    Anybody wants a stepper motor analyzer?
    281
    34.1k
    • zaptaundefined
      zapta @rjenkinsgb
      @rjenkinsgb, very nice build!
      A couple of notes:
      1. Theoretically the analyzer needs only 4 wires to measure the currents of the two coils. You can build a harness that has only 4 wires with Y splitting on both ends.
      2. For double sided tape for the TFT, I had good experience with this kind of thermal tapes. They hold well and designed to be isolating. https://www.amazon.com/gp/product/B072JJD2ND . I also use them between the Pico and the PCB for extra isolation.
      3. You mention residual current (0.04A in the picture). I presume that you set the zero in the Settings screen.
      zaptaundefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
      • zaptaundefined
        zapta @zapta
        A question for the people that uses various current sensors, how do tell the firmware what is the mv/A sensitivity of the sensor you use?
        I don't think that this kind of equipment needs to be supper accurate in the current measurement but it's nice to keep it reasonably close, e.g. +/-5%.
        rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
        • Dogma2kundefined
          Dogma2k @Th0mpy
          @th0mpy
          Thank you for your explanation.
          I have now found a couple of TMCS1101A4BQDT that I wanted to order.
          It doesn't really matter what kind of stepper I analyze. I wanted to install the analyzer on my NEMA23 as a permanent display
          • rjenkinsgbundefined
            rjenkinsgb @zapta
            @zapta said in Anybody wants a stepper motor analyzer?:
            A couple of notes:
            I realise only two through connections are monitored, but the harness needs two connectors at either end anyway..
            To fix the display, I put a few strips of kapton on the back & over the rear of the motor connectors to ensure good insulation, then some generic thin double sided tape to hold things together.
            Yes, it has been zero'd - the readings fluctuate randomly +/- a small amount with no connections. When I first turned the unit on, it read somewhere around 300 - 400mA on each channel.
            It's a really nice design, the options and screen responsiveness are great. Playing around with it, I realised it can do for something else I have been intending to make for some time - an encoder tester for machine tool systems.
            If I add a pair of analog differential inputs with selectable gain in place of the current sensors on one, it can monitor either sine or digital encoders & linear scale signals - pretty much just change the Amps indication for Volts!
            Robert J.
            Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
              rjenkinsgb @zapta
              If you get some TMCS1101A4BQDT ICs, they are the same sensitivity as the original ones.
              Robert J.
              • zaptaundefined
                zapta @rjenkinsgb
                @rjenkinsgb said in Anybody wants a stepper motor analyzer?:
                TMCS1101A4BQDT
                The datasheet of the TMCS1101A4BQDT suggests that it requires 5V supply. Does it work well with 3.3V?
                Th0mpyundefined 1 Reply Last reply Reply Quote 0
                • Th0mpyundefined
                  Th0mpy @zapta
                  @zapta It seems that either 3.3v or 5v work just fine. The limits are just a little different.
                  Usually the team that scores the most points wins the game.
                  • zaptaundefined
                    zapta @Th0mpy
                    @th0mpy said in Anybody wants a stepper motor analyzer?:
                    Good to know. Thanks. Yes, 3.3 will cause saturation for +/-5.75A @400mv/A but we don't need that full range, and it is specified for 3.3V for the other ranges.
                    • Dogma2kundefined
                      Dogma2k
                      So that the prototype housing of the AWD Stepper Motor Analyzer fits quite well, just adjust a few small things.
                      zaptaundefined 1 Reply Last reply Reply Quote 1
                      • zaptaundefined
                        zapta @Dogma2k
                        @dogma2k said in Anybody wants a stepper motor analyzer?:
                        Wow! That's a nice design.
                        • Th0mpyundefined
                          Th0mpy
                          Hey everyone, I have a new batch of sensors being delivered early next week. If you're interested hit me up via chat.
                          • Dogma2kundefined
                            Dogma2k
                            The final case is finally ready. I also installed a FlowMeter. Everything fits in and the lid even closes.
                            If you like, you can download the STEP file
                            https://a360.co/3sl2Kge
                            • zaptaundefined
                              zapta @Dogma2k
                              @dogma2k , looks very impressive. If you can, please post here a picture with all screen on, it will be even more cool. 😉
                              Dogma2kundefined 1 Reply Last reply Reply Quote 0
                              • Dogma2kundefined
                                Dogma2k @zapta
                                @zapta
                                Unfortunately only provisionally because I don't have my 5V transformer an Arduino Uno yet
                                • Dogma2kundefined
                                  Dogma2k
                                  @zapta
                                  Can the analyzer be switched on and off during operation? Because you can / should only disconnect the motors without electrical voltage. Or does it matter here because the input and output always have continuity and the measurements are only picked up in parallel?
                                  • zaptaundefined
                                    zapta @Dogma2k
                                    @dogma2k, the electronics and the stepper circuit are isolated from each other so it's safe to turn 5V power on/off even when the printer is working. It will not damage the electronic and the print will continue with no interruption.
                                    • Dogma2kundefined
                                      Dogma2k
                                      The analyzer is finally running after I had to remove the display again because the soldering points of the connector had pushed through the metal frame of the display and always caused a short circuit
                                      Thanks for the nice toy 😉
                                      zaptaundefined 2 Replies Last reply Reply Quote 0
                                      • zaptaundefined
                                        zapta @Dogma2k
                                        Wow! Looks awesome. I am glad that this didn't cause a permanent damage. I maintain the insulation by
                                        1. Using an insulated 10mm width double tape on the back of the PCB, at the marked areas. E.g. https://www.amazon.com/Adhesive-10mmx25mx0-25mm-Thermally-Conductive-Computer/dp/B075FRPXQ5 . I also apply it between the PCB and the PICO, just in case.
                                        2. Pre cutting the servo connectors pins such that they don't protrude at the back of the connector. This is the trimming jig I use https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/3d/connector_trim_jig.stl
                                        BTW, it should be ok to connect multiple analyzers to the same servo since the sensors serial resistance is very low.
                                        • zaptaundefined
                                          zapta @Dogma2k
                                          @dogma2k, the current readings seem have have offset. You may want to reset it in the Settings screen with the motor disconnected (that is, zero current).
                                          • Dogma2kundefined
                                            Dogma2k @zapta
                                            I had double-sided tape in between. Wasn't enough
                                            https://www.amazon.de/gp/product/B08YJK6L1T/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
                                            It didn't matter, it went well, it was just fun to find the fault ...
                                            1. Pre cutting the servo connectors pins such that they don't protrude at the back of the connector. This is the trimming jig I use https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/3d/connector_trim_jig.stl
                                            That would probably have been the best had I done that
                                            Even more? I already need 4 pieces because I have 2x X steppers and 2x Y steppers.
                                            The small OLED is also not yet in operation for the filament flow meter, because I haven't had time to get the Arduino UNO ready
                                            I still have a problem that as soon as the motors are working, the display does not react at all or almost not at all.
                                            If the motors are switched off with M84 then you can use the display properly.
                                            How come that
                                            Analyzer_standby.mp4
                                            Analyzer_aktion.mp4
