    After updating to 3.4.0beta2: faulty heater 1, -273.1C.
    Beta Firmware
    11
    121
    7.3k
      dc42 administrators @CadetC
      Thanks again! test9 is now available.
      Sotidiiundefined CadetCundefined 2 Replies Last reply Reply Quote 0
      • Sotidiiundefined
        Sotidii @dc42
        test9 -Ok
        • CadetCundefined
          CadetC @dc42
          don't know why but test 9 is seen by system as test8
          m122 b121
          Diagnostics for board 121:
          Duet TOOL1LC firmware version 3.3+test8 (2021-08-21 14:00:53)
          Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
            @cadetc thanks, I forgot to update the version number text. The time (14:00) means you have the correct binary. Are the temperature readings OK?
            CadetCundefined 1 Reply Last reply Reply Quote 0
            • CadetCundefined
              CadetC @dc42
              yes -temp OK
                Thanks. Please can you both try file Duet3Firmware_TOOL1LC-34b2+2.bin from https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0.
                PS - I've just updated that file because the version text didn't update.
                Sotidiiundefined CadetCundefined 3 Replies Last reply Reply Quote 0
                • Sotidiiundefined
                  Sotidii @dc42
                  OK!
                  • CadetCundefined
                    CadetC @dc42
                    34b2+2.bin-OK
                    • CadetCundefined
                      CadetC @dc42
                      m122 b121.0
                      Duet TOOL1LC firmware version 3.4.0beta2+2 (2021-08-21 14:16:34)
                        Thanks to both of you. It appears that this bug has gone away as mysteriously as it appeared.
                        • CadetCundefined
                          CadetC @dc42
                          there is definitely a difference between firmware 3.4b2 and 3.4b2+2
                          below is a screen with temperature reading for 3.4b2 and below for 3.4b2+2 -
                          comparison made just now
                          m122 b121.0
                          Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09)
                          m122 b121
                          But all in all, the most important thing is that it's OK now,
                          Thanks
                          • jbarrosundefined
                            jbarros @dc42
                            Thanks!
                            Temps in range with the latest build so I give it Thumbs Up!
                            And again, thank you for your time, dedication and work!
                            • Marshalundefined
                              Marshal
                              Hi all,
                              I updated my printer after vacation and noticed the same issue.
                              I have upped the LC1 to 3.4.0beta2+2 and readings are back within expected range.
                              No recalibration done yet.
                              (I was not sure if there was a toolboard v1 reported or tested with the issue.)
                              Diagnostics for board 20:
                              In Progress CoreXY:
                              • Duet3 6HC
                              • 1 Toolboard LC1
                              • Sergeundefined
                                Serge
                                @dc42 Hello, sorry, i don't have receive notifications from this post that you have make for upgrading the firmwares.
                                I have try the 3.4b2+2 and now, i have the hotend sensor offline.
                                • Sergeundefined
                                  Serge
                                  Sorry for this mystake, i have reboot the Duet3 and now, the hotend sensor is online.
                                  But :
                                  Maybe i have to recalibrate the sensor ? yes or no ?
                                  • Sergeundefined
                                    Serge
                                    After recalibrate the sensor :
                                    But now, stable.
                                    • pixelpieperundefined
                                      pixelpieper @dc42
                                      @dc42 Sorry for not following up further, I am currently on vacation away from my printer, but I am happy to try the builds when I am back in a week if it still makes sense.
                                      Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                                      Voron V0.250 / Duet 2 Maestro
                                        dc42 administrators @pixelpieper
                                        @pixelpieper the problem appears to be solved in firmware 3.4beta3.
