    FILAMENT_RUNOUT_DISTANCE_MM or similar at reprap?
    Firmware wishlist
    1.6k
    • OwenDundefined
      OwenD @OwenD
      Hmmm
      I tried the method I suggested, but it doesn't work.
      Although the macro gets called and the global is set, RRF pauses immediately after filament-error.g is called.
      That is probably deliberate and kind of logical, but renders this method unworkable.
        T3P3Tony administrators @OwenD
        @owend @apak I have asked @dc42 to look at this because I can see the argument for only pausing when a filament-error.g is present if the filament-error contains the explicit pause command.
        dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
          dc42 administrators @T3P3Tony
          @t3p3tony the daemon.g file suggested by OwenD contains an explicit M25 command. That's probably why pause.g is being run.
          @apak what do you mean by "runs x mm of filament"? Do you mean "extrudes x mm of filament"?
          OwenDundefined apakundefined 3 Replies Last reply Reply Quote 0
            T3P3Tony administrators @T3P3Tony
            @OwenD @apak apologies. I missed that M25. Try it without!
            • OwenDundefined
              OwenD @dc42
              @dc42 @T3P3Tony
              The M25 should not be called until the current extruder position exceeds the global variable position set.
              I.e when the filament sensor is tripped, the M25 should not be called until another 200mm of filament has been extruded.
              This allows for the filament between the sensor and the extruder to be used up. On my case that's about 600mm
              At that point a pause is called.
              I'll check again but I'm pretty sure the the code in daemon.g evaluated to false when pause was called.
              EDIT:
              I'm wondering if it's because I have a filament monitor defined using M591, rather than just an external trigger using M581?
              • OwenDundefined
                OwenD @dc42
                @dc42 said in FILAMENT_RUNOUT_DISTANCE_MM or similar at reprap?:
                I just ran a quick test.
                The M25 in daemon.g isn't being called.
                In config.g I have
                ; Filament monitor
                M591 P1 C"e0stop" S1 D0 									; filament monitor for extruder 0 connected to E0 endstop
                In filament-error0.g (and filament-error.g) I have
                ;0:/sys/filament-error#.g
                ; run when filament error for extruder # is found.
                ; if this file not found runs filament-error.g
                ; if neither found runs pause.g
                G4 P10 ; delay 10ms to debounce
                if sensors.filamentMonitors[0].status="ok"
                	echo "switch bounce detected"
                	M99 ; break out if sensor value is zero again (bouncing)
                var runoutDistance = 300 ; this is just so you can change easily
                var thisExtruderValue = move.extruders[tools[state.currentTool].filamentExtruder].position
                set global.filamentDistance = var.thisExtruderValue + var.runoutDistance
                echo "filament-error0.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
                In daemon.g I have
                	if (move.extruders[tools[state.currentTool].filamentExtruder].position > global.filamentDistance)  &&  (global.filamentDistance !=0) && (state.status = "processing")
                		echo "paused called from daemon"
                		M25 ; pause print if filament has run out
                	G4 S2 ; add a delay for these checks
                The console output seems to show the print is paused before filament-error.g is run
                In any case, it's paused before the daemon can do it.
                Here is the extruder position vs the position it should have paused.
                (pause caused a retract)
                OwenDundefined apakundefined 2 Replies Last reply Reply Quote 1
                • OwenDundefined
                  OwenD @OwenD
                  I should also point out that the print paused in the position where the filament sensor tripped
                  It did not move away as I have in pause.g
                  M83            ; relative extruder moves
                  G91		; relative movement
                  G10  ; retract filament
                  G1 Z+5 F600     ; lift Z by 5mm
                  G90            ; absolute positioning
                  G1 X{move.axes[0].min} Y{move.axes[1].max} F6000 ; move bed forward and clear nozzle away
                  ;M144 ; put bed on standby
                  T100 ; Put nozzle in standby
                  • apakundefined
                    apak @dc42
                    @dc42 yes. It´s a direct extruder, but with reversed bowden of 400mm, and at the beginning of the reversed bowden it´s the filament sensor, so It would be nice to extrude at leat 90% of that lenght in order not to waste that filament
                    • apakundefined
                      apak @OwenD
                      @owend Looking at how caribou3d duet handles the sensor
                      https://github.com/Caribou3d/CaribouDuet2Wifi-ConfigurationMacros
                      may be, on trigger we could deactivate sensor, continue printing for var runoutDistance, and then trigger pause, reactivate, load an resume
                        T3P3Tony administrators @apak
                        @apak @OwenD I am working on recreating this issue because it looks like there is a pause happening which should not be happening if the filament-error.g file is present.
