    Anybody wants a stepper motor analyzer?
    281
    31.6k
    • rjenkinsgbundefined
      rjenkinsgb
      The Mouser TMCS1101A4BQDT ICs seem to work perfectly!
      I've made a harness to connect in to the axis motor sockets on the control box, which is fine for those (but the extruders are run from individual toolboards).
      [I have printed an enclosure, but then discovered I don't have any thin double-sided tape to attach the display... I'll get some later on].
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      • zaptaundefined
        zapta @rjenkinsgb
        @rjenkinsgb, very nice build!
        A couple of notes:
        1. Theoretically the analyzer needs only 4 wires to measure the currents of the two coils. You can build a harness that has only 4 wires with Y splitting on both ends.
        2. For double sided tape for the TFT, I had good experience with this kind of thermal tapes. They hold well and designed to be isolating. https://www.amazon.com/gp/product/B072JJD2ND . I also use them between the Pico and the PCB for extra isolation.
        3. You mention residual current (0.04A in the picture). I presume that you set the zero in the Settings screen.
        zaptaundefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
        • zaptaundefined
          zapta @zapta
          A question for the people that uses various current sensors, how do tell the firmware what is the mv/A sensitivity of the sensor you use?
          I don't think that this kind of equipment needs to be supper accurate in the current measurement but it's nice to keep it reasonably close, e.g. +/-5%.
          rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
          • Dogma2kundefined
            Dogma2k @Th0mpy
            @th0mpy
            Thank you for your explanation.
            I have now found a couple of TMCS1101A4BQDT that I wanted to order.
            It doesn't really matter what kind of stepper I analyze. I wanted to install the analyzer on my NEMA23 as a permanent display
              rjenkinsgb @zapta
              @zapta said in Anybody wants a stepper motor analyzer?:
              A couple of notes:
              I realise only two through connections are monitored, but the harness needs two connectors at either end anyway..
              To fix the display, I put a few strips of kapton on the back & over the rear of the motor connectors to ensure good insulation, then some generic thin double sided tape to hold things together.
              Yes, it has been zero'd - the readings fluctuate randomly +/- a small amount with no connections. When I first turned the unit on, it read somewhere around 300 - 400mA on each channel.
              It's a really nice design, the options and screen responsiveness are great. Playing around with it, I realised it can do for something else I have been intending to make for some time - an encoder tester for machine tool systems.
              If I add a pair of analog differential inputs with selectable gain in place of the current sensors on one, it can monitor either sine or digital encoders & linear scale signals - pretty much just change the Amps indication for Volts!
              Robert J.
                rjenkinsgb @zapta
                If you get some TMCS1101A4BQDT ICs, they are the same sensitivity as the original ones.
                Robert J.
                • zaptaundefined
                  zapta @rjenkinsgb
                  @rjenkinsgb said in Anybody wants a stepper motor analyzer?:
                  TMCS1101A4BQDT
                  The datasheet of the TMCS1101A4BQDT suggests that it requires 5V supply. Does it work well with 3.3V?
                  Th0mpyundefined 1 Reply Last reply Reply Quote 0
                  • Th0mpyundefined
                    Th0mpy @zapta
                    @zapta It seems that either 3.3v or 5v work just fine. The limits are just a little different.
                    Usually the team that scores the most points wins the game.
                    • zaptaundefined
                      zapta @Th0mpy
                      @th0mpy said in Anybody wants a stepper motor analyzer?:
                      Good to know. Thanks. Yes, 3.3 will cause saturation for +/-5.75A @400mv/A but we don't need that full range, and it is specified for 3.3V for the other ranges.
                      • Dogma2kundefined
                        Dogma2k
                        So that the prototype housing of the AWD Stepper Motor Analyzer fits quite well, just adjust a few small things.
                        zaptaundefined 1 Reply Last reply Reply Quote 1
                        • zaptaundefined
                          zapta @Dogma2k
                          @dogma2k said in Anybody wants a stepper motor analyzer?:
                          Wow! That's a nice design.
                          • Th0mpyundefined
                            Th0mpy
                            Hey everyone, I have a new batch of sensors being delivered early next week. If you're interested hit me up via chat.
                            • Dogma2kundefined
                              Dogma2k
                              The final case is finally ready. I also installed a FlowMeter. Everything fits in and the lid even closes.
                              If you like, you can download the STEP file
                              https://a360.co/3sl2Kge
                              • zaptaundefined
                                zapta @Dogma2k
                                @dogma2k , looks very impressive. If you can, please post here a picture with all screen on, it will be even more cool. 😉
                                Dogma2kundefined 1 Reply Last reply Reply Quote 0
                                • Dogma2kundefined
                                  Dogma2k @zapta
                                  @zapta
                                  Unfortunately only provisionally because I don't have my 5V transformer an Arduino Uno yet
                                  • Dogma2kundefined
                                    Dogma2k
                                    @zapta
                                    Can the analyzer be switched on and off during operation? Because you can / should only disconnect the motors without electrical voltage. Or does it matter here because the input and output always have continuity and the measurements are only picked up in parallel?
                                    • zaptaundefined
                                      zapta @Dogma2k
                                      @dogma2k, the electronics and the stepper circuit are isolated from each other so it's safe to turn 5V power on/off even when the printer is working. It will not damage the electronic and the print will continue with no interruption.
                                      • Dogma2kundefined
                                        Dogma2k
                                        The analyzer is finally running after I had to remove the display again because the soldering points of the connector had pushed through the metal frame of the display and always caused a short circuit
                                        Thanks for the nice toy 😉
                                        zaptaundefined 2 Replies Last reply Reply Quote 0
                                        • zaptaundefined
                                          zapta @Dogma2k
                                          Wow! Looks awesome. I am glad that this didn't cause a permanent damage. I maintain the insulation by
                                          1. Using an insulated 10mm width double tape on the back of the PCB, at the marked areas. E.g. https://www.amazon.com/Adhesive-10mmx25mx0-25mm-Thermally-Conductive-Computer/dp/B075FRPXQ5 . I also apply it between the PCB and the PICO, just in case.
                                          2. Pre cutting the servo connectors pins such that they don't protrude at the back of the connector. This is the trimming jig I use https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/3d/connector_trim_jig.stl
                                          BTW, it should be ok to connect multiple analyzers to the same servo since the sensors serial resistance is very low.
                                          • zaptaundefined
                                            zapta @Dogma2k
                                            @dogma2k, the current readings seem have have offset. You may want to reset it in the Settings screen with the motor disconnected (that is, zero current).
