined
                                          KevinMar @fcwilt
                                          @fcwilt Yes, all 3 faulted (nearly) simultaneously, when heating is initiated simultaneously
                                          • KevinMarundefined
                                            KevinMar @DIY-O-Sphere
                                            @diy-o-sphere Changed to thermistor (actually changed hardware) just to try troubleshooting
                                            DIY-O-Sphereundefined dc42undefined 2 Replies Last reply Reply Quote 0
