    output problem
    614
    • tom33undefined
      tom33 @jay_s_uk
      @jay_s_uk
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.4 on Wed Oct 13 2021 14:06:51 GMT+0200 (heure d’été d’Europe centrale)
      M550 P"ISA" ; set printer name
      M552 P192.168.1.70 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0.0 goes forwards
      M569 P1 S0 ; physical drive 0.1 goes forwards
      M569 P2 S1 ; physical drive 0.1 goes forwards
      M569 P3 S1 ; physical drive 0.3 goes forwards
      M569 P4 S1 ; physical drive 0.1 goes forwards
      M569 P5 S1 ; physical drive 0.5 goes forwards
      ;M569.7 P3 C"out8" ; driver 0 on board 40 uses port out1 on board 40 to control the brake
      M584 X0 Y1:2 V2 Z3 W4 E5 ; set drive mapping M584 X0.0 Y0.1:0.2 V0.2 Z0.3:0.4 W0.4 E0.5
      M350 X16 Y16 V16 Z16 W16 E16 I1 ; configure microstepping with interpolation
      M92 X320.00 Y640.00 V640.00 Z640.00 W640.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 V900.00 Z60.00 W60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 V6000.00 Z180.00 W180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 V500.00 Z20.00 W20.00 E250.00 ; set accelerations (mm/s^2)
      M906 X2800 Y2800 V2800 Z2800 W2800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X1000 Y500 Z400 S0 ; set axis maxima
      M574 X2 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
      M574 Y2 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
      M574 Z2 S1 P"!io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io3.in
      M558 P5 C"!io4.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
      M557 X15:950 Y15:450 S50 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out3" T0 ; create bed heater output on out0 and map it to sensor 0
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M563 P0 S"E0" D0 H1 F0 ; define tool 0
      ;Input
      M950 J0 C"io0.in" ; Arret d'urgence
      M581 T0 P0 S1 R0 ; T0 --> M112 Arret d'urgence
      M950 P0 C"out8"
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      ;T0 ; select first tool
        T3P3Tony administrators @tom33
        @tom33 what commands are you sending that do not work?
        tom33undefined 1 Reply Last reply Reply Quote 0
        • tom33undefined
          tom33 @T3P3Tony
          @t3p3tony
          M42 P0 S1
          Even if I create an output on out0, out1,… the led doesn’t light up
            @tom33 which LED? please show how you are wiring it.
            tom33undefined 2 Replies Last reply Reply Quote 0
            • tom33undefined
              tom33 @T3P3Tony
              @t3p3tony LED.jpg this led
              • tom33undefined
                tom33 @T3P3Tony
                @t3p3tony
                When I turn on the output nothing append
                  jay_s_uk @tom33
                  @tom33 if you have nothing connected it won't turn on
                  • tom33undefined
                    tom33 @jay_s_uk
                    @jay_s_uk even if nothing is wired the led turned on, I tried with another duet 3 and the same config
                      @tom33 Thanks, no I understand what you mean. Just to make 1005 sure we are on the same page, you can't control a heater with M42 if you have already mapped it to a heater. Can you send the following (with nothing plugged into out2 and out2 not used in the config.g
                      M950 P20 C"out2"
                      M42 P20 S1 ; LED on out 2 should come on
                      M42 P20 S0 ; LED on out 2 should go off
                      • tom33undefined
                        tom33 @T3P3Tony
                        @t3p3tony said in output problem:
                        M950 P20 C"out2"
                        I tried and nothing append, the problem is just with the output because I can run the motor for exemple...
                          @tom33 thanks for confirming that. It looks like this impacts multiple outputs. Can you test Out0 to see if the LED lights on that please.
                          • tom33undefined
                            tom33 @T3P3Tony
                            @t3p3tony The same with out0. I think the problem come from the board because I tried the same config.g in another duet3 3
                              @tom33 thanks for bearing with the testing. please can you contact warrant@duet3d.com to initiate a warranty return, referencing this forum post.
