    FILAMENT_RUNOUT_DISTANCE_MM or similar at reprap?
    Firmware wishlist
    1.6k
      T3P3Tony administrators @T3P3Tony
      @OwenD @apak apologies. I missed that M25. Try it without!
      • OwenDundefined
        OwenD @dc42
        @dc42 @T3P3Tony
        The M25 should not be called until the current extruder position exceeds the global variable position set.
        I.e when the filament sensor is tripped, the M25 should not be called until another 200mm of filament has been extruded.
        This allows for the filament between the sensor and the extruder to be used up. On my case that's about 600mm
        At that point a pause is called.
        I'll check again but I'm pretty sure the the code in daemon.g evaluated to false when pause was called.
        EDIT:
        I'm wondering if it's because I have a filament monitor defined using M591, rather than just an external trigger using M581?
        • OwenDundefined
          OwenD @dc42
          @dc42 said in FILAMENT_RUNOUT_DISTANCE_MM or similar at reprap?:
          @t3p3tony the daemon.g file suggested by OwenD contains an explicit M25 command. That's probably why pause.g is being run.
          I just ran a quick test.
          The M25 in daemon.g isn't being called.
          In config.g I have
          ; Filament monitor
          M591 P1 C"e0stop" S1 D0 									; filament monitor for extruder 0 connected to E0 endstop
          In filament-error0.g (and filament-error.g) I have
          ;0:/sys/filament-error#.g
          ; run when filament error for extruder # is found.
          ; if this file not found runs filament-error.g
          ; if neither found runs pause.g
          G4 P10 ; delay 10ms to debounce
          if sensors.filamentMonitors[0].status="ok"
          	echo "switch bounce detected"
          	M99 ; break out if sensor value is zero again (bouncing)
          var runoutDistance = 300 ; this is just so you can change easily
          var thisExtruderValue = move.extruders[tools[state.currentTool].filamentExtruder].position
          set global.filamentDistance = var.thisExtruderValue + var.runoutDistance
          echo "filament-error0.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
          In daemon.g I have
          	if (move.extruders[tools[state.currentTool].filamentExtruder].position > global.filamentDistance)  &&  (global.filamentDistance !=0) && (state.status = "processing")
          		echo "paused called from daemon"
          		M25 ; pause print if filament has run out
          	G4 S2 ; add a delay for these checks
          The console output seems to show the print is paused before filament-error.g is run
          In any case, it's paused before the daemon can do it.
          Here is the extruder position vs the position it should have paused.
          (pause caused a retract)
          OwenDundefined apakundefined 2 Replies Last reply Reply Quote 1
          • OwenDundefined
            OwenD @OwenD
            I should also point out that the print paused in the position where the filament sensor tripped
            It did not move away as I have in pause.g
            M83            ; relative extruder moves
            G91		; relative movement
            G10  ; retract filament
            G1 Z+5 F600     ; lift Z by 5mm
            G90            ; absolute positioning
            G1 X{move.axes[0].min} Y{move.axes[1].max} F6000 ; move bed forward and clear nozzle away
            ;M144 ; put bed on standby
            T100 ; Put nozzle in standby
            • apakundefined
              apak @dc42
              @dc42 yes. It´s a direct extruder, but with reversed bowden of 400mm, and at the beginning of the reversed bowden it´s the filament sensor, so It would be nice to extrude at leat 90% of that lenght in order not to waste that filament
              • apakundefined
                apak @OwenD
                @owend Looking at how caribou3d duet handles the sensor
                https://github.com/Caribou3d/CaribouDuet2Wifi-ConfigurationMacros
                may be, on trigger we could deactivate sensor, continue printing for var runoutDistance, and then trigger pause, reactivate, load an resume
                  T3P3Tony administrators @apak
                  @apak @OwenD I am working on recreating this issue because it looks like there is a pause happening which should not be happening if the filament-error.g file is present.
