    Tool Board Heater Tuning Leading To Faults
    101
    5.4k
      dc42 administrators @KevinMar
      @kevinmar confirm you are running firmware 3.3 on both main board and tool board?
      KevinMarundefined 1 Reply Last reply Reply Quote 0
      • KevinMarundefined
        KevinMar @dc42
        @dc42 yes, 100%. All running 3.3 non beta or anything
        • fcwiltundefined
          fcwilt @KevinMar
          @kevinmar said in Tool Board Heater Tuning Leading To Faults:
          @fcwilt "Print will be terminated if a heater fault is not reset within 10 minutes"
          As a test have you commented out the settings for all but one tool heater to see if that makes a difference?
          • KevinMarundefined
            KevinMar @fcwilt
            @fcwilt huh? Just comment out all of the heaters? I have not tried that.
            Should I add "M570 H1 P10 T15 S0" to my config?
            • KevinMarundefined
              KevinMar
              The thing that keeps confusing me is that this is a very standard-issue setup. Running all standard E3D + Duet hardware, and running a stable release of the firmware.
              • fcwiltundefined
                fcwilt @KevinMar
                I was wondering if the same problem would occur you if you only had one extruder heater configured.
                As to the M570 I was working with out of date documentation.
                It turns out with current firmware it appears you have to have a H parameter to set/report on a given heater.
                • fcwiltundefined
                  fcwilt @KevinMar
                  It most certainly is confusing but I would not be surprised if we are overlooking something that should be obvious.
                  • KevinMarundefined
                    KevinMar @fcwilt
                    @fcwilt Me too, but I've been digging
                    KevinMarundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    • KevinMarundefined
                      KevinMar @KevinMar
                      This post is deleted!
                      • fcwiltundefined
                        fcwilt @KevinMar
                        When I'm faced with something like this I resort to a process of elimination, thus my suggestion to configure just one heater to see if it changes anything.
                        • KevinMarundefined
                          KevinMar @fcwilt
                          @fcwilt I've commented out all heaters except H2, autotuning now.
                          "M308 S2 P"21.temp0" Y"pt1000" A"Ex1"
                          M950 H2 C"21.out0" T2 ; Heater for extruder out tool 1
                          M307 H2 R2.050 C309.100:130.600 D6.20 S1.00 V24.3 B0
                          M570 H2 P10 T25 S0.1"
                          • fcwiltundefined
                            fcwilt @KevinMar
                            Worth a try.
                            At some point did you verify that each tool board is actually at the address you are using?
                            • KevinMarundefined
                              KevinMar @fcwilt
                              @fcwilt Yes, toolboards are at the addresses assigned
                                Can you send M98 P"config.g" to check for any syntax errors?
                                I'd also suggest generating a basic config using the online tool and trying with that.
                                Perhaps a photo of the hotend itself my give us some clues.
                                • fcwiltundefined
                                  fcwilt @KevinMar
                                  I've got a test setup on my workbench but it only has one tool board connected and it works fine.
                                  Perhaps there is some as yet undiscovered firmware problem that only manifests with multiple tool boards.
                                  • KevinMarundefined
                                    KevinMar @fcwilt
                                    @fcwilt @dc42
                                    Here's my new, super simple config
                                    M550 P"ToolChanger" 					; Set machine name
                                    M111 S0                              	; Debug off
                                    M929 P"eventlog.txt" S1					; Start logging to file eventlog.txt
                                    M555 P1									; Set RepRap output
                                    G4 S1  									; Wait for expansion boards to start
                                    M307 H2 R2.063 C316.300:132.500 D6.10 S1.00 V24.3 B0
                                    M143 H2 S300
                                    M950 F11 C"21.out2"
                                    M106 P11 S255 H2 T70
                                    M950 F1 C"21.out1"
                                    M563 P1 S"Tool1"  H2 F1
                                    G10  P1 S220 R205
                                    G29 S2
                                    T-1
                                    M501									; Load config-override.g
                                    KevinMarundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                    • KevinMarundefined
                                      KevinMar @KevinMar
                                      boom, fault at 70c
                                      It's most commonly faulting at 70c, which is when my hotend cooling fan is enabled
                                        Phaedrux Moderator @KevinMar
                                        Does that M307 line match what gets loaded by config-override?
                                        • KevinMarundefined
                                          KevinMar @Phaedrux
                                          @phaedrux always
                                            And if you execute M98 P"config.g" does it show any errors?
                                            If you delete config-override.g completely and remove the M307 line entirely from config.g, reboot the board and tune from scratch and save with M500 does it produce the same M307 line?
