    Pressure advance tuning with conditional G-code
    Gcode meta commands
    11
    43
    3.3k
      T3P3Tony administrators @Schmart
      This is really very cool. Its awesome to see the concept of gcode meta commands used in this way. I have logged the wishlist items.
      @schmart said in Pressure advance tuning with conditional G-code:
      The code didn't look right when it contains words like "doesn't" and "haven't" in comments. This results in random "{0}" inserted and illegal G-code.
      I can't reproduce this in the latest build. I took a very cutdown version of your original macro posted with the ; doesn't comment and a few more lines and running that did not throw any errors.
      o_lampeundefined Schmartundefined 2 Replies Last reply Reply Quote 1
      • o_lampeundefined
        o_lampe @T3P3Tony
        @t3p3tony Do you both talk about the code-window of the forum? Just have to add " ```perl" in the first line
          T3P3Tony administrators @o_lampe
          @o_lampe I assumed @Schmart was referring to the gcode parsed by RRF (which should throw out all the comments, no matter what they contain)
          Schmartundefined 1 Reply Last reply Reply Quote 0
          • Schmartundefined
            Schmart @T3P3Tony
            @t3p3tony Apologies, I was indeed referring to the markdown representation of G-code in the forum. Fortunately, the firmware itself handles comments with single quotes without any issue. @o_lampe I wasn't aware of the 'perl' option, I will try this when I'm back home!
            Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
            Schmartundefined 1 Reply Last reply Reply Quote 1
            • Schmartundefined
              Schmart @Schmart
              @o_lampe @T3P3Tony Tried the 'perl' code block in the markdown of my original post, and changed line 100 briefly to contain "haven't" instead of "have not". But the result doesn't look better then.
              Also in the fragments below the rendering issue can be reproduced; notice the "{1}" at line 11.
              ; Make an inventory of axes that haven't yet been homed
               var axes = ""
               echo "Total number of axes: " ^ {#move.axes}
               while {iterations < #move.axes}
                 if {!move.axes[iterations].homed}
                   set var.axes = {var.axes ^ move.axes[iterations].letter}
               ; Home applicable axes
               echo "Axes to be homed: " ^ var.axes
               G28 {var.axes}
              Versus the exact same perl code block with "have not":
              ; Make an inventory of axes that have not yet been homed
               var axes = ""
               G28 {var.axes}
              • Schmartundefined
                Schmart @T3P3Tony
                @t3p3tony said in Pressure advance tuning with conditional G-code:
                Thank you for that, by the way! 👍❤️
                  This post is deleted!
                    T3P3Tony administrators @T3P3Tony
                    @t3p3tony
                    ok so with perl:
                     var axes = ""
                     G28 {var.axes}
                    without perl
                     var axes = ""
                     G28 {var.axes}
                      so i can't recreate it with that snippet is if use no specified syntax highlighting.
                      • Schmartundefined
                        Schmart @T3P3Tony
                        @t3p3tony Editing on my phone is terrible because I can't get out of preview mode anymore, but I've managed to put the entire code in a code block without specifying any language, and changed line 100 to use "haven't". Then on line 106, 110, 114 and 117, I'm spotting some issues.
                        ; This macro generates a test print to determine the best pressure advance factor (M572 S-parameter)
                        ; It uses the test print described in this forum post:
                        ; https://forum.duet3d.com/topic/6698/pressure-advance-calibration
                        ; Author: Schmart
                        ; WARNING: all dimensions, size units and speeds are in mm and mm/s
                        ; Reference for conditional G-code:
                        ; - https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
                        ; Wishes for conditional G-code:
                        ; - Canceling or stopping running conditional G-code
                        ; - Simulation; logging what commands would be executed/generated without actually executing them
                        ; - Dumping the variables (names and values) in a macro, perhaps also treating variable in a meta-way, e.g. {#var} for count, {var[0].name} and {var['layer_height'].value}
                        ; - Assigning an object or array to a variable. E.g. var axis = move.axes[0]; echo {var.axis.letter}
                        ; - Custom subroutine/function definition, e.g. def print_line(var a, var b)
                        ; - ceiling(), pow() and sq() functions
                        ; TODO:
                        ; - Many optimizations still remaining
                        ; - Perhaps the most important variables (bed and print temperature, filament diameter, extrusion multiplier, PA stepping)
                        ;   can be made into macro parameters, e.g. M98 P"0:/macros/4 - Print Tuning/Pressure Advance" B40 P204 D1.75 X0.95 S0.02 P0.002
                        ; Starting value for pressure advance
                        var pa_start = 0.0
                        ; Pressure advance increment for each (whole) millimeter print height
                        ; e.g. if var.height = 20, var.pa_start = 0.1 and var.pa_stepping = 0.004, then
                        ; the PA test range is from 0.1 to (0.1 + 20 * 0.004) => 0.1 to 0.18.
