    After updating to 3.4.0beta2: faulty heater 1, -273.1C.
    Beta Firmware
    11
    121
    7.3k
      dc42 administrators @CadetC
      Thanks. Please can you both try file Duet3Firmware_TOOL1LC-34b2+2.bin from https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0.
      PS - I've just updated that file because the version text didn't update.
      Sotidiiundefined CadetCundefined 3 Replies Last reply Reply Quote 0
      • Sotidiiundefined
        Sotidii @dc42
        OK!
        • CadetCundefined
          CadetC @dc42
          34b2+2.bin-OK
          • CadetCundefined
            CadetC @dc42
            m122 b121.0
            Diagnostics for board 121:
            Duet TOOL1LC firmware version 3.4.0beta2+2 (2021-08-21 14:16:34)
              Thanks to both of you. It appears that this bug has gone away as mysteriously as it appeared.
              CadetCundefined 1 Reply Last reply Reply Quote 0
              • CadetCundefined
                CadetC @dc42
                there is definitely a difference between firmware 3.4b2 and 3.4b2+2
                below is a screen with temperature reading for 3.4b2 and below for 3.4b2+2 -
                comparison made just now
                m122 b121.0
                Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09)
                Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                m122 b121
                But all in all, the most important thing is that it's OK now,
                Thanks
                • jbarrosundefined
                  jbarros @dc42
                  Thanks!
                  Temps in range with the latest build so I give it Thumbs Up!
                  And again, thank you for your time, dedication and work!
                  • Marshalundefined
                    Marshal
                    Hi all,
                    I updated my printer after vacation and noticed the same issue.
                    I have upped the LC1 to 3.4.0beta2+2 and readings are back within expected range.
                    No recalibration done yet.
                    (I was not sure if there was a toolboard v1 reported or tested with the issue.)
                    Diagnostics for board 20:
                    In Progress CoreXY:
                    • Duet3 6HC
                    • 1 Toolboard LC1
                    • Sergeundefined
                      Serge
                      @dc42 Hello, sorry, i don't have receive notifications from this post that you have make for upgrading the firmwares.
                      I have try the 3.4b2+2 and now, i have the hotend sensor offline.
                      • Sergeundefined
                        Serge
                        Sorry for this mystake, i have reboot the Duet3 and now, the hotend sensor is online.
                        But :
                        Maybe i have to recalibrate the sensor ? yes or no ?
                        • Sergeundefined
                          Serge
                          After recalibrate the sensor :
                          But now, stable.
                          • pixelpieperundefined
                            pixelpieper @dc42
                            @dc42 Sorry for not following up further, I am currently on vacation away from my printer, but I am happy to try the builds when I am back in a week if it still makes sense.
                            Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                            Voron V0.250 / Duet 2 Maestro
                              dc42 administrators @pixelpieper
                              @pixelpieper the problem appears to be solved in firmware 3.4beta3.
