    New heated enclosure printer
    230
    23.1k
    • cosengundefined
      coseng @sebkritikel
      @sebkritikel OK, thanks for the info. This part just ran overnight, 5hr35min, and I think came out quite good. It is definitely better than the thin wall version and not much heavier and a lot stiffer. The problem is this technique is not applicable to all of the parts. I will do it when possible, but will dedicate today to running some of these calibration processes in the hope of getting both types of parts running well.
      Instead of the ribs of the previous runs, this is modeled as solid with some cutouts for the mounting holes.
      There are a few printing artifacts and hopefully today's activities will help to address them, but I'm very happy with these very usable parts.
      Chris
      Cosentino Engineering
      • cosengundefined
        coseng
        Made and ran a PA test part with geometry similar to my problem areas. This part's toolpaths are one continuous pass per layer, no infill, retractions, etc. 0.8mm nozzle, 0.5mm layer height. 135mm/sec actual print speed.
        It printed mostly great, with the exception of one area:
        The location of this problem points strongly to thermal issues of the extrusion bead cooling, so next on deck is the layer fan.
        The PA test changes were subtle and easier felt with your fingertips and not a camera. Best value seems to be 0.03 where there was the least amount of bulging at the rib ends but no other weirdness at corners and transitions.
        Progress!
        Chris
        cosengundefined 1 Reply Last reply Reply Quote 1
        • cosengundefined
          coseng @coseng
          @dc42 I'm having a little trouble in paradise this evening. I was about to install the layer fan and had modified the system.cfg file to add the two lines for fan definition, and noticed the DWC with the wired internet connection was acting sluggishly. I made an error with the config.sys file in not changing the numbers from 3 to 4 to add the fan. I updated the file by changing those two lines, and I clicked reboot mainboard for the updated config.sys file and presto, the web browser could not reconnect with the printer.
          I did the 'ol printer reboot, and then the paneldue partially booted but had 'connecting' in the upper right corner and the bed temps and other displays were not present and I still had no ethernet connectivity. I did another reboot and the paneldue now did not display anything, just blank with the backlight on.
          Windows says that nothing is plugged in to the internet port and none of the ethernet plug lights are on on either end.
          Before I started messing around and doing something stupid, I was hoping for a little guidance.
          Chris
            Phaedrux Moderator @coseng
            @coseng said in New heated enclosure printer:
            Take a look through this guide and see how far you can get.
            https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
            cosengundefined 1 Reply Last reply Reply Quote 0
            • cosengundefined
              coseng @Phaedrux
              @phaedrux Thanks. I see a USB port in devmgr but it is listed as 'USB Serial Device (COM3)' , not any of the options listed in the guide.
              Chris
                Are you able to reach it through a USB serial terminal like YAT?
                • cosengundefined
                  coseng @Phaedrux
                  @phaedrux YAT says access to COM3 is denied. The last time I used YAT was to set the 6HC up so the setting should be the same.
                  Chris
                    What LEDs are lit when power is applied, either through VIN or USB?
                    cosengundefined 2 Replies Last reply Reply Quote 0
                    • cosengundefined
                      coseng @Phaedrux
                      @phaedrux The proper LEDs from the recover guide are lit. I reinstalled the windows drivers and now have 'Duet3 Motion control Electronics (COM3)' listed in devmgr and can connect in YAT. A M115 gives me this response:
                      'FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-03-15 18:57:26
                      ok'
                      Chris
                      • cosengundefined
                        coseng @Phaedrux
                        @phaedrux OK, I was able to use the 'fallback procedure #1' from the recovery guide, copied the 3.4.1 files to the sd card, performed the update with yat, then did a M115 and received the confirmation with the updated firmware version. Still get nothing from the ethernet connection and DWC. No lights on the ethernet port and Windows says the cable is unplugged. Paneldue is still blank. One slow blinking LED between SD card and reset switch, then the group of 4 leds, green, red, orange, blue, are all solid lit.
                        Chris
                          Are the files on the SD card still intact?
                          It almost sounds like it's not reading the SD card, or config.g files.
                          Can you try sending some commands over YAT to see if you can bring up networking and the paneldue?