                        var pa_stepping = 0.01
                        ; The extruder to apply the pressure advance factor to
                        var pa_extruder = 0
                        ; These values specify the center of the print bed
                        ; The default bed center is at (0,0)
                        var x_center = 0
                        var y_center = 0
                        ; Print temperatures
                        var print_temperature = 205
                        var standby_temperature = 120
                        var bed_temperature = 40
                        ; Height of the test print
                        var height = 20
                        var layer_height = 0.20
                        ; Number of fast segments
                        var fast_segments = 3
                        ; Slow segments are at the beginning and the end, and in between fast segments, e.g. SLOW FAST SLOW FAST SLOW
                        var slow_segment_length = 10
                        var fast_segment_length = 20
                        ; Definition of speeds
                        var first_layer_speed = 20
                        var travel_speed = 80
                        var fast_segment_speed = 60
                        var slow_segment_speed = 10
                        ; Number of perimeters around the object as a stable base
                        var skirt_loops = 6
                        ; Height of the skirt in layers
                        var skirt_layers = 2
                        ; The tool number to print with
                        var tool_number = 0
                        ; Extrusion width is calculated here, but can also be set with a literal value
                        ; Note that 1.05 and 1.125 are common factors that result in 0.42mm or 0.45mm width respectively
                        var nozzle_bore_diameter = 0.40
                        var extrusion_width = {var.nozzle_bore_diameter * 1.125}
                        var filament_diameter = 1.78
                        var extrusion_multiplier = 0.93
                        ; Firmware retraction settings
                        var retract_length = 0.5
                        var retract_restart_length = 0
                        var retract_speed = 40
                        var deretract_speed = 40
                        var retract_z_lift = 0
                        ; Flow math
                        var filament_flow = {pi * var.filament_diameter * var.filament_diameter / 4}
                        var regular_flow = {(var.extrusion_width - var.layer_height) * var.layer_height + pi * var.layer_height * var.layer_height / 4}
                        var bridge_flow = {pi * var.nozzle_bore_diameter * var.nozzle_bore_diameter / 4}
                        var line_spacing = {var.extrusion_width - var.layer_height * (1 - pi / 4)}
                        var regular_flow_ratio = { var.extrusion_multiplier * var.regular_flow / var.filament_flow}
                        var purge_line_flow_ratio = { 2.0 * var.regular_flow_ratio }
                        echo "extrusion_width: " ^ var.extrusion_width
                        echo "layer_height: " ^ var.layer_height
                        echo "filament_flow: " ^ var.filament_flow
                        echo "bridge_flow: " ^ var.bridge_flow
                        echo "regular_flow: " ^ var.regular_flow
                        echo "line_spacing: " ^ var.line_spacing
                        echo "regular_flow_ratio: " ^ var.regular_flow_ratio
                        ;M37 S1 ; Enter simulation mode
                        ; Set firmware retraction
                        M207 S{var.retract_length} R{var.retract_restart_length} F{60 * var.retract_speed} T{60 * var.deretract_speed} Z{var.retract_z_lift}
                        T{var.tool_number} ; Select tool
                        M106 S0 ; Turn off part cooling fan
                        M568 P{var.tool_number} S{var.print_temperature} R{var.standby_temperature} A1 ; Set tool to standby temperature
                        M190 S{var.bed_temperature} ; Wait for bed temperature to reach setpoint
                        M116 P{var.tool_number} ; Wait for temperatures associated with the selected tool to be reached
                        var axes = ""
                        G28 {var.axes}
                        ;G28 XYZ ; Home the X, Y and Z axes
                        ;G28 XY ; Home the X and Y axes
                        ;G28 Z ; Home the Z axis
                        G21 ; Set units to millimeters
                        M83 ; Use relative distances for extrusion
                        ; Calculate object width
                        var width = {var.fast_segments * var.fast_segment_length + (1 + var.fast_segments) * var.slow_segment_length}
                        ; Calculate starting coordinates and other constant(s)
                        var x_start = {var.x_center - 0.5 * var.width + var.skirt_loops * var.line_spacing}
                        var y_start = {var.y_center - 0.5 * var.line_spacing + var.skirt_loops * var.line_spacing}
                        var travel_feedrate = {60 * var.travel_speed}
                        var first_layer_feedrate = {60 * var.first_layer_speed}
                        ; Absolute position for purge line in X and Y space, 50 mm behind model
                        G90 ; Use absolute coordinates
                        G1 X{var.x_start} Y{var.y_start + 50} F{var.travel_feedrate}
                        ; Set heater to final temperature and wait
                        M568 A2
                        ; Absolute position of nozzle at first layer height
                        G1 Z{var.layer_height} F{var.travel_feedrate}
                        ; Relatively print two fat purge lines
                        G91 ; Switch to relative coordinates
                        G1 X{var.width} E{var.width * var.purge_line_flow_ratio} F{var.first_layer_feedrate}
                        G1 Y{-(2 * var.line_spacing)} F{var.travel_feedrate}
                        G1 X{-var.width} E{var.width * var.purge_line_flow_ratio} F{var.first_layer_feedrate}
                        G10 ; Retract to prevent oozing
                        ; Move to the start of the model in X, Y and Z space
                        ; The skirt code also moves to the start, but the skirt can be disabled.
