    Motors move wrong way
    784
      droftarts administrators @tecno
      @tecno check the individual motor moves for delta here: https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_testing#checking-movement-direction
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @droftarts
        @droftarts said in Motors move wrong way:
        Guess what, all axis move as commanded in the test BUT in DWC it is the opposite.
        • Dougal1957undefined
          Dougal1957
          @tecno with a simple diagram can you show us the motor positions when looking down on the delta from above similar to
          Z
          X Y.
          Also post your full Config.g
          Doug
          • tecnoundefined
            tecno @Dougal1957
            @dougal1957
            ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue May 31 2022 17:03:35 GMT+0200 (centraleuropeisk sommartid)
            M575 P1 S0 B57600                             ; enable support for PanelDue
            G90                                           ; send absolute coordinates...
            M83                                           ; ...but relative extruder moves
            M550 P"BigDelta"                              ; set printer name
            M665 R300 L615 B275 H570                      ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0                                 ; put your endstop adjustments here, or let auto calibration find them
            M669 S1 T1  								  ; kinematics linear delta
            M564 H0 S0									  ; allow axis movement not homed
            ; Wait a moment for the CAN expansion boards to start
            G4 S2
            M551 P"bengt"                                 ; set password
            M552 P192.168.1.124 S1                        ; enable network and acquire dynamic address via DHCP
            M586 P0 S1                                    ; enable HTTP
            M586 P1 S1                                    ; enable FTP
            M586 P2 S1                                    ; enable Telnet
            ;M569 P40.0 S0 R1  T10:10:10:10                ; physical drive 121.0 goes forwards
            ;M569 P41.0 S0 R1  T10:10:10:10                ; physical drive 122.0 goes forwards
            ;M569 P42.0 S0 R1  T10:10:10:10                ; physical drive 123.0 goes forwards
            ;M584 X40.0 Y41.0 Z42.0 E0.0                   ; set drive mapping
            M569 P0 S0
            M569 P1 S1
            M569 P2 S1
            M569 P3 S1
            M584 X3 Y2 Z1 E0
            M350 X16 Y16 Z16 E16 I1                       			  ; configure microstepping with interpolation   X16 Y16 Z16
            M92 X40.00 Y40.00 Z40.00 E663.00              ; set steps per mm
            M566 X120.00 Y120.00 Z120.00 E1200.00      ; set maximum instantaneous speed changes (mm/min)
            M203 X800.00 Y800.00 Z800.00 E1200.00   ; set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z1000.00 E1000.00      ; set accelerations (mm/s^2)
            M906 X1500 Y1500 Z1500 E800 I30               ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                       ; Set idle timeout
            M208 Z0 S1                                    ; set minimum Z
            M574 X2 S1 P"40.io1.in"                      ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
            M574 Y2 S1 P"41.io1.in"                      ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
            M574 Z2 S1 P"42.io1.in"                      ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
            M558 P5 R0.4 C"io3.in+io4.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
            G31 P500 X0 Y0 Z2.5                           ; set Z probe trigger value, offset and trigger height
            M557 R85 S20                                  ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B4138  ; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out0" T0                            ; create bed heater output on out0 and map it to sensor 0
            M307 H0 B1 S1.00                              ; enable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                       ; map heated bed to heater 0
            M143 H0 S120                                  ; set temperature limit for heater 0 to 120C
            M308 S1 P"temp1" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin temp1
            M950 H1 C"out1" T1                            ; create nozzle heater output on out1 and map it to sensor 1
            M307 H1 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S280                                  ; set temperature limit for heater 1 to 280C
            M950 F0 C"out5" Q500                          ; create fan 0 on pin out3 and set its frequency
            M106 P0 S0 H-1                                ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"out4" Q500                          ; create fan 1 on pin out4 and set its frequency
            M106 P1 S1 H1 T45                             ; set fan 1 value. Thermostatic control is turned on
            M563 P1 D0 H1 F0                              ; define tool 1
            G10 P1 X0 Y0 Z0                               ; set tool 1 axis offsets
            G10 P1 R0 S0                                  ; set initial tool 1 active and standby temperatures to 0C
            ;M501                                          ; load saved parameters from non-volatile memory
            T1
            Z back
            X left front
            Y right front
              Dougal1957 @tecno
              @tecno In that case I think your M584 is in the wrong sequence as George said above try
              M584 X1 Y2 Z3 E0 assuming that the motors are connected to X Y and Z ports in that order.
              • tecnoundefined
                tecno @Dougal1957
                @dougal1957
                Sorry but there is no reason to have X on port 1 !
