    Feature Request - workpiece angle compensation CNC
    Firmware wishlist
    11
    54
    2.8k
    • jrentschler01undefined
      jrentschler01 @dc42
      @dc42 duet2 wifi with fw 3.3
      Jürgen
        T3P3Tony administrators @jrentschler01
        @jrentschler01 There is a test build here: https://www.dropbox.com/sh/xeu30go894p9xbs/AAB5U66SH4wbjKIcX0snUbKxa?dl=0
        If you are not already running 3.4b5 please upgrade to that before upgrading to this (and check the upgrade notes).
        Note this is untested so proceed with caution.
        jrentschler01undefined 2 Replies Last reply Reply Quote 0
          jrentschler01 @T3P3Tony
          @t3p3tony said in Feature Request - workpiece angle compensation CNC:
          the
          @T3P3Tony Thank you I'm close to start to test, wiring tooks a little longer but I hope I should have everthing running by tomorrow.
          But how should be the procedure for the compensation?
          Jürgen
            jay_s_uk @jrentschler01
            @jrentschler01 i've written a macro.
            this in theory should work but I haven't tested it yet.
            var y_first_measurement = 0
            var y_second_measurement = 0
            var y_length = 0
            var x_first_measurement = 0
            var x_second_measurement = 0
            var x_length = 0
            var y_over_x = 0
            var y_x_tan_rads = 0
            var y_x_tan_deg = 0
            M291 P"Put the probe on the left hand side of the bottom edge" S2 X1 Y1 Z1		; Pop up box asking for operator input
            M558 F1500																		; Set the initial probing speed
            G38.2 Y600 P0 K0																	; Probe the material as a first pass
            G1 Y{move.axes[1].machinePosition-5}											; Move 5mm away from the material
            M558 F150																		; Set the final probing speed
            G38.2 Y600 P0 K0																	; Probe the material again
            M400																			; Make sure all movement is complete
            set var.y_first_measurement=move.axes[1].machinePosition						; Record the stop position y_first_measurement
            set var.x_first_measurement=move.axes[0].machinePosition						; Record the stop position x_first_measurement
            M400																			; Make sure all data recording is complete
            G1 X{move.axes[0].machinePosition+50}											; Move along the workpiece in X
            set var.y_second_measurement=move.axes[1].machinePosition						; Record the stop position y_second_measurement
            set var.x_second_measurement=move.axes[0].machinePosition						; Record the stop position x_second_measurement
            set var.y_length={var.y_second_measurement-var.y_first_measurement}
            set var.x_length={var.x_second_measurement-var.x_first_measurement}
            set var.y_over_x={var.y_length/var.x_length}
            set var.y_x_tan_rads=atan(var.y_over_x)
            set var.y_x_tan_deg=degrees(var.y_x_tan_rads)
            G68 A0 B0 R{var.y_x_tan_deg}
            Now this will ask you to jog to the bottom edge of your material, ideally you should go to somewhere near the bottom left.
            This is of course assuming you're using a probe that can probe in X, Y and Z and its set as K0. I use a vers.by probe.
            It uses G38.2 and stores the X and Y coordinates of each point. Once it probes the first point, it moves 50mm in X and probes again.
            The angle is then calculated and fed into G68.
            If you don't want to set it that way, its set using G68 Ax Bx Rx where Ax is the centre point to rotate around in X, Bx is the centre point to rotate around in Y and Rx is the angle to offset and is counterclockwise
            CanDo415undefined 1 Reply Last reply Reply Quote 3
              After days of reading through this forum I managed now to get my machine wokring somehow but there are still a lot off issues that i found with using the duet as CNC Controller. But I guess I should put this in a seperate thread, right?
              @t3p3tony But now I was able to test the angle compensation, I was a little confused with the other threads that I thought you will do it differently then the G68 command that's why I asked for the procedure.
              I tryed it with the RRF 3.4b5 in the link and the G68 command but it was a fail. Here is what I did:
              I drawed a simple rectangle with this G-Code
              ;simple rectangle for test
              G90
              G21
              G1 F500
              G1 X50
              G1 Y50
              G1 X0
              G1 Y0
              Then I just moved the X Work offset +70 and entered
              G68 A0 B0 R45
              and run the same G-Code again but the result was far away from what I expected:
              the left rectange is normal without G68 and the right one is with the 68.
