    Very stubborn print quality issue
    29
    1.8k
    • theruttmeisterundefined
      theruttmeister @Vinculum
      @hbm-3d given that it seems to be an error based on layer number, my guess would be some sort of compounding error in either firmware or maybe mismatched slicer settings.
      Steps/mm on Z or E causing some sort of trailing offset.
      I'd start by trying to confirm that the machine really is doing what is commanded in Z and E.
      It's that or you have really really bad CPE on the ballscrews.
      Isolate, substitute, verify.
      • oliofundefined
        oliof
        I know this sounds weird but it could be drag on the filament spool. I recently had this with a cardboard spool on a printed spool holder -- just too much friction and the filament needed a good yank from the extruder to move. If you're not using a bearing based roller, it might be worth looking into one. (would also explain why this is less expressed with 0.3 layer height because more material being pushed means more continuous pull on the spool).
        Vinculumundefined 1 Reply Last reply Reply Quote 1
        • Vinculumundefined
          Vinculum @rjenkinsgb
          @rjenkinsgb As far as i can see they are matching the outside.
          • Vinculumundefined
            Vinculum @oliof
            @oliof Good idea but the spool holder is the same as before it had issues.
            Also, it is not bearing based but it is also guided all the way so there is no yank, the tension is fairly steady throughout.
            • Vinculumundefined
              Vinculum
              Ok the plot thickens. I printed a simple square, no infill, just 3 perimeters @ 150mm/s with 0.15mm layer height.
              The only difference is the size, 100x100, 200x200 & 400x400.
              Here is the result (forget the writings):
              I'm lost...
              • oliofundefined
                oliof
                what extruder and hotend are you using? bowden or direct?
                Vinculumundefined 1 Reply Last reply Reply Quote 0
                • Vinculumundefined
                  Vinculum @oliof
                  @oliof Direct. Phaetus dragon with bondtech cht nozzle and sherpa extruder with ldo motor.
                  Ok here's what I think now. It must be extruder related somehow. It isn't the Z-axis or it would not change depending on layer height or even object size as it does now.
                  It is definitly something driven or mechanical since it is way to consistent to be something like material unevenness.
                  The main indicator is that the pattern size increased by object size or vice versa. The smaller the object, the larger the gaps become. Bigger object, so more material extruded, is lower interval. It almost looks like it is overextruding every X meters of filament.
                  • oliofundefined
                    oliof
                    please check that the drive gears on the sherpa are still aligned to each other and inline with the filament path (I've seen some lose position elsewhere which can cause weird issues). Also make sure your hotend fan is still working correctly. Since you have identical printers next to this, maybe switching out the extruder and hotend from another one to this is easier/faster to ensure they are or are not part of the issue here.
                    • rjenkinsgbundefined
                      rjenkinsgb
                      Are the config files identical between the machines?
                      Any chance of a typo in this one, like the extruder being in bang-bang mode?
                      Have you tried the hotend thermistor, as I suggested at the start of the thread?
                      Robert J.
                      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                      • Vinculumundefined
                        @rjenkinsgb
                        M584 X0.4 Y0.5 Z0.0:0.1:0.2:0.3 E1.0 ; set drive mapping
                        M350 X256 Y256 Z64 E32 I0 ; configure microstepping without interpolation
                        M92 X800.00 Y800.00 Z12820.00 E1402.00 ; set steps per mm
                        M566 X900.00 Y900.00 Z150.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X30000 Y30000 Z300 E12000 ; set maximum speeds (mm/min)
                        M201 X2000 Y2000 Z150 E1500 ; set accelerations (mm/s^2)
                        M906 X2000 Y2000 Z2000 E500 I50 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        ;Hotend 1
                        M308 S1 P"1.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 1.temp0
                        M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1
                        • Vinculumundefined
                          Vinculum
                          Ok so new update.
                          Swapped the Sherpa extruder for a brand new orbiter, changed the steps/mm etc accordingly.
                          No change.
                          Tried 3rd roll of filament that came from another printer that printed fine with it.
                          No change.
                          Unrolled a couple of meters of filament to eliminate the spoolholder.
                          No change.
                          It is something that changes based on a certain amount of extruded filament but it is not the extruder...
                          rjenkinsgbundefined engikeneerundefined theruttmeisterundefined 3 Replies Last reply Reply Quote 0
                            rjenkinsgb @Vinculum
                            @hbm-3d said in Very stubborn print quality issue:
                            No change.
                            Was that the extruder only, or the complete hot end system?
                            (I'm not familiar with those particular extruders).
                            Robert J.
                            • Falkiaundefined
                              Falkia
                              How does the temperature graph for the hotend look, is the temperature reading stable?
                              Have you tried another hotend/thermistor/heat element?
                              Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
                              • engikeneerundefined
                                engikeneer @Vinculum
                                Is it time or filament length based? Maybe do a couple of single wall prints the same size with different wall thicknesses to check
                                i3 clone with a bunch of mods
                                  @hbm-3d change between relative/absolute values for E. See if that does anything. You'll need to change in both RRF and slicer.
                                  • hackinistratorundefined
                                    hackinistrator
                                    i'm 90% sure its your bed heat cycle .
                                    try to print without heating the bed .
                                    • Vinculumundefined
                                      Vinculum @hackinistrator
                                      @hackinistrator
                                      You dir sir are my hero of the day. Turned the bed heater off after the first layer et voila:
                                      So i checked the config with the other printers. It is not completely the same (others are Duet 2 with RRF2) but i missed 1 tiny thing.
                                      This line: M307 H0 B1 S1.00
                                      The B1 had to be a B0... 😤
                                      Problem solved, case closed. I thank you all for your time and input!
                                      • Phaedruxundefined Phaedrux has marked this topic as solved