                          M552 S1 (or whatever you're using for networking)
                          M575 P1 B57600 S1 for the paneldue.
                          • cosengundefined
                            coseng @Phaedrux
                            @phaedrux SD card is readable but the config.sys was empty. I copied the .old file to overwrite it. Reinserted the SD card, now have green LEDs on the network port but still can't connect to dwc. Am using fixed IP of 168.192.2.1 and confirmed using yat and a M552. I can ping it from a command prompt and get replies. Paneldue is still blank, even if i send a M575 P1 B57600 S1 and get an ok confirmation.
                            Chris
                            • cosengundefined
                              coseng @Phaedrux
                              @phaedrux OK, go tthe network working and can connecto via DWC and the fan modifications to the config.g are still there so hopefully the rest of the configuration is correct.
                              The paneldue is still blank. Config.g is:
                              ; Configuration file for Duet 3 (firmware version 3.3)
                              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 14 2022 23:29:28 GMT-0400 (Eastern Daylight Time)
                              M550 P"hyperprinter" ; set printer name
                              M669 K1 ; select CoreXY mode
                              M564 H0 ; allow moves before homing
                              ; Wait a moment for the CAN expansion boards to start
                              G4 S2
                              M552 P192.168.2.1 S1 ; enable network and set IP address
                              M553 P255.255.255.0 ; set netmask
                              M554 P192.168.2.20 ; set gateway
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M569 P0.1 S0 ; physical drive 0.1 goes forwards
                              M569 P0.2 S0 ; physical drive 0.2 goes forwards
                              M569 P121.0 S1 ; physical drive 121.0 goes forwards
                              M584 X0.1 Y0.2 Z0.0 E121.0 ; set drive mapping
                              M350 X128 Y128 Z8 E16 I1 ; configure microstepping with interpolation
                              M92 X56.14 Y56.14 Z320.00 E837.00 ; set steps per mm
                              M566 X500.00 Y500.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X50000.00 Y50000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
                              M201 X10000.00 Y10000.00 Z50.00 E3000.00 ; set accelerations (mm/s^2)
                              M906 X300 Y300 Z5900 E1500 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S20 ; Set idle timeout
                              M572 D0 S0.03
                              ; CLEARPATH STEPPER TIMING
                              M569 P1 R1 T2
                              M569 P2 R1 T2
                              M208 X-300 Y-250 Z0 S1 ; set axis minima
                              M208 X300 Y250 Z950 S0 ; set axis maxima
                              M574 X2 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io2.in
                              M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
                              M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
                              M558 P9 C"121.io0.in" H5 F120 A1 T20000 ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X-2.31 Y-13.53 Z2.91 ; set Z probe trigger value, offset and trigger height
                              M557 X-290:290 Y-240:224 S116 ; define mesh grid
                              M308 S0 P"temp0" Y"pt1000" ; configure sensor 0 as PT1000 on pin temp0
                              ; M307 H0 R0.379 K0.064:0.000 D4.11 E1.35 S1.00 B0 OLD FROM FIRST TUNING RUN
                              M307 H0 R0.158 K0.054:0.000 D37.27 E1.35 S1.00 B0 ; FROM SECOND TUNING RUN WITH BED MOUNTED SENSOR
                              M308 S1 P"temp1" Y"thermistor" T1000 ; configure sensor 3 as two 500 ohm thermistors in series on pin temp1
                              M950 H1 C"out1" T1 ; create chamber heater output on out1 and map it to sensor 1
                              M307 H1 R0.292 K0.731:0.000 D3.86 E1.35 S1.00 B0 ; FROM FIRST TUNING RUN
                              M141 H1 ; map chamber to heater 1
                              M143 H1 S150 ; set temperature limit for heater 1 to 150C
                              M308 S2 P"121.temp0" Y"pt1000" ; configure sensor 2 as PT1000 on pin 121.temp0
                              M950 H2 C"121.out0" T2 ; create nozzle heater output on 121.out0 and map it to sensor 2
                              M307 H2 R1.544 K0.166:0.000 D6.33 E1.35 S1.00 B0 V23.1 ; FROM FIRST TUNING RUN
                              M143 H2 S320 ; set temperature limit for heater 2 to 320C
                              M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                              M106 P0 C"Chamber 1" S1 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                              M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
                              M106 P1 C"Chamber 2" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                              M950 F2 C"121.out2" Q500 ; create fan 2 on pin 121.out2 and set its frequency
                              M106 P2 C"XY Extruder" S1 H-1 ; set fan 2 name and value. Thermostatic control is turned off
                              M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
                              M106 P3 C"Water Cooler" S1 H-1 ; set fan 3 name and value. Thermostatic control is turned off
                              M950 F4 C"121.out1" Q500 ; create fan 4 on pin 121.out1 and set its frequency
                              M106 P4 C"Layer fan" S1 H-1 ; set fan 4 name and value. Thermostatic control is turned off
                              M563 P0 S"xyhead" D0 H2 F2 ; define tool 0
                              ; Custom settings
                              M950 D1 C"spi.cs0+spi.cs2"
                              Chris
                              • cosengundefined
                                coseng @coseng
                                @Phaedrux Even though the paneldue is blank I can access the files on the sd card.
