    M584 help needed
    990
    • jlee73undefined
      jlee73 @Phaedrux
      @phaedrux I meant x moves when I try to move y sorry
        You'd have to use something like youtube, or vimeo, or google drive, or dropbox, etc. Or a smaller clip in mp4 format.
        jlee73undefined 2 Replies Last reply Reply Quote 0
        • jlee73undefined
          jlee73 @Phaedrux
          @phaedrux I will have to get that to you tomorrow
            Can you also send M122 and copy and paste the result?
            • fcwiltundefined
              fcwilt @jlee73
              @jlee73 said in M584 help needed:
              Did you experiment with the X and Y values in M669?
              • jlee73undefined
                jlee73 @Phaedrux
                @phaedrux After doing some more reading I think I’ve got it set up wrong on the M669 code. It should be M669K0. Will try that tomorrow
                  Knnn Kinematics type: 0 = Cartesian, 1 = CoreXY,
                  So it's cartesian, and not corexy?
                  jlee73undefined 1 Reply Last reply Reply Quote 0
                  • jlee73undefined
                    jlee73 @Phaedrux
                    @phaedrux it has to be. K1 would most likely tell the motors on x&y to move at the same time right? But a K0 would allow the x&y motors to move independently correct?
                      What does the belt path for the printer look like? Can you show a photo?
                      This is what a corexy belt setup looks like.
                      830b2d43-d5a8-4198-8222-fab5d99ed54d-simple_belts_corexy_annotated.jpg simple_belts_corexy_annotated.jpg
                      • jlee73undefined
                        jlee73 @Phaedrux
                        @phaedrux Yeah that’s not it at all
                        • jlee73undefined
                          jlee73 @Phaedrux
                          This post is deleted!
                            That is cartesian.
                            • jlee73undefined
                              jlee73 @Phaedrux
                              @phaedrux tomorrow when I get back there I will change it to you M669K0
                              • jlee73undefined
                                jlee73 @Phaedrux
                                @phaedrux That was the entire problem I just got back to the office changed it to him 669K0 and it completely solve the problem thanks for everyone’s help
                                • Phaedruxundefined Phaedrux has marked this topic as solved