                        T3P3Tonyundefined apakundefined 2 Replies Last reply Reply Quote 0
                          I have recreated this - and moved it to firmware wishlist section as the behaviour will need to be changed to allow the filament out logic to run without a pause.
                          OwenDundefined apakundefined DonStaufferundefined 3 Replies Last reply Reply Quote 0
                          • OwenDundefined
                            OwenD @T3P3Tony
                            @t3p3tony
                            Thanks Tony 👍
                            • apakundefined
                              apak @T3P3Tony
                              @t3p3tony thanks
                              • apakundefined
                                apak @T3P3Tony
                                @t3p3tony does this feature have an ETA?
                                  @apak no ETA yet.
                                  • T3P3Tonyundefined T3P3Tony referenced this topic
                                  • DonStaufferundefined
                                    DonStauffer @T3P3Tony
                                    @t3p3tony Tell me if I'm correct:
                                    A workaround should be possible by setting a global variable in filament-error.g if you want to cancel the pause. pause.g checks for the variable, and does an M24 if the variable was set, instead of its usual commands.
                                    Do you think this would work? Or would it skip pause.g if filament-error.g ran, giving you no opportunity to cancel the pause? I'm uncertain whether pause.g gets run or not if filament-error.g exists. I know it's not supposed to.
                                      T3P3Tony administrators @DonStauffer
                                      @donstauffer if filament-error.g runs then pause.g does not run AFAIK. The issue is that there is always a pause as part of the process no matter which macro is called.
                                      DonStaufferundefined 1 Reply Last reply Reply Quote 0
                                        @t3p3tony Confirmed. pause.g doesn't run.
                                        • OwenDundefined
                                          OwenD
                                          Just confirming that this is now possible with 3.4.0b7
                                          Albeit you must be aware that the macro called is now filament_error.g, not filament-error.g
                                          i.e. must have an underscore "_" and not a hyphen "-"
                                          There is also a problem if filament_error.g contains an M291 as described here
                                          filament_error.g
                                          ;0:/sys/filament_error.g
                                          ;run when a filament sensor error is detected.  Print will be paused bt Daemon.g after runout distance.
                                          var runoutDistance = 350 ; this is just so you can change easily
                                          ; first check that we are not currently in an error state and the switch has been toggled again.
                                          if (global.filamentDistance !=0) || !(state.status = "processing")
                                          	echo "Filament sensor triggered, but already no print in progress.  No action taken"
                                          	M99 ; exit macro
                                          echo "filament_error.g run"
                                          	echo "switch bounce detected - error cancelled"
                                          echo {"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D}
                                          ;M291 R"Filament Error" P{"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D} S1 T3
                                          echo "filament_error.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
                                          In daemon.g
                                          (Note this is run in a while loop so it's called at intervals less than 10 seconds)
                                          while true
                                          	; I have a bunch of other stuff in here
                                          	;check the filament runout
                                          	if state.currentTool != -1
                                          			echo "paused called from daemon - filament runout"
                                          In resume.g we reset the distance
                                          	set global.filamentDistance = 0 ; reset filament sensor extrusion distance
                                          ;do all the other stuff needed for resuming
                                          You also need to set the distance to zero in start.g
                                          else
                                          	abort "Filament sensor shows no filament loaded.  Print aborted"
                                          and of course define the global in config.g
                                          if !exists(global.filamentDistance)
                                          	global filamentDistance = 0 ; global for use to allow filament to feed for set distance after sensor trips
                                          else
                                          apakundefined 1 Reply Last reply Reply Quote 2
                                          • apakundefined
                                            apak @OwenD
                                            thanks, will try
                                            MrTwinkysundefined 1 Reply Last reply Reply Quote 0
