    FILAMENT_RUNOUT_DISTANCE_MM or similar at reprap?
    Firmware wishlist
    1.6k
    • OwenDundefined
      OwenD @OwenD
      I should also point out that the print paused in the position where the filament sensor tripped
      It did not move away as I have in pause.g
      M83            ; relative extruder moves
      G91		; relative movement
      G10  ; retract filament
      G1 Z+5 F600     ; lift Z by 5mm
      G90            ; absolute positioning
      G1 X{move.axes[0].min} Y{move.axes[1].max} F6000 ; move bed forward and clear nozzle away
      ;M144 ; put bed on standby
      T100 ; Put nozzle in standby
      • apakundefined
        apak @dc42
        @dc42 yes. It´s a direct extruder, but with reversed bowden of 400mm, and at the beginning of the reversed bowden it´s the filament sensor, so It would be nice to extrude at leat 90% of that lenght in order not to waste that filament
        • apakundefined
          apak @OwenD
          @owend Looking at how caribou3d duet handles the sensor
          https://github.com/Caribou3d/CaribouDuet2Wifi-ConfigurationMacros
          may be, on trigger we could deactivate sensor, continue printing for var runoutDistance, and then trigger pause, reactivate, load an resume
            T3P3Tony administrators @apak
            @apak @OwenD I am working on recreating this issue because it looks like there is a pause happening which should not be happening if the filament-error.g file is present.
            T3P3Tonyundefined apakundefined 2 Replies Last reply Reply Quote 0
              T3P3Tony administrators @T3P3Tony
              I have recreated this - and moved it to firmware wishlist section as the behaviour will need to be changed to allow the filament out logic to run without a pause.
              OwenDundefined apakundefined DonStaufferundefined 3 Replies Last reply Reply Quote 0
              • OwenDundefined
                OwenD @T3P3Tony
                @t3p3tony
                Thanks Tony 👍
                • apakundefined
                  apak @T3P3Tony
                  @t3p3tony thanks
                  • apakundefined
                    apak @T3P3Tony
                    @t3p3tony does this feature have an ETA?
                      @apak no ETA yet.
                      • T3P3Tonyundefined T3P3Tony referenced this topic
                      • DonStaufferundefined
                        DonStauffer @T3P3Tony
                        @t3p3tony Tell me if I'm correct:
                        A workaround should be possible by setting a global variable in filament-error.g if you want to cancel the pause. pause.g checks for the variable, and does an M24 if the variable was set, instead of its usual commands.
                        Do you think this would work? Or would it skip pause.g if filament-error.g ran, giving you no opportunity to cancel the pause? I'm uncertain whether pause.g gets run or not if filament-error.g exists. I know it's not supposed to.
                          T3P3Tony administrators @DonStauffer
                          @donstauffer if filament-error.g runs then pause.g does not run AFAIK. The issue is that there is always a pause as part of the process no matter which macro is called.
                          DonStaufferundefined 1 Reply Last reply Reply Quote 0
                            @t3p3tony Confirmed. pause.g doesn't run.
                            • OwenDundefined
                              OwenD
                              Just confirming that this is now possible with 3.4.0b7
                              Albeit you must be aware that the macro called is now filament_error.g, not filament-error.g
                              i.e. must have an underscore "_" and not a hyphen "-"
                              There is also a problem if filament_error.g contains an M291 as described here
                              filament_error.g
                              ;0:/sys/filament_error.g
                              ;run when a filament sensor error is detected.  Print will be paused bt Daemon.g after runout distance.
                              var runoutDistance = 350 ; this is just so you can change easily
                              ; first check that we are not currently in an error state and the switch has been toggled again.
                              if (global.filamentDistance !=0) || !(state.status = "processing")
                              	echo "Filament sensor triggered, but already no print in progress.  No action taken"
                              	M99 ; exit macro
                              echo "filament_error.g run"
                              G4 P10 ; delay 10ms to debounce
                              if sensors.filamentMonitors[0].status="ok"
                              	echo "switch bounce detected - error cancelled"
                              	M99 ; break out if sensor value is zero again (bouncing)
                              echo {"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D}
                              ;M291 R"Filament Error" P{"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D} S1 T3
                              var thisExtruderValue = move.extruders[tools[state.currentTool].filamentExtruder].position
                              set global.filamentDistance = var.thisExtruderValue + var.runoutDistance
                              echo "filament_error.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
                              In daemon.g
                              (Note this is run in a while loop so it's called at intervals less than 10 seconds)
                              while true
                              	; I have a bunch of other stuff in here
                              	;check the filament runout
                              	if state.currentTool != -1
                              		if (move.extruders[tools[state.currentTool].filamentExtruder].position > global.filamentDistance)  &&  (global.filamentDistance !=0) && (state.status = "processing")
                              			echo "paused called from daemon - filament runout"
                              			M25 ; pause print if filament has run out
                              	G4 S2 ; add a delay for these checks
                              In resume.g we reset the distance
                              	set global.filamentDistance = 0 ; reset filament sensor extrusion distance
                              ;do all the other stuff needed for resuming
                              You also need to set the distance to zero in start.g
                              else
                              	abort "Filament sensor shows no filament loaded.  Print aborted"
                              and of course define the global in config.g
                              if !exists(global.filamentDistance)
                              	global filamentDistance = 0 ; global for use to allow filament to feed for set distance after sensor trips
                              else
                              apakundefined 1 Reply Last reply Reply Quote 2
                              • apakundefined
                                apak @OwenD
                                thanks, will try
                                MrTwinkysundefined 1 Reply Last reply Reply Quote 0
                                • apakundefined
                                  apak
                                  This post is deleted!
                                  • MrTwinkysundefined
                                    MrTwinkys @apak
                                    @apak any word on whether or not this is functioning correctly? I would like to set this up for a reverse Bowden setup also.
                                    • selva_tviundefined selva_tvi referenced this topic
