Weird Issue with Duet Wifi Wifi connection
1.6k
    Norder @GBusy24
    This post is deleted!
      Norder @GBusy24
      @gbusy24 said in Weird Issue with Duet Wifi Wifi connection:
      @phaedrux It is my x endstop switch. @Phaedrux I'm glad I'm having this conversation with you because what brought about these issues is the fact that I have been revamping my print carriage setup and changing from E3D V6 to Titan Aero and I printed your remix of a carriage on Thingiverse. I couldn't figure out how to wire the switch minus the PCB, so I did this. Can you share with me how to wire the switch directly to the board W/O using the PCB?
      https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_endstops
      undefined 1 Reply Last reply 16 Jul 2022, 00:31 Reply Quote 1
        GBusy24 @Norder
        @günter-jibben Wow, Thanks! Didn't know this info was out there.
        No such thing as spare time. No such thing as free time No such thing as down time. All you got is lifetime. Go!
          Cool to see you've printed the carriage. I think you've got it sorted now though. The switch by itself doesn't actually require the PCB at all.
          undefined 1 Reply Last reply 16 Jul 2022, 10:26 Reply Quote 0
            GBusy24 @Phaedrux
            @phaedrux Thank you. Not sure how to interpret this.Screenshot (37).png Sure could use a diagram.
            undefined 1 Reply Last reply 16 Jul 2022, 11:24 Reply Quote 0
              engikeneer @GBusy24
              @gbusy24 outer 2 pins on the switch to the outer 2 pins on the Duet WiFi endstop plug. Doesn't matter which one goes to which, just don't connect the middle pins on either 🙂
              i3 clone with a bunch of mods
              undefined 3 Replies Last reply 16 Jul 2022, 11:50 Reply Quote 0
                GBusy24 @engikeneer
                @engikeneer okay, great. Thank you
                  GBusy24 @engikeneer
                  @engikeneer I was able to put e-thing back togather last night and the Xstop wiring is correct now, but it is showing triggered when it's not and I thought the fix for this was changing the M574 command from S1 to S0 or vice versa, but that's not working. What am I doing wrong now?
                    GBusy24 @engikeneer
                    @engikeneer ; Configuration file for Duet WiFi (firmware version 3.3)
                    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 24 2022 20:50:56 GMT-0500 (Eastern Standard Time)
                    M550 P"CoreXY 1" ; set printer name
                    M669 K1 ; select CoreXY mode
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P1 S0 ; physical drive 1 goes forwards
                    M569 P3 S0 ; physical drive 3 goes forwards
                    M92 X80.00 Y80.00 Z400.00 E852 ; set steps per mm
                    M203 X6000.00 Y6000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min)
                    M906 X800 Y800 Z800 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X320 Y185 Z300 S0 ; set axis maxima
                    M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                    M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                    M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
                    M574 Z1 S2 ; Define Z to use Probe. Home to Min
                    M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                    M558 P9 C"^zprobe.in" H5 F120 T6000
                    G31 P500 X-41.8 Y32.2 Z2.2
                    M557 X10:320 Y0:190 S50 ; define mesh grid
                    M307 H0 R0.495 K0.404:0.000 D4.40 E1.35 S1.00 B0; disable bang-bang mode for the bed heater and set PWM limit
                    M501
                    undefined 1 Reply Last reply 17 Jul 2022, 17:22 Reply Quote 0
                      engikeneer @GBusy24
                      @gbusy24 you want to remove the exclamation mark from the pin name as that inverts the signal.
                      The S parameter sets the type of endstop, so should be S1 for X and Y.
                      You have also set your locations to be low end for x (I.e. the endstop is at x=0) and high end for Y (I.e. the endstop is at y=185). That is set by the X & Y parameters respectively.
                      See the docs for more details
                      https://docs.duet3d.com/User_manual/Reference/Gcodes#m574-set-endstop-configuration
                      undefined 1 Reply Last reply 17 Jul 2022, 18:19 Reply Quote 0
                        GBusy24 @engikeneer
                        @engikeneer I tried removing the ! And it didn't change anything. Yes I have my Y set up like that because my end stop is at the back of the bed. I will give all this a look over again to try and figure out what I'm doing wrong and get back with you. I appreciate your response.
                        39 out of 40