                        ; Also, the skirt code does not set Z, and there may be no purge line for which Z is set. Safety first.
                        G1 X{var.x_start} Y{var.y_start} Z{var.layer_height} F{var.travel_feedrate}
                        G11 ; Advance/unretract/deretract in preparation to print
                        ; Routine for printing the test object
                        var layers = {floor(var.height / var.layer_height)}
                        echo "Total number of layers: " ^ var.layers
                        while {iterations < var.layers}
                          ; Track current layer
                          var layer = {iterations + 1}
                          ; Current height in mm
                          var z = {var.layer * var.layer_height}
                          ; Calculate pressure advance factor
                          var pa = {var.pa_start + floor(var.z) * var.pa_stepping}
                          ; Set pressure advance
                          M572 D{var.pa_extruder} S{var.pa}
                          ; Output some statistics while printing
                          echo "Layer " ^ iterations ^ " (" ^ {iterations + 1} ^ " of " ^ {var.layers} ^ " at " ^ {var.z} ^ "mm)"
                          echo "Pressure advance: " ^ {var.pa}
                          ; Pre-calculate feedrates for first layer and other layers
                          var slow_segment_feedrate = {60 * (var.layer == 1 ? var.first_layer_speed : var.slow_segment_speed)}
                          var fast_segment_feedrate = {60 * (var.layer == 1 ? var.first_layer_speed : var.fast_segment_speed)}
                          ; Print skirt
                          if {iterations < var.skirt_layers}
                            ; Move to absolute XY start coordinates
                            G1 X{var.x_start} Y{var.y_start} F{var.travel_feedrate}
                            ; Print all loops of the skirt
                            while {iterations < var.skirt_loops}
                              var skirt_loop = {var.skirt_loops - iterations}
                              var x = {var.width + 2 * var.skirt_loop * var.line_spacing}
                              var y = {var.line_spacing + 2 * var.skirt_loop * var.line_spacing}
                              ; Print one full skirt loop
                              while iterations < 2
                                var direction = {iterations == 0 ? 1 : -1}
                                G1 X{var.direction * var.x} E{var.x * var.regular_flow_ratio} F{var.fast_segment_feedrate}
                                G1 Y{var.direction * var.y} E{var.y * var.regular_flow_ratio} F{var.fast_segment_feedrate}
                              ; Travel to the start of the next skirt loop
                              G1 X{var.line_spacing} Y{var.line_spacing} F{var.travel_feedrate}
                          ; Print two perimeters back and forth of alternating slow and fast segments
                            ; Slow starting segment (X)
                            G1 X{var.direction * var.slow_segment_length} E{var.slow_segment_length * var.regular_flow_ratio} F{var.slow_segment_feedrate}
                            ; Remaining fast and slow segments (X)
                            while iterations < var.fast_segments
                              G1 X{var.direction * var.fast_segment_length} E{var.fast_segment_length * var.regular_flow_ratio} F{var.fast_segment_feedrate}
                            ; Print the side perimeter (Y)
                            G1 Y{var.direction * var.line_spacing} E{var.line_spacing * var.regular_flow_ratio} F{var.slow_segment_feedrate}
                          ; Move one layer up
                        G10 ; Retract
                        G91 ; Relative positioning
                        G1 F3000 Z20 ; Move gantry up 20mm
                        G90 ; Absolute positioning
                        G28 X ; Home X axis
                        ;M104 S0 ; Turn off nozzle heat block
                        M568 P{var.tool_number} S0 R0 A2 ; Set required heater temperature off
                        M140 S0 ; Turn off bed
                        M18 ; Disable stepper motors
                        ;M37 S0 ; Leave simulation mode
                          @schmart ok thanks. its obviously dependent on both the syntax used and the other lines.