                                Chris
                                • cosengundefined
                                  coseng @coseng
                                  OK, updated the paneldue firmwware through dwc and now it all seems good again. Phew! Thanks for the help. I wonder what happened.
                                  Chris
                                    When you updated the firmware to 3.4.1 did you manually update the dwc files to match?
                                    What firmware version was on there before?
                                    I think you figured it out but sounds like version mismatches.
                                    • cosengundefined
                                      coseng @Phaedrux
                                      @phaedrux Oops, no, but I did not do anything after getting it working again, wlll do that now. Previous version was 3.4.0 for the 6hc and dwc.
                                      Chris
                                        What PanelDue firmware did you land on?
                                        • cosengundefined
                                          coseng @Phaedrux
                                          @phaedrux I updated the paneldue and the 1LC toolboard to be 3.4.1 so all the components were at the same level. Happily printing away again. Thanks!
                                          Chris
                                          • cosengundefined
                                            coseng
                                            Oh yea! Finally after running this part about 20 times, here's a great final result. It is not the first white part, so was not a material swap fix.
                                            It's just about as perfect a part as I can expect. The grooves on the backside are for 1/2" square steel tube for a small reinforcement frame that will be epoxied in and bolted inline with the two mounting holes so these parts will actually be used on the racetrack at up to 160mph.
                                            The last few final changes were all thermal:
                                            -added a layer fan, off for first 30% of build, then increasing to 75% at 75% of build.
                                            -reduced the chamber temp as the build progressed, 50C to start, 45C midway, then 40C at 75%.
                                            -increased minimum layer time from 10sec to 20 sec. Build time was 7hr2min.
                                            My take away from all this testing is that although it is often said to use minimal layer cooling on ABS, I suspect that this is for machines without a good thermal enclosure, which seems to make a big difference. I think that my air/temp mixing in the chamber is not that good, or the thermal gradient is just too big to keep constant with a thin bellows top with a gap for the printhead, or my sensor positions are reading low, or all of the above. With a 50C chamber setpoint, the bed sensor reads is 93 (set for 90) and the SSR never goes on. With a 45C chamber the bed is 92, with a 40C chamber, 91. So I am getting great heat retention to the point of excess, where the chamber heaters are heating the bed. Which really just means I have to figure out those numbers for this printer. Or maybe the heater tuning should be with all configurations of the various heaters on and off, but then it gets pretty complex and more likely to mess things up.
                                            Once things get up to temp they are quite stable so I don't want to mess with it too much. So I’m getting there. Hopefully a revised layer fan will reduce the amount of heat soak, for lack a better term, and allow me to do 10sec layers instead of 20sec. Or I’ll just print two parts at a time. But for now, it is 235/90/50 to start, then dropping to 230/90/45 at the midpoint, then 220/90/40 for the end. Max speed on the big layers is 150mm/s, down to about 40mm/sec on the small layers.
                                            Thanks again to all for the help!
                                            Chris
