output problem
586
    T3P3Tony administrators @tom33
    @tom33 what commands are you sending that do not work?
    undefined 1 Reply Last reply 18 Oct 2021, 17:31 Reply Quote 0
      tom33 @T3P3Tony
      @t3p3tony
      M42 P0 S1
      Even if I create an output on out0, out1,… the led doesn’t light up
      undefined 1 Reply Last reply 18 Oct 2021, 18:36 Reply Quote 0
        @tom33 which LED? please show how you are wiring it.
        undefined 2 Replies Last reply 20 Oct 2021, 06:34 Reply Quote 0
          tom33 @T3P3Tony
          @t3p3tony LED.jpg this led
            tom33 @T3P3Tony
            @t3p3tony
            When I turn on the output nothing append
            undefined 1 Reply Last reply 20 Oct 2021, 06:46 Reply Quote 0
              jay_s_uk @tom33
              @tom33 if you have nothing connected it won't turn on
              undefined 1 Reply Last reply 20 Oct 2021, 06:49 Reply Quote 0
                tom33 @jay_s_uk
                @jay_s_uk even if nothing is wired the led turned on, I tried with another duet 3 and the same config
                undefined 1 Reply Last reply 20 Oct 2021, 11:05 Reply Quote 1
                  @tom33 Thanks, no I understand what you mean. Just to make 1005 sure we are on the same page, you can't control a heater with M42 if you have already mapped it to a heater. Can you send the following (with nothing plugged into out2 and out2 not used in the config.g
                  M950 P20 C"out2"
                  M42 P20 S1 ; LED on out 2 should come on
                  M42 P20 S0 ; LED on out 2 should go off
                  undefined 1 Reply Last reply 21 Oct 2021, 12:23 Reply Quote 0
                    tom33 @T3P3Tony
                    @t3p3tony said in output problem:
                    M950 P20 C"out2"
                    I tried and nothing append, the problem is just with the output because I can run the motor for exemple...
                    undefined 1 Reply Last reply 21 Oct 2021, 12:33 Reply Quote 0
                      @tom33 thanks for confirming that. It looks like this impacts multiple outputs. Can you test Out0 to see if the LED lights on that please.
                      undefined 1 Reply Last reply 21 Oct 2021, 13:49 Reply Quote 0
                        tom33 @T3P3Tony
                        @t3p3tony The same with out0. I think the problem come from the board because I tried the same config.g in another duet3 3
                        undefined 1 Reply Last reply 21 Oct 2021, 14:00 Reply Quote 0
                          @tom33 thanks for bearing with the testing. please can you contact warrant@duet3d.com to initiate a warranty return, referencing this forum post.
                          13 out of 15