                          OwenDundefined 1 Reply Last reply Reply Quote 1
                          • OwenDundefined
                            OwenD @T3P3Tony
                            @t3p3tony
                            Nice work! @Schmart
                            The forum highlighting problem is long standing
                            https://forum.duet3d.com/post/225020
                            Sometimes you need yo try a few different language formats to get one that works.
                            Try python, bash, Java, json, pascal etc
                            • Heartleander81undefined
                              Heartleander81
                              Hi. I test this today but I become with the duet3 6c Board and tool board 1lc in sbc Modus a error.
                              What can I Do?
                              I have test it with .g and .gcode and as Macro
                              With macro I become a another error Code
                              • izemanundefined
                                izeman
                                I wanted to try the code as well, and it doesn't seem to work as expected. The nozzle and bed heat up, and then the heater is turned off again as it starts printing it seems.
                                Schmartundefined 2 Replies Last reply Reply Quote 0
                                • Schmartundefined
                                  Schmart @Heartleander81
                                  @heartleander81 As far as I know, the conditional G-code works in a macro only, not in a .gcode file.
                                  The second problem I suspect is a copy error. Conditional G-code is indentation sensitive; with indented text (consistently using either spaces or tabs) you essentially define the sections that run conditionally or in a loop.
                                  In other errors I spot that the word line in purge_line_flow_ratio was somehow replaced with the line numbers 139 and 141 the variable is used on, so perhaps something's going wrong in the process of copying the text from the forum post into the macro editor.
                                  I've just copied the code from the first post again in my editor (VS Code) and performed a difference/diff/compare with the code in my actual printer to verify that the code in this post is sound. There's no differences that explain what I'm seeing on your end 😞
                                  Heartleander81undefined 1 Reply Last reply Reply Quote 0
                                  • Schmartundefined
                                    Schmart @izeman
                                    @izeman I'm missing text like 'Axes to be homed' in the console, so I'm assuming you had to modify the code for the topology of your printer.
                                    Can you verify that the code still contains the T{var.tool_number} and M568 P{var.tool_number} S{var.print_temperature} R{var.standby_temperature} A1 statements? This selects the current tool, respectively sets the active and standby temperatures and requests to go to the standby temperature.
                                    If that's still in there, according to the documentation, the M568 A2 on line 131 should use the current tool (which should be selected with T{var.tool_number}) and therefore M568 should not require the P parameter, but you can try if changing the code M568 A2 (originally on line 131) to M568 P{var.tool_number} A2 helps mitigate the error.
                                    izemanundefined 1 Reply Last reply Reply Quote 0
                                      Heartleander81 @Schmart
                                      @schmart hi.
                                      When I write a echo for purge_line_flow_ratio become I the error on line 88 not in line 139 and line 141.
                                      I have check it on vs code to and notepad ++ ther looks All good but doun't work
                                      PCRundefined 1 Reply Last reply Reply Quote 0
                                      • PCRundefined
                                        PCR @Heartleander81
                                        @chrishamm
                                        Via privat chat @Heartleander81 and I tried to solve his problem.
                                        He is using a D3 with SBC. I am using a D3M+ standalone. I sent him my macro and he tried to simulatet it. He got this error:
                                        GetFileInfo: Cannot convert Z parameter to float (value {var.layer_height})
                                        We both are running 3.4 B5. Could this be a DSF Problem?
                                        @oozeBot i know you have some printer running D3 with SBC. Can you try to simulate it?
                                        Best
                                        Heartleander81undefined chrishammundefined 2 Replies Last reply Reply Quote 0
                                          Heartleander81 @PCR
                                          I have copy second time the Code from first comment.
                                          I have the error with the line 139 and 141 but the test run now.
                                          • chrishammundefined
                                            chrishamm administrators @PCR
                                            @pcr Can you please send me the full G-code file?
                                            Duet software engineer
