    Feature Request - workpiece angle compensation CNC
    Firmware wishlist
    11
    54
    2.7k
      dc42 administrators @jrentschler01
      @jrentschler01 I confirm, G68 is not working properly. I'm looking at it now.
      jrentschler01undefined 1 Reply Last reply Reply Quote 0
      • jrentschler01undefined jrentschler01 referenced this topic
        jrentschler01 @jay_s_uk
        @jay_s_uk I did in a seperate thread:
        https://forum.duet3d.com/topic/25848/found-issues-using-duet-as-cnc-controller
        Jürgen
          jrentschler01 @dc42
          @dc42 okay great let me know if I can do something to help
          Jürgen
            @jrentschler01 please test G68 using one of the firmware binaries at https://www.dropbox.com/sh/4h5zqc0ki73wa9r/AABrMZxfMzMH4M0uJQPLsBmQa?dl=0.
            Please note, these report the version as 3.4.0-beta6, however they are only candidates for the 3.4.0beta6 release. So please install the official beta6 when we release it.
            I have tested basic G1, G2 and G3 moves with G68 and I believe they are working correctly. I have forbidden using G92 to set X or Y when G68 is in effect. I haven't taken account of G68 in any other situations - there may be some where RRF ought to.
            The coordinate rotation defined by G68 is ignored when running system macros such as pause.g, resume.g, tool change and homing files.
              jrentschler01 @dc42
              @dc42 I tested now with G1 the same wy with drawing a simple rectangle and it worked so far, I assume G2&G3 as well. Thank you a lot.
              I'm continue getting a macro ready to probe the workpice and calulate the angle like @jay_s_uk mentioned.
              It would be great if we could visualize it after that somehow.
              Jürgen
              • CanDo415undefined
                CanDo415 @jay_s_uk
                @jay_s_uk said in Feature Request - workpiece angle compensation CNC:
                @jrentschler01 i've written a macro.
                this in theory should work but I haven't tested it yet.
                var y_first_measurement = 0
                var y_second_measurement = 0
                var y_length = 0
                var x_first_measurement = 0
                var x_second_measurement = 0
                var x_length = 0
                var y_over_x = 0
                var y_x_tan_rads = 0
                var y_x_tan_deg = 0
                M291 P"Put the probe on the left hand side of the bottom edge" S2 X1 Y1 Z1		; Pop up box asking for operator input
                M558 F1500																		; Set the initial probing speed
                G38.2 Y600 P0 K0																	; Probe the material as a first pass
                G1 Y{move.axes[1].machinePosition-5}											; Move 5mm away from the material
                M558 F150																		; Set the final probing speed
                G38.2 Y600 P0 K0																	; Probe the material again
                M400																			; Make sure all movement is complete
                set var.y_first_measurement=move.axes[1].machinePosition						; Record the stop position y_first_measurement
                set var.x_first_measurement=move.axes[0].machinePosition						; Record the stop position x_first_measurement
                M400																			; Make sure all data recording is complete
                G1 X{move.axes[0].machinePosition+50}											; Move along the workpiece in X
                set var.y_second_measurement=move.axes[1].machinePosition						; Record the stop position y_second_measurement
                set var.x_second_measurement=move.axes[0].machinePosition						; Record the stop position x_second_measurement
                set var.y_length={var.y_second_measurement-var.y_first_measurement}
                set var.x_length={var.x_second_measurement-var.x_first_measurement}
                set var.y_over_x={var.y_length/var.x_length}
                set var.y_x_tan_rads=atan(var.y_over_x)
                set var.var y_x_tan_rads = degrees{var.y_x_tan_rads}
                G68 A0 B0 R{var.y_x_tan_rads}
                Now this will ask you to jog to the bottom edge of your material, ideally you should go to somewhere near the bottom left.
                This is of course assuming you're using a probe that can probe in X, Y and Z and its set as K0. I use a vers.by probe.
                It uses G38.2 and stores the X and Y coordinates of each point. Once it probes the first point, it moves 50mm in X and probes again.
                The angle is then calculated and fed into G68.
                If you don't want to set it that way, its set using G68 Ax Bx Rx where Ax is the centre point to rotate around in X, Bx is the centre point to rotate around in Y and Rx is the angle to offset and is counterclockwise
                Very good job so far.
                I still get an error while running the macro.
                "M292
                Error: in file macro line 37 column 13: meta command: expected '='
                Can somebody help me?
                  Phaedrux Moderator @CanDo415
                  @CanDo415 Can you share your firmware version?
                  CanDo415undefined 1 Reply Last reply Reply Quote 0
                  • CanDo415undefined
                    CanDo415 @Phaedrux
                    @Phaedrux 3.4.1
                      @CanDo415 Please update to 3.5.1 and double check your macro that it matches the one shared. Particularly the line number the error reports.
                      • CanDo415undefined
                        CanDo415 @Phaedrux
                        @Phaedrux
                        copied the macro.
                        I have to fix all problems from the update first. Messed up my whole config😧
                        • CanDo415undefined
                          CanDo415
                          "Error: in file macro line 37 column 12: meta command: unknown variable 'var'"
                          is the new result after updating to 3.5.1
                          var y_length = 0
                          var x_length = 0
                          var y_over_x = 0
                          var y_x_tan_deg = 0
                          M291 P"Probe links vor das Werstück positionieren" S2 X1 Y1 Z1					; Pop up box asking for operator input
                          G1 Y{move.axes[1].machinePosition-10}											; Move 5mm away from the material
                          set var.var y_x_tan_rads=degrees{var.y_x_tan_rads}
                          jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                            jay_s_uk @CanDo415
                            @CanDo415 i have a mistake in my macro. i have corrected my original
                            • CanDo415undefined
                              CanDo415 @jay_s_uk
                              @jay_s_uk
                              @Phaedrux
                              Error: line 37 column 22: meta command: unknown value 'degrees'
                              there seems to be a bit more
                                jay_s_uk @CanDo415
                                @CanDo415 i've made another change but I don't think its going to fix the issue.
                                I don't know why "degrees" throws an error though as its a built in command
                                CanDo415undefined OwenDundefined 2 Replies Last reply Reply Quote 0
                                • CanDo415undefined
                                  CanDo415 @jay_s_uk
                                  that's why i added Phaedrux.
                                  I want to change it a bit to get the corner as well. so the degrees issue has to be solved anyway.
                                  Thanks for the great start jay
                                  • CanDo415undefined
                                    CanDo415 @CanDo415
                                    maybe he can help?
                                      droftarts administrators @CanDo415
                                      @CanDo415 @jay_s_uk
                                      There's a space in the variable name, ie var.var y_x_tan_rads isn't a valid variable name.
                                      • CanDo415undefined
                                        CanDo415 @droftarts
                                        @droftarts
                                        jay corrected it already.
                                        the problem shifted to the degrees command
                                        • OwenDundefined
                                          OwenD @jay_s_uk
                                          degrees() is a function
                                          You've used curly braces instead of parentheses
                                          set var.y_x_tan_deg=degrees{var.y_x_tan_rads}
                                          try
                                          set var.y_x_tan_deg=degrees(var.y_x_tan_rads)
                                          jay_s_ukundefined CanDo415undefined 2 Replies Last reply Reply Quote 2
                                            jay_s_uk @OwenD
                                            @OwenD i knew it would be something about the way its been formatted
                                            updated the original again
