Anybody wants a stepper motor analyzer?
@rjenkinsgb Which connectors do you need? I just received a my order of the WURTH connectors (similar to the Duet 5+ or Duet 2). They look similar to yours on the board. I could send over a couple if you're willing to wait and part with some beer money.
@th0mpy
That's a good question at the moment there is almost nothing to buy, so I'll take the one that is available again first. So ACS70331EOLCTR-2P5B3 or TMCS1101A4BQDT -
@th0mpy said in Anybody wants a stepper motor analyzer?:
The six pin 2mm pitch headers, as fitted to stepper motors, to make an inline adapter for that end.
I have plenty of four pin KK ones, thanks.
At the moment the 2mm pin headers are like gold dust - 27p on RS but out of stock, or anything up to £10 EACH on ebay.
I found some back-to-back headers to connect two motor cables together, so I can use one of those as the inline connector & I have a few spare motor cables to make up the adapters.
(They cost around ten euros, but for a pack of 16). -
@dogma2k With either of those you should not need a jumper on the options. They both have 400mv/a rating, so you should be good.
@rjenkinsgb What about just some stepper motor cables, and hack the end off? Something like this maybe: https://www.amazon.com/RuiLing-Stepper-Motor-Cables-HX2-54/dp/B07QHTG82K/ref=sr_1_3?keywords=stepper+motor+cable&qid=1637721866&sr=8-3
I have those already - it's the mating header connector I need, so I can unplug from a motor and connect "inline" between that cable and the motor.
These, in other words:
https://uk.rs-online.com/web/p/pcb-headers/1755419/
https://www.ebay.co.uk/itm/143627995609I got a pack of these instead, and I can use two motor cables on the analyzer with one of these to link to the existing motor cable:
https://www.ebay.co.uk/itm/383225801147(I'm not buying from the profiteering sellers on principle).
Six pin plug to socket extension cables would have been ideal, but I cannot find any place actually in the UK selling them.
The Mouser TMCS1101A4BQDT ICs seem to work perfectly!
I've made a harness to connect in to the axis motor sockets on the control box, which is fine for those (but the extruders are run from individual toolboards).
[I have printed an enclosure, but then discovered I don't have any thin double-sided tape to attach the display... I'll get some later on].
@rjenkinsgb, very nice build!
A couple of notes:
- Theoretically the analyzer needs only 4 wires to measure the currents of the two coils. You can build a harness that has only 4 wires with Y splitting on both ends.
- For double sided tape for the TFT, I had good experience with this kind of thermal tapes. They hold well and designed to be isolating. https://www.amazon.com/gp/product/B072JJD2ND . I also use them between the Pico and the PCB for extra isolation.
- You mention residual current (0.04A in the picture). I presume that you set the zero in the Settings screen.
A question for the people that uses various current sensors, how do tell the firmware what is the mv/A sensitivity of the sensor you use?
I don't think that this kind of equipment needs to be supper accurate in the current measurement but it's nice to keep it reasonably close, e.g. +/-5%.
@th0mpy
Thank you for your explanation.
I have now found a couple of TMCS1101A4BQDT that I wanted to order.It doesn't really matter what kind of stepper I analyze. I wanted to install the analyzer on my NEMA23 as a permanent display
@zapta said in Anybody wants a stepper motor analyzer?:
A couple of notes:
I realise only two through connections are monitored, but the harness needs two connectors at either end anyway..
To fix the display, I put a few strips of kapton on the back & over the rear of the motor connectors to ensure good insulation, then some generic thin double sided tape to hold things together.
Yes, it has been zero'd - the readings fluctuate randomly +/- a small amount with no connections. When I first turned the unit on, it read somewhere around 300 - 400mA on each channel.
It's a really nice design, the options and screen responsiveness are great. Playing around with it, I realised it can do for something else I have been intending to make for some time - an encoder tester for machine tool systems.
If I add a pair of analog differential inputs with selectable gain in place of the current sensors on one, it can monitor either sine or digital encoders & linear scale signals - pretty much just change the Amps indication for Volts!
If you get some TMCS1101A4BQDT ICs, they are the same sensitivity as the original ones.
@rjenkinsgb said in Anybody wants a stepper motor analyzer?:
TMCS1101A4BQDT
The datasheet of the TMCS1101A4BQDT suggests that it requires 5V supply. Does it work well with 3.3V?
@zapta It seems that either 3.3v or 5v work just fine. The limits are just a little different.
Good to know. Thanks. Yes, 3.3 will cause saturation for +/-5.75A @400mv/A but we don't need that full range, and it is specified for 3.3V for the other ranges.
@dogma2k said in Anybody wants a stepper motor analyzer?:
AWD Stepper Motor Analyze
Wow! That's a nice design.
Hey everyone, I have a new batch of sensors being delivered early next week. If you're interested hit me up via chat.
The final case is finally ready. I also installed a FlowMeter. Everything fits in and the lid even closes.
If you like, you can download the STEP file -
@dogma2k , looks very impressive. If you can, please post here a picture with all screen on, it will be even more cool.
