    Kit Recommendation: Two Materials 300x300
    36
    2.5k
    • auserundefined
      auser @oliof
      @oliof thanks! Indeed this one has flown below my radar. I did have a look at the first two howtos linked from https://ratrig.dozuki.com/c/Rat_Rig_V-Cast and I like them! so one more to keep an eye open for. I don't expect there is any estimation on when the next version of V-Cast will become available?
      • oliofundefined
        oliof
        Not to my knowledge. I know someone in Germany is willing to sell his, but that's mostly assembled and you probably would need to pick it up ....
        • martin7404undefined
          martin7404 @auser
          @auser For muldex , depending on where are you based 3Dprintingworld -John for USA or me can help you with printed parts. I could build one for you in case you are in EU
          Muldex IDEX Duet2+Duex5
          Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
          Sapphire Pro with Duet2, with closed-loop motors
          custom high temp E3D tool changer with Duet2+Duex
          auserundefined 1 Reply Last reply Reply Quote 1
          • auserundefined
            auser @martin7404
            @martin7404 very kind of you that you offer to help with a muldex! I'm inside europe but not in the EU. Will contact you by PM if that is ok?
            • poofjuniorundefined
              poofjunior @auser
              @auser Looks like I'm getting to this one a bit late, but a kit for the frame has been in the works via Filastruder, and we're almost done aggregating everything. Our target is end of this month (Jan), which feels a bit surreal, since we've been at this for a good ten months now.
              The kit should totally eliminate the need for making your own wire harnesses, come with all the assembly tools except a soldering iron for installing the heat-set inserts, and leverage a Duet3 Mini + 3HC Expansion with 2 drivers to spare for tools by default. (There's also a hole mounting pattern for 2 additional 3HC boards.)
              Along the way, I totally revamped the default extruder tool to be Orbiter-based with support for the 1.5 and 2.0, and then support groovemount heatsinks, threaded heatsinks, and v6 and v7 heads, not to mention a bunch of clones. It also sports dual 5015 fans. More info on the Baby Bullet here, but the folks who've built one or modified one seem to be really happy with it.
              I totally acknowledge that building Jubilee is lots of work, but hopefully this will get folks much further out faster.
              Cheers--and have fun on your build--whatever platform you pick!
              auserundefined 1 Reply Last reply Reply Quote 3
              • auserundefined
                auser @poofjunior
                @poofjunior said in Kit Recommendation: Two Materials 300x300:
                Great news! And thanks for letting me / us know! And no not (for me) I was away a few days and I'm still considering my options. Will there also be an european distributor? As mentioned > 200 usd for shipping and then import tax + VAT does add up.
                Maybe you can post here again when the kit goes life?
                best regards
                poofjuniorundefined 1 Reply Last reply Reply Quote 0
                  poofjunior @auser
                  @auser There's no EU distributer for a kit now, but folks building Jubilees in the EU usually go to HighTemp3D for parts. I'd be open to looking for more folks willing to do kits.
                  I totally acknowledge that shipping costs add up. Test driving a kit in the US is one way to help solve that issue, but not the last. Baby steps!
                  And I'll gladly post an announcement when kits go live if I'm allowed to do some self-promotion!
                  auserundefined T3P3Tonyundefined Sindariusundefined 3 Replies Last reply Reply Quote 2
                  • auserundefined
                    auser @poofjunior
                    @T3P3Tony: Is announcing a kit (duet powered) considered ok in this forum? If not @poofjunior, can you maybe suggest (e.g. in PN) where to subscribe?
                    Thanks all!
                    Edit: formatting
                      T3P3Tony administrators @poofjunior
                      Yes that will be ok. In general I am happy for Duet based printer kits to be linked to on this forum as long as:
                      1. The use genuine Duet3D products
                      2. Its not spammed in loads of posts unnecessarily.
                      • zaptaundefined
                        zapta @auser
                        @auser, I presume that you can also mention it in your signature, since it's fine print and tells about your background. 😉
                        • auserundefined
                          auser @zapta
                          @zapta
                          I think that suggestion was directed @poofjunior. He is the jubiliee designer if I'm not mistaken?
                          • Sindariusundefined
                            Sindarius @poofjunior
                            @poofjunior I for one am excited about a Jubilee kit!
                            • breedundefined
                              breed @auser
                              @auser rat rig v-cast
                                A Former User
                                Print your own.
                                The complete process can be much fun and you´ll learn so much.
                                I could help you.
                                cheers
                                Richard
                                • auserundefined
                                  auser
                                  the filastruder jubilee kit was just announced yesterday: https://forum.duet3d.com/topic/27241/jubilee-kits-are-live
                                  To me this looks very good, and is my current favourite. Especially considered that Ratrigs V-Cast update no longer seems to be "coming soon". But is "on hiatus" [1]. I'm off discussing budgets...
                                  [1] https://www.ratrig.com/3d-printing-cnc/rat-rig-v-cast.html
                                  • AlexKidundefined
                                    AlexKid @martin7404
                                    @martin7404
                                    Than I think we have at least three Muldex builds in Europe. I build one during last year. It was very interessting to do this.
                                      martin7404
                                      @alexkid I am glad, it is great to have one more
                                      where are you located
                                      AlexKidundefined 1 Reply Last reply Reply Quote 0
                                      • AlexKidundefined
                                        AlexKid @martin7404
                                        @martin7404
                                        I'm from germany, Lower Saxony. And you?
                                        martin7404undefined 1 Reply Last reply Reply Quote 0
                                          martin7404 @AlexKid
                                          @alexkid Bulgaria, Sofia
