    Tool Board Heater Tuning Leading To Faults
    101
    5.4k
    • fcwiltundefined
      fcwilt @KevinMar
      @kevinmar said in Tool Board Heater Tuning Leading To Faults:
      @fcwilt Yes, all 3 faulted (nearly) simultaneously, when heating is initiated simultaneously
      If you execute a M570 command from the DWC Console what value does it report?
      KevinMarundefined 1 Reply Last reply Reply Quote 0
      • KevinMarundefined
        KevinMar @dc42
        @dc42 C values changed when tuning with the sock.
        R values were a manual change
        • KevinMarundefined
          KevinMar @fcwilt
          @fcwilt "Print will be terminated if a heater fault is not reset within 10 minutes"
            dc42 administrators @KevinMar
            @kevinmar confirm you are running firmware 3.3 on both main board and tool board?
            • KevinMarundefined
              KevinMar @dc42
              @dc42 yes, 100%. All running 3.3 non beta or anything
              • fcwiltundefined
                fcwilt @KevinMar
                As a test have you commented out the settings for all but one tool heater to see if that makes a difference?
                • KevinMarundefined
                  KevinMar @fcwilt
                  @fcwilt huh? Just comment out all of the heaters? I have not tried that.
                  Should I add "M570 H1 P10 T15 S0" to my config?
                  • KevinMarundefined
                    KevinMar
                    The thing that keeps confusing me is that this is a very standard-issue setup. Running all standard E3D + Duet hardware, and running a stable release of the firmware.
                    • fcwiltundefined
                      fcwilt @KevinMar
                      I was wondering if the same problem would occur you if you only had one extruder heater configured.
                      As to the M570 I was working with out of date documentation.
                      It turns out with current firmware it appears you have to have a H parameter to set/report on a given heater.
                      • fcwiltundefined
                        fcwilt @KevinMar
                        It most certainly is confusing but I would not be surprised if we are overlooking something that should be obvious.
                        • KevinMarundefined
                          KevinMar @fcwilt
                          @fcwilt Me too, but I've been digging
                          KevinMarundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                          • KevinMarundefined
                            KevinMar @KevinMar
                            This post is deleted!
                            • fcwiltundefined
                              fcwilt @KevinMar
                              When I'm faced with something like this I resort to a process of elimination, thus my suggestion to configure just one heater to see if it changes anything.
                              • KevinMarundefined
                                KevinMar @fcwilt
                                @fcwilt I've commented out all heaters except H2, autotuning now.
                                "M308 S2 P"21.temp0" Y"pt1000" A"Ex1"
                                M950 H2 C"21.out0" T2 ; Heater for extruder out tool 1
                                M307 H2 R2.050 C309.100:130.600 D6.20 S1.00 V24.3 B0
                                M570 H2 P10 T25 S0.1"
                                • fcwiltundefined
                                  fcwilt @KevinMar
                                  Worth a try.
                                  At some point did you verify that each tool board is actually at the address you are using?
                                  • KevinMarundefined
                                    KevinMar @fcwilt
                                    @fcwilt Yes, toolboards are at the addresses assigned
                                      Can you send M98 P"config.g" to check for any syntax errors?
                                      I'd also suggest generating a basic config using the online tool and trying with that.
                                      Perhaps a photo of the hotend itself my give us some clues.
                                      • fcwiltundefined
                                        fcwilt @KevinMar
                                        I've got a test setup on my workbench but it only has one tool board connected and it works fine.
                                        Perhaps there is some as yet undiscovered firmware problem that only manifests with multiple tool boards.
                                        • KevinMarundefined
                                          KevinMar @fcwilt
                                          @fcwilt @dc42
                                          Here's my new, super simple config
                                          M550 P"ToolChanger" 					; Set machine name
                                          M111 S0                              	; Debug off
                                          M929 P"eventlog.txt" S1					; Start logging to file eventlog.txt
                                          M555 P1									; Set RepRap output
                                          G4 S1  									; Wait for expansion boards to start
                                          M307 H2 R2.063 C316.300:132.500 D6.10 S1.00 V24.3 B0
                                          M143 H2 S300
                                          M950 F11 C"21.out2"
                                          M106 P11 S255 H2 T70
                                          M950 F1 C"21.out1"
                                          M563 P1 S"Tool1"  H2 F1
                                          G10  P1 S220 R205
                                          G29 S2
                                          T-1
                                          M501									; Load config-override.g
                                          KevinMarundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                          • KevinMarundefined
                                            KevinMar @KevinMar
                                            boom, fault at 70c
                                            It's most commonly faulting at 70c, which is when my hotend cooling fan is enabled
