    After updating to 3.4.0beta2: faulty heater 1, -273.1C.
    Beta Firmware
    11
    121
    7.5k
    • CadetCundefined
      CadetC @dc42
      34b2+2.bin-OK
      • CadetCundefined
        CadetC @dc42
        m122 b121.0
        Diagnostics for board 121:
        Duet TOOL1LC firmware version 3.4.0beta2+2 (2021-08-21 14:16:34)
          dc42 administrators @CadetC
          Thanks to both of you. It appears that this bug has gone away as mysteriously as it appeared.
          CadetCundefined 1 Reply Last reply Reply Quote 0
          • CadetCundefined
            CadetC @dc42
            there is definitely a difference between firmware 3.4b2 and 3.4b2+2
            below is a screen with temperature reading for 3.4b2 and below for 3.4b2+2 -
            comparison made just now
            m122 b121.0
            Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09)
            Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
            m122 b121
            But all in all, the most important thing is that it's OK now,
            Thanks
            • jbarrosundefined
              jbarros @dc42
              Thanks!
              Temps in range with the latest build so I give it Thumbs Up!
              And again, thank you for your time, dedication and work!
              • Marshalundefined
                Marshal
                Hi all,
                I updated my printer after vacation and noticed the same issue.
                I have upped the LC1 to 3.4.0beta2+2 and readings are back within expected range.
                No recalibration done yet.
                (I was not sure if there was a toolboard v1 reported or tested with the issue.)
                Diagnostics for board 20:
                In Progress CoreXY:
                • Duet3 6HC
                • 1 Toolboard LC1
                • Sergeundefined
                  Serge
                  @dc42 Hello, sorry, i don't have receive notifications from this post that you have make for upgrading the firmwares.
                  I have try the 3.4b2+2 and now, i have the hotend sensor offline.
                  • Sergeundefined
                    Serge
                    Sorry for this mystake, i have reboot the Duet3 and now, the hotend sensor is online.
                    But :
                    Maybe i have to recalibrate the sensor ? yes or no ?
                    • Sergeundefined
                      Serge
                      After recalibrate the sensor :
                      But now, stable.
                      • pixelpieperundefined
                        pixelpieper @dc42
                        @dc42 Sorry for not following up further, I am currently on vacation away from my printer, but I am happy to try the builds when I am back in a week if it still makes sense.
                        Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                        Voron V0.250 / Duet 2 Maestro
                          dc42 administrators @pixelpieper
                          @pixelpieper the problem appears to be solved in firmware 3.4beta3.