              I think just the first move looks right with the 45° angle. What could be the Problem?
              Jürgen
              T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                @jrentschler01 i am not sure, it will take me quite some time to get setup to test this right now so i wonder if @jay_s_uk has had a chance to test it and if its working for him?
                  jay_s_uk @T3P3Tony
                  @t3p3tony not had a chance to test it yet. I'll see if I can set something up later on
                    jrentschler01
                    @jay_s_uk do you think you can help in this?
                    Let me know if you you guys need more information or anthing I should test.
                    I knkow i needed quite some time to get ready but I'm not sure how long I keep this setup with the duet because this will be one of the essential functions I need and some other issues that I faced with using RepRap for CNC. I might moving on to linuxcnc soon.
                    Jürgen
                      @jrentschler01 maybe post about your other issues?
                      jrentschler01undefined 1 Reply Last reply Reply Quote 0
                        dc42 administrators @jrentschler01
                        @jrentschler01 I confirm, G68 is not working properly. I'm looking at it now.
                        • jrentschler01undefined jrentschler01 referenced this topic
                          jrentschler01 @jay_s_uk
                          @jay_s_uk I did in a seperate thread:
                          https://forum.duet3d.com/topic/25848/found-issues-using-duet-as-cnc-controller
                          Jürgen
                            jrentschler01 @dc42
                            @dc42 okay great let me know if I can do something to help
                            Jürgen
                              @jrentschler01 please test G68 using one of the firmware binaries at https://www.dropbox.com/sh/4h5zqc0ki73wa9r/AABrMZxfMzMH4M0uJQPLsBmQa?dl=0.
                              Please note, these report the version as 3.4.0-beta6, however they are only candidates for the 3.4.0beta6 release. So please install the official beta6 when we release it.
                              I have tested basic G1, G2 and G3 moves with G68 and I believe they are working correctly. I have forbidden using G92 to set X or Y when G68 is in effect. I haven't taken account of G68 in any other situations - there may be some where RRF ought to.
                              The coordinate rotation defined by G68 is ignored when running system macros such as pause.g, resume.g, tool change and homing files.
                                jrentschler01 @dc42
                                @dc42 I tested now with G1 the same wy with drawing a simple rectangle and it worked so far, I assume G2&G3 as well. Thank you a lot.
                                I'm continue getting a macro ready to probe the workpice and calulate the angle like @jay_s_uk mentioned.
                                It would be great if we could visualize it after that somehow.
                                Jürgen
                                • CanDo415undefined
                                  CanDo415 @jay_s_uk
                                  @jay_s_uk said in Feature Request - workpiece angle compensation CNC:
                                  var y_length = 0
                                  var x_length = 0
                                  var y_over_x = 0
                                  var y_x_tan_deg = 0
                                  set var.var y_x_tan_rads = degrees{var.y_x_tan_rads}
                                  G68 A0 B0 R{var.y_x_tan_rads}
                                  Very good job so far.
                                  I still get an error while running the macro.
                                  "M292
                                  Error: in file macro line 37 column 13: meta command: expected '='
                                  Can somebody help me?
                                    Phaedrux Moderator @CanDo415
                                    @CanDo415 Can you share your firmware version?
                                    CanDo415undefined 1 Reply Last reply Reply Quote 0
                                    • CanDo415undefined
                                      CanDo415 @Phaedrux
                                      @Phaedrux 3.4.1
                                        @CanDo415 Please update to 3.5.1 and double check your macro that it matches the one shared. Particularly the line number the error reports.
                                        • CanDo415undefined
                                          CanDo415 @Phaedrux
                                          @Phaedrux
                                          copied the macro.
                                          I have to fix all problems from the update first. Messed up my whole config😧
                                          • CanDo415undefined
                                            CanDo415
                                            "Error: in file macro line 37 column 12: meta command: unknown variable 'var'"
                                            is the new result after updating to 3.5.1
                                            var y_length = 0
                                            var x_length = 0
                                            var y_over_x = 0
                                            var y_x_tan_deg = 0
                                            M291 P"Probe links vor das Werstück positionieren" S2 X1 Y1 Z1					; Pop up box asking for operator input
                                            G1 Y{move.axes[1].machinePosition-10}											; Move 5mm away from the material
                                            set var.var y_x_tan_rads=degrees{var.y_x_tan_rads}
                                            jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
