    Duet3 mini voron gantry level problem
    voron2.4 gantry level problem
    1.8k
    • jamaicarastaundefined
      jamaicarasta
      Hello guys, I'm new here and from Germany. I switched from Klipper to RRF. So far I am very happy that I did. I love it and the panel due 7 inch. But i have a gantry level problem with the duet mini in my voron 2.4 350mm. I have a IR probe to probe Z. With the G32, to measure, it first moves to the middle and then all 4 corners. Then this error message comes up.
      Error: Bed calibration : 4 factor calibration requested but only 0 points provided
      bed.g
      4 M561
      5 G28
      6 G30 P1 X15 X5 z-99999
      7 G30 P2 X15 Y315 z-99999
      8 G30 P3 X300 X315 z-99999
      9 G30 P4 X300 X5 z-99999 S4
      How do I continue? I've searched the internet for hours but just can't find the solution. I would be very grateful for tips.
      Greetings Marc
      jumpedwithbothfeetundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • jumpedwithbothfeetundefined
        jumpedwithbothfeet @jamaicarasta
        @jamaicarasta in all but one probe point you have 2 X axis coordinates, change it too -
        bed.g
        4 M561
        5 G28
        6 G30 P1 X15 Y5 z-99999
        8 G30 P3 X300 Y315 z-99999
        9 G30 P4 X300 Y5 z-99999 S4
        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
        jamaicarastaundefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @jamaicarasta
          @jamaicarasta your probe points to start at 0
          So P0, P1, P2 and P3, not P1, P2, P3 and P4
          jamaicarastaundefined 3 Replies Last reply Reply Quote 0
            jamaicarasta @jay_s_uk
            @jay_s_uk
            ok thanks i thought i have to start at p1 because my 4z motors are plugged into 1,2,3,4.
            I will Try it in a few Hours when I'm back at the printer.
            I'll let you know 👍🤝
            It's amazing how quickly you get an answer here.
              jamaicarasta @jumpedwithbothfeet
              @jumpedwithbothfeet
              where do i have 2 times x? don't quite understand. I gave correct points 4 times in my opinion.
              Thanks
              jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                @jay_s_uk
                and one more question if i may. it does not go to my specified coordinates exactly. X15 stays at X40 on rehearsal. but if I drive normally with g1 then it drives exactly to x15. only at g32 is it off by 25.
                  @jamaicarasta it applies the G31 offsets to that, so if your probe is -25 in X, the nozzle has to be at 40 for the probe to be at 15
                    @jay_s_uk
                    ok i will check that i took a config from the internet from the beginning and maybe the value there is wrong for my probe
                      @jay_s_uk
                      So the error is gone, now I have the next error. is that something in the config file?
                      G32
                      Error: This kinematics does not support auto-calibration
                      Config:
                      General preferences -------------------------------------------------------
                      M550 P"Duet Voron" ; set printer name
                      M669 K1 ; select CoreXY mode
                      ; Network --------------------------------------------------------------------
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      ; Drives ---------------------------------------------------------------------
                      ; ----+---- Z-Drives
                      ; | 2 | 3 |
                      ; | 1 | 4 |
                      ; Front
                      M584 X5 Y6 Z1:2:3:4 E0 ; motor bindings
                      M569 P0 S1 ; extruder motor direction
                      M569 P1 S1 ; Z1 motor direction
                      M569 P2 S0 ; Z2 motor direction
                      M569 P3 S1 ; Z3 motor direction
                      M569 P4 S0 ; Z4 motor direction
                      M569 P5 S1 ; X motor direction
                      M569 P6 S1 ; Y motor direction
                      M350 X16 Y16 Z16 E16 I1 ; set microstepping
                      M92 X80 Y80 Z400 E426 ; set microsteps per mm
                      M566 X16000.00 Y16000.00 Z18000.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                      M203 X24000.00 Y24000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                      M201 X6000.00 Y6000.00 Z3000.00 E1500.00 ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E300 I30 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      ; thermal section ------------------------------------------------------------
                      M308 S3 Y"mcu-temp" A"Board" ; Board thermal sensor
                      M912 P0 S-2 ; MCU tempurature sensor correction (subtract 2°K)
                      ; Axis Limits ----------------------------------------------------------------
                      M208 X350 Y350 Z340 S0 ; set axis maxima
                      ; Endstops -------------------------------------------------------------------
                      M574 X2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io3.in
                      M574 Y2 S1 P"io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io4.in
                      M574 Z1 S2 "io1.in" ; configure switch-type (e.g. Probe) endstop for low end on Z via pin io1.in
                      ; Z-Probe --------------------------------------------------------------------
                      M558 K0 P8 A2 S0.05 C"^io1.in" H5 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
                      G31 P500 X0 Y10 Z1.590 ; set Z probe trigger value, offset and trigger height
                      M557 X15:335 Y15:335 S20 ; define mesh grid
                      ; Heaters --------------------------------------------------------------------
                      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                      M143 H1 S300 ; set temperature limit for heater 1 to 300C
                      ; Fans -----------------------------------------------------------------------
                      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
                      M106 P0 S1 H1 T60 ; set fan 0 value. Thermostatic control is turned on
                      M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
                      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
                      M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
                      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                      M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
                      M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off
                      ; Tools ----------------------------------------------------------------------
                      ; Custom settings are not defined --------------------------------------------
                      M501
                        @jamaicarasta You need an M671 to set the pivot points of the gantry.