                  T3P3Tonyundefined apakundefined 2 Replies Last reply Reply Quote 0
                    I have recreated this - and moved it to firmware wishlist section as the behaviour will need to be changed to allow the filament out logic to run without a pause.
                    OwenDundefined apakundefined DonStaufferundefined 3 Replies Last reply Reply Quote 0
                    • OwenDundefined
                      OwenD @T3P3Tony
                      @t3p3tony
                      Thanks Tony 👍
                      • apakundefined
                        apak @T3P3Tony
                        @t3p3tony thanks
                        • apakundefined
                          apak @T3P3Tony
                          @t3p3tony does this feature have an ETA?
                            @apak no ETA yet.
                            • T3P3Tonyundefined T3P3Tony referenced this topic
                            • DonStaufferundefined
                              DonStauffer @T3P3Tony
                              @t3p3tony Tell me if I'm correct:
                              A workaround should be possible by setting a global variable in filament-error.g if you want to cancel the pause. pause.g checks for the variable, and does an M24 if the variable was set, instead of its usual commands.
                              Do you think this would work? Or would it skip pause.g if filament-error.g ran, giving you no opportunity to cancel the pause? I'm uncertain whether pause.g gets run or not if filament-error.g exists. I know it's not supposed to.
                                T3P3Tony administrators @DonStauffer
                                @donstauffer if filament-error.g runs then pause.g does not run AFAIK. The issue is that there is always a pause as part of the process no matter which macro is called.
                                DonStaufferundefined 1 Reply Last reply Reply Quote 0
                                  @t3p3tony Confirmed. pause.g doesn't run.
                                  • OwenDundefined
                                    OwenD
                                    Just confirming that this is now possible with 3.4.0b7
                                    Albeit you must be aware that the macro called is now filament_error.g, not filament-error.g
                                    i.e. must have an underscore "_" and not a hyphen "-"
                                    There is also a problem if filament_error.g contains an M291 as described here
                                    filament_error.g
                                    ;0:/sys/filament_error.g
                                    ;run when a filament sensor error is detected.  Print will be paused bt Daemon.g after runout distance.
                                    var runoutDistance = 350 ; this is just so you can change easily
                                    ; first check that we are not currently in an error state and the switch has been toggled again.
                                    if (global.filamentDistance !=0) || !(state.status = "processing")
                                    	echo "Filament sensor triggered, but already no print in progress.  No action taken"
                                    	M99 ; exit macro
                                    echo "filament_error.g run"
                                    	echo "switch bounce detected - error cancelled"
                                    echo {"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D}
                                    ;M291 R"Filament Error" P{"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D} S1 T3
                                    echo "filament_error.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
                                    In daemon.g
                                    (Note this is run in a while loop so it's called at intervals less than 10 seconds)
                                    while true
                                    	; I have a bunch of other stuff in here
                                    	;check the filament runout
                                    	if state.currentTool != -1
                                    			echo "paused called from daemon - filament runout"
                                    In resume.g we reset the distance
                                    	set global.filamentDistance = 0 ; reset filament sensor extrusion distance
                                    ;do all the other stuff needed for resuming
                                    You also need to set the distance to zero in start.g
                                    else
                                    	abort "Filament sensor shows no filament loaded.  Print aborted"
                                    and of course define the global in config.g
                                    if !exists(global.filamentDistance)
                                    	global filamentDistance = 0 ; global for use to allow filament to feed for set distance after sensor trips
                                    else
                                    apakundefined 1 Reply Last reply Reply Quote 2
                                    • apakundefined
                                      apak @OwenD
                                      thanks, will try
                                      MrTwinkysundefined 1 Reply Last reply Reply Quote 0
                                      • apakundefined
                                        apak
                                        This post is deleted!
                                        • MrTwinkysundefined
                                          MrTwinkys @apak
                                          @apak any word on whether or not this is functioning correctly? I would like to set this up for a reverse Bowden setup also.
                                          • selva_tviundefined selva_tvi referenced this topic
