    output problem
    586
      T3P3Tony administrators @tom33
      @tom33 which LED? please show how you are wiring it.
      tom33undefined 2 Replies Last reply Reply Quote 0
      • tom33undefined
        tom33 @T3P3Tony
        @t3p3tony LED.jpg this led
        • tom33undefined
          tom33 @T3P3Tony
          @t3p3tony
          When I turn on the output nothing append
            jay_s_uk @tom33
            @tom33 if you have nothing connected it won't turn on
            tom33undefined 1 Reply Last reply Reply Quote 0
            • tom33undefined
              tom33 @jay_s_uk
              @jay_s_uk even if nothing is wired the led turned on, I tried with another duet 3 and the same config
                @tom33 Thanks, no I understand what you mean. Just to make 1005 sure we are on the same page, you can't control a heater with M42 if you have already mapped it to a heater. Can you send the following (with nothing plugged into out2 and out2 not used in the config.g
                M950 P20 C"out2"
                M42 P20 S1 ; LED on out 2 should come on
                M42 P20 S0 ; LED on out 2 should go off
                • tom33undefined
                  tom33 @T3P3Tony
                  @t3p3tony said in output problem:
                  M950 P20 C"out2"
                  I tried and nothing append, the problem is just with the output because I can run the motor for exemple...
                    @tom33 thanks for confirming that. It looks like this impacts multiple outputs. Can you test Out0 to see if the LED lights on that please.
                    • tom33undefined
                      tom33 @T3P3Tony
                      @t3p3tony The same with out0. I think the problem come from the board because I tried the same config.g in another duet3 3
                        @tom33 thanks for bearing with the testing. please can you contact warrant@duet3d.com to initiate a warranty return, referencing this forum post.
