    M584 help needed
    991
    • jlee73undefined
      jlee73 @Phaedrux
      @phaedrux
      No, once everything is homed on dwc, i then try ti use the move "y" by 1,10 or 50 buttons to move the y which is my hotend. when i do that the x axis also moves it should not move at all.
      jlee73undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • jlee73undefined
        jlee73 @jlee73
        @jlee73 it has nothing to do w Z
          Phaedrux Moderator @jlee73
          @jlee73 said in M584 help needed:
          @phaedrux
          The corexy kinematic uses both motors to produce motion. Only 45 degree moves would use a single motor at a time. Is this what you're seeing?
          Again, can you post a video so we can see what you're seeing?
            Your original post says that Z moved.
            but when I tried to move the Y axis the Z motors also move.
            So I'm confused. Please make a video.
            jlee73undefined 2 Replies Last reply Reply Quote 0
            • jlee73undefined
              jlee73 @Phaedrux
              @phaedrux I tried the forum won’t let me upload it because it’s too big
              • jlee73undefined
                jlee73 @Phaedrux
                @phaedrux I meant x moves when I try to move y sorry
                  You'd have to use something like youtube, or vimeo, or google drive, or dropbox, etc. Or a smaller clip in mp4 format.
                  • jlee73undefined
                    jlee73 @Phaedrux
                    @phaedrux I will have to get that to you tomorrow
                      Can you also send M122 and copy and paste the result?
                      • fcwiltundefined
                        fcwilt @jlee73
                        Did you experiment with the X and Y values in M669?
                        • jlee73undefined
                          jlee73 @Phaedrux
                          @phaedrux After doing some more reading I think I’ve got it set up wrong on the M669 code. It should be M669K0. Will try that tomorrow
                            Knnn Kinematics type: 0 = Cartesian, 1 = CoreXY,
                            So it's cartesian, and not corexy?
                            jlee73undefined 1 Reply Last reply Reply Quote 0
                            • jlee73undefined
                              jlee73 @Phaedrux
                              @phaedrux it has to be. K1 would most likely tell the motors on x&y to move at the same time right? But a K0 would allow the x&y motors to move independently correct?
                                What does the belt path for the printer look like? Can you show a photo?
                                This is what a corexy belt setup looks like.
                                830b2d43-d5a8-4198-8222-fab5d99ed54d-simple_belts_corexy_annotated.jpg simple_belts_corexy_annotated.jpg
                                • jlee73undefined
                                  jlee73 @Phaedrux
                                  @phaedrux Yeah that’s not it at all
                                  • jlee73undefined
                                    jlee73 @Phaedrux
                                    This post is deleted!
                                      That is cartesian.
                                      • jlee73undefined
                                        jlee73 @Phaedrux
                                        @phaedrux tomorrow when I get back there I will change it to you M669K0
                                        • jlee73undefined
                                          jlee73 @Phaedrux
                                          @phaedrux That was the entire problem I just got back to the office changed it to him 669K0 and it completely solve the problem thanks for everyone’s help
                                          • Phaedruxundefined Phaedrux has marked this topic as solved