                        I would probably go with the point where it the belts attach
                        jamaicarastaundefined 1 Reply Last reply Reply Quote 1
                          @jay_s_uk
                          ok m671… 😤 i forgot it. I read that yesterday. So measure again from the corner of the bed X0 Y0 and enter the minus value there?
                            @jamaicarasta yea, each one would typically sit outside the print area. the M671 should be in the order the Z motors are declared
                            jamaicarastaundefined 2 Replies Last reply Reply Quote 0
                              @jay_s_uk
                              Ah ok. Xmotor1:motor2:motor3:motor4 Ymotor1:motor2:motor3:motor4
                              You are my hero 🙏
                              I hope I can ask you a few more questions in the near future. I still have a few things I don't quite understand.
                                @jay_s_uk
                                I measured and found the values. Should I measure the values ​​from the probe points or simply add them to the entire coordinate system? Example X0Y0 as bett end x-55y-25 from bett end to my middle belt. Or measured from the probe coordinates I gave him.
                                  @jamaicarasta the locations are in relation to X0 Y0
                                    @jay_s_uk
                                    Ok perfect 👍
                                    it works great now. Is there once enough or should he do it several times before printing. It's a very good probe now, I'm only asking because the red probe that came with it always took 4 rounds or more. I exchanged it because it melted at 285 degrees carbon printing defies cork and polyimide tape...
                                      @jamaicarasta you had the X listed twice in each line instead of one X and one Y
                                      however I suspect @jay_s_uk hit the nail on the head with the probe numbering being the actual issue and flagging up the warning 🙂
                                      jamaicarastaundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                        @jumpedwithbothfeet
                                        Sorry that was a old file 😅
                                        I don’t saw this. Now is not x and x in one line 👊🏻
                                          jay_s_uk @jumpedwithbothfeet
                                          @jumpedwithbothfeet you can get it to run until for so many iterations until a set value is obtained.
                                          we have an example here https://teamgloomy.github.io/useful_macros.html#bedg-file-for-g32 that can ne used with 4 locations as well
                                            @jay_s_uk
                                            Thanks for the tip bro.
                                            Now I will make my mesh.g file.
                                            with an error: Push(): stack overflow
                                            ; mesh.g
                                            ; called to perform automatic bedmesh via G29
                                            M561 ; clear any bed...
                                            G29 ; bed mesh
                                            G1 X175 Y175 Z50 F20000 ; go to bed middle
                                            ; bed.g
                                            G30 P0 X15 Y20 Z-99999 ; Probe links vorne
                                            G30 P1 X15 Y315 Z-99999 ; Probe links hinten
                                            G30 P2 X335 Y315 Z-99999 ; Probe rechts hinten
                                            G30 P3 X335 Y20 Z-99999 S4 ; Probe rechts vorne
                                            G1 X175 Y175 Z5 F20000
                                            ; homeall.g
                                            ; called to home all axes
                                            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Feb 11 2022 17:57:25 GMT+0100 (Mitteleuropäische Normalzeit)
                                            G91 ; relative positioning
                                            G1 H1 X355 F6000 ; home X axis
                                            G1 X-5 F6000 ; go back a few mm
                                            G1 H1 X355 F360 ; move slowly to X axis endstop
                                            G1 H1 Y355 F6000 ; home y axis
                                            G1 Y-5 F6000 ; go back a few mm
                                            G1 H1 Y355 F360 ; move slowly to Y axis endstop
                                            G90 ; absolute positioning
                                            G1 X175 Y175 F20000 ; go to first probe point (Bettmitte)
                                            M558 K0 P8 A2 S0.05 C"^io1.in" H2 F300 T16000 ; set Z probe type to modulated and the dive height + speeds
                                            G31 P500 X0 Y20 Z1.590 ; set Z probe trigger value, offset and trigger height
                                            M557 X15:335 Y35:315 S10 ; define mesh grid
                                            jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