                Anyhow I did that and edit config and switched motor wires = Still same problem
                Will try to switch motor wires on one winding to see if it helps.
                //edit No it did not
                Dougal1957undefined oliofundefined 2 Replies Last reply Reply Quote 0
                  Dougal1957 @tecno
                  @tecno said in Motors move wrong way:
                  @dougal1957
                  Your config order of the M569 P1 to P3 suggests that the motors are connected to ports 1 2 and 3 in XYZ order tho
                  Maybe reverse the order of them may solve your issue because your motors all move in the correct way when individually commanded it has to be a config issue!
                  Argh sorry that order I don't think matters but I think it is still worth trying.
                  Just looked up M584 and wonder if this maybe your issue.```
                  tecnoundefined 2 Replies Last reply Reply Quote 0
                  • oliofundefined
                    oliof @tecno
                    if you switch the configuration and the wiring at the same time, the problem will persist. Do one or the other.
                      Dougal1957
                      Also remember that in Delta kinematics all 3 axis have to move for any movement in the cartesian plane.
                      • tecnoundefined
                        tecno @Dougal1957
                        @dougal1957
                        I have tried all possibly settings
                        • tecnoundefined
                          tecno @Dougal1957
                          @dougal1957
                          So M584 line has to be X0 Y1 Z2 and E4 or E5 or just E4 no x/y/z?
                          tecnoundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                          • tecnoundefined
                            tecno @tecno
                            I feel like fool now 😞
                            Been looking at the carriage motion not head motion = NOOB with Delta 😉
                            All appears to move as it should.
                              Dougal1957 @tecno
                              @dougal1957
                              I am just about to go out but I will get you a copy of my Config.g
                              M575 P1 S1 B57600                                   ; enable support for PanelDue
                              M550 P"Delta"                                       ; set printer name
                              M665 R239.403 L450.7 B175 H401                      ; Set delta radius, diagonal rod length, printable radius and homed height
                              M552 S1                                             ; enable network
                              M586 P2 S0                                          ; disable Telnet
                              M569 P0 S1                                          ; physical drive 0 goes forwards
                              M569 P1 S1                                          ; physical drive 1 goes forwards
                              M569 P2 S1                                          ; physical drive 2 goes forwards
                              M569 P3 S1                                          ; physical drive 3 goes forwards
                              M584 X0 Y1 Z2 E3                                    ; set drive mapping
                              M92 X200.00 Y200.00 Z200.00 E2500.00                ; set steps per mm
                              M566 X54000.00 Y54000.00 Z54000.00 E2400.00         ; set maximum instantaneous speed changes (mm/min)
                              M203 X1080000.00 Y1080000.00 Z1080000.00 E144000.00 ; set maximum speeds (mm/min)
                              M201 X1000.00 Y1000.00 Z1000.00 E120.00             ; set accelerations (mm/s^2)
                              M906 X1000 Y1000 Z1000 E500 I30                     ; set motor currents (mA) and motor idle factor in per cent
                              M574 X2 S1 P"xstop"                                 ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                              M574 Y2 S1 P"ystop"                                 ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                              M574 Z2 S1 P"zstop"                                 ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
                              M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
                              G31 P500 X0 Y0 Z0.1                                 ; set Z probe trigger value, offset and trigger height
                              M308 S0 P"spi.cs2" Y"rtd-max31865" F50
                              ;M308 S0 P"bedtemp" Y"thermistor" T100000 B4138      ; configure sensor 0 as thermistor on pin bedtemp
                              M950 H0 C"bedheat" T0                               ; create bed heater output on bedheat and map it to sensor 0
                              M307 H0 B0 S1.00                                    ; disable bang-bang mode for the bed heater and set PWM limit
                              M143 H0 S75                                         ; set temperature limit for heater 0 to 75C
                              M308 S1 P"spi.cs1" Y"rtd-max31865" F50
                              ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin e0temp
                              M950 H1 C"e0heat" T1                                ; create nozzle heater output on e0heat and map it to sensor 1
                              M950 F0 C"fan2" Q500                                ; create fan 0 on pin fan0 and set its frequency
                              M950 F1 C"fan1" Q500                                ; create fan 1 on pin fan1 and set its frequency
                              M563 P0 D0 H1 F2                                    ; define tool 0
                              G10 P0 X0 Y0 Z0                                     ; set tool 0 axis offsets
                              G10 P0 R0 S0                                        ; set initial tool 0 active and standby temperatures to 0C
                              T0                                                  ; select first tool
                              • Phaedruxundefined Phaedrux has marked this topic as solved
