    Duet 2 wifi Error: Cannot initialise SD card 0: Card is unusable
    507
    • tisdaiundefined
      tisdai
      Hi I have been having the same problem as some of the other members here in that no matter what I try I can not get the SD card be recognised. I have tried removing each connector 1 by 1 to see if their was a short but nothing seems to work. Any help with this to try and get it to work will be greatly appreciated.
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @tisdai
        @tisdai that M122 report shows the sd card is detected with a write speed of 12MB/s
          droftarts administrators @tisdai
          @tisdai See https://duet3d.dozuki.com/Wiki/SD_Card#Section_Troubleshooting_SD_Card_issues
          tisdaiundefined 1 Reply Last reply Reply Quote 0
          • tisdaiundefined
            tisdai @droftarts
            @droftarts I have done the SD Test and that was ok. I have tried everything that has been posted about the SD card problems and no matter what I try I can not get it to work. Sorry to bother you like this.
              @tisdai have a look at the SD card socket. See https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_Socket
              Post a picture of the soldering.
              • tisdaiundefined
                tisdai @droftarts
                @droftarts Here you are Ian and thanks for helping
                  @tisdai can’t really see from this angle, need a picture from behind the socket. It’s possible the top right (in your picture) SD card socket pin is not connected.
                  • tisdaiundefined
                    tisdai @droftarts
                    @droftarts Sorry having a problem trying to get it to zoom in using my phone, duet wifi.jpg duet wifi 2.JPG
                      T3P3Tony administrators @tisdai
                      @tisdai what error are you getting with the card not recognised?
                      • tisdaiundefined
                        tisdai @T3P3Tony
                        @t3p3tony With the M39 command I get " Error: No SD card mounted in slot 0 " I have tried 4 different sized cards from 2gig to 16gig and also tried the H2Testw test on the cards and they were ok and when I go to my browser and try to log in all I get is, " Your Duet rejected the HTTP request: page not found
                        Check that the SD card is mounted and has the correct files in its /www folder " I have done the diagnostic and placed it here in the post nothing seems to work.
                        • tisdaiundefined
                          tisdai @tisdai
                          @tisdai Is their anything else I can do to get the board working ok ?
                          • tisdaiundefined
                            tisdai @tisdai
                            @tisdai That looks like a No then, thanks for your replies and trying to help appreciate it.
                              dc42 administrators @tisdai
                              @tisdai when you send M21 over USB or from PanelDue if you have one, what is the response?
                              Is the microcontroller getting hot?
                              • tisdaiundefined
                                tisdai @dc42
                                @dc42 ! No it is not getting hot and I get the same response from 4 different cards I tested them and placed the results here a little earlier in the post all were ok.
                                • tisdaiundefined
                                  tisdai @tisdai
                                  @tisdai Would jumping the erase pins and reinstalling the firmware help in any way, sorry but just trying anything I can think of that might help.
                                    @tisdai if you have a genuine Duet less than one year old then please email warranty@duet3d.com including a link to this thread.
                                    • tisdaiundefined
                                      tisdai @dc42
                                      @dc42 Yes I have a genuine Duet board I would never even consider buying anything else, I have done as you asked.
                                      • tisdaiundefined
                                        tisdai @tisdai
                                        @tisdai Has been sorted by Warranty, Thank you to all who helped me out with this problem. Please mark as solved for me.
