    Displaying current extrusion volume possible?
    Duet Web Control wishlist
    tuning volumetric extrusion
    12
    18
    1.2k
    • Chrissundefined
      Chriss @Argo
      +1 This would be nice. And I ask for a Endstop status too!
      samlogan87undefined 1 Reply Last reply Reply Quote 2
      • ramisthand76undefined
        ramisthand76
        yes, this is really good
        https://tutuappvip.co/mobdro-download
        https://myfiosgateway.one/
        • samlogan87undefined
          samlogan87 @Chriss
          @chriss end stop status is there. You need to install the external plugin for dwc and it shows up under machine I think it is
          Custom Core-XY
          Chrissundefined 1 Reply Last reply Reply Quote 0
          • Chrissundefined
            Chriss @samlogan87
            @samlogan87 Do you have a link to the external plugin by hand?
            • chrishammundefined
              chrishamm administrators @Chriss
              @chriss https://github.com/Duet3D/DSF-Plugins/releases/tag/v3.4.0
              Duet software engineer
              • moth4017undefined
                moth4017
                i would like to see extrusion volume too
                jackantubisundefined 1 Reply Last reply Reply Quote 0
                • jackantubisundefined
                  jackantubis @moth4017
                  Yes for me too 🙂
                    deckingman @o_lampe
                    @o_lampe said in Displaying current extrusion volume possible?:
                    Hi guys,
                    I'm playing with my new extruder and would like to know how much it extrudes in a real print.
                    Is it possible to display extrusion volume in DWC? Printspeed, layerheight and layerwidth? should be available for calculations.
                    I extruded in free air to get ballpark numbers, but real life is different.
                    What should the update criteria or interval be? i.e do you want volume per second say, or volume per n mm of head travel or volume per move or volume for the entire print? A simplified calculation would be the cross sectional area of the filament x the extruder travel.
                    Adamfilipundefined 2 Replies Last reply Reply Quote 0
                    • Adamfilipundefined
                      Adamfilip @deckingman
                      @deckingman current flow mm3/s updates once per second
                        @deckingman
                        Even adding a new Chart (new tab on top of existing layer chart) showing volume flow over time, similar to layer chart, so we could see entire time of print job or just last 30 seconds charted would be sweet
                        • oliofundefined
                          oliof @Adamfilip
                          Since extrusion is rarely consistent over a full second on prints of common complexity due to curves, corners, layer changes, overhangs, bridges, infill, inner walls, and outer walls running at various speeds, showing you a sample of what flow was maybe one second ago seems of very little use to me.
                          The only time it would be useful to me is when I try to determine the max flow of filament at a given temperature whichextrus is part of a tuning routine, where a realtime display also is not super helpful since you can play it by ear/eye it with a simple visual flag on your filament feeder showing when skips start to happen.
                          I tend to look at the volumetric flow preview in Cura to ensure I didn't configure anything stupid, since if I were to see it while something prints its usually already too late. That could have some improvements (like "show extrusion rate where I point with the mouse") though ...
                            deckingman @Adamfilip
                            @adamfilip Given the variability of the volumetric flow rate, even within a single move (due to factors such as acceleration and deceleration) what would you do with the information? How would it be useful?
                              jackantubis
                              Yes for me it's max flow calibration of each new filament (avoid manual calculation). Sometimes too much monitoring is too much but love to see parameters flowing during print 🙂
                              • o_lampeundefined
                                o_lampe
                                I want to bump up this thread, since I'm tinkering with a toolchanger and want to optimize print settings for different nozzle sizes.
                                I also saw that PrusaSlicer (and surely others too) changes extrusion width often.
                                It's mentioned as a comment in the gcode file.
                                ;WIDTH:0.727092
                                Q: would it be possible to see the current extrusion width in the object model? Or extract it somehow?
