    After updating to 3.4.0beta2: faulty heater 1, -273.1C.
    Beta Firmware
    11
    121
    7.3k
    • Sotidiiundefined
      Sotidii @dc42
      OK!
      • CadetCundefined
        CadetC @dc42
        34b2+2.bin-OK
        • CadetCundefined
          CadetC @dc42
          m122 b121.0
          Diagnostics for board 121:
          Duet TOOL1LC firmware version 3.4.0beta2+2 (2021-08-21 14:16:34)
            dc42 administrators @CadetC
            Thanks to both of you. It appears that this bug has gone away as mysteriously as it appeared.
            CadetCundefined 1 Reply Last reply Reply Quote 0
            • CadetCundefined
              CadetC @dc42
              there is definitely a difference between firmware 3.4b2 and 3.4b2+2
              below is a screen with temperature reading for 3.4b2 and below for 3.4b2+2 -
              comparison made just now
              m122 b121.0
              Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09)
              Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
              m122 b121
              But all in all, the most important thing is that it's OK now,
              Thanks
              • jbarrosundefined
                jbarros @dc42
                Thanks!
                Temps in range with the latest build so I give it Thumbs Up!
                And again, thank you for your time, dedication and work!
                • Marshalundefined
                  Marshal
                  Hi all,
                  I updated my printer after vacation and noticed the same issue.
                  I have upped the LC1 to 3.4.0beta2+2 and readings are back within expected range.
                  No recalibration done yet.
                  (I was not sure if there was a toolboard v1 reported or tested with the issue.)
                  Diagnostics for board 20:
                  In Progress CoreXY:
                  • Duet3 6HC
                  • 1 Toolboard LC1
                  • Sergeundefined
                    Serge
                    @dc42 Hello, sorry, i don't have receive notifications from this post that you have make for upgrading the firmwares.
                    I have try the 3.4b2+2 and now, i have the hotend sensor offline.
                    • Sergeundefined
                      Serge
                      Sorry for this mystake, i have reboot the Duet3 and now, the hotend sensor is online.
                      But :
                      Maybe i have to recalibrate the sensor ? yes or no ?
                      • Sergeundefined
                        Serge
                        After recalibrate the sensor :
                        But now, stable.
                        • pixelpieperundefined
                          pixelpieper @dc42
                          @dc42 Sorry for not following up further, I am currently on vacation away from my printer, but I am happy to try the builds when I am back in a week if it still makes sense.
                          Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                          Voron V0.250 / Duet 2 Maestro
                            dc42 administrators @pixelpieper
                            @pixelpieper the problem appears to be solved in firmware 3.4beta3.
