    Prints are warping
    73
    4.3k
    • engikeneerundefined
      engikeneer @TRATOON
      @tratoon if you are using a probe, you shouldn't be using G92.
      Set the z offset of your probe correctly in G31 in config.g. your z axis will be set to this value when the probe triggers
      i3 clone with a bunch of mods
      TRATOONundefined 3 Replies Last reply Reply Quote 0
      • TRATOONundefined
        TRATOON @engikeneer
        @engikeneer But to get a Z offset, don't I need to tell the printer where Z0 is and isn't G92 telling the printer where Z0 is?
        engikeneerundefined 1 Reply Last reply Reply Quote 0
        • TRATOONundefined
          TRATOON @engikeneer
          @engikeneer So will my printer always set Z0 to where the probe is triggered, and I have to ell it (using the Z offset) where to put the nozzle in relation to the Z0, set by the probe?
          • TRATOONundefined
            TRATOON @engikeneer
            @engikeneer And how do I stop a " the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
            30 points probed, min error -1.656, max error -1.329, mean -1.461, deviation 0.088
            Height map saved to file 0:/sys/heightmap.csv" warning?
              engikeneer @TRATOON
              @tratoon you can use G92 once when determining the z offset, but not after.
              My preferred approach is to set G31 Z0 (I.e. zero offset). Then probe the centre of the bed with a single G30. Then move z down until the nozzle just touches your bed. For a BLTouch, should be 1-2mm ish. Whatever that value is goes in G31 Z
              You can then tweak it a little bit if you find your first layer is too squished, or not squished enough
              TRATOONundefined 1 Reply Last reply Reply Quote 0
              • TRATOONundefined
                TRATOON @engikeneer
                @engikeneer Thank you very much, that solved my problem
                engikeneerundefined 1 Reply Last reply Reply Quote 1
                  engikeneer @TRATOON
                  @tratoon re the warning message on the heightmap, you need to home z using your probe before creating your heightmap and before you load it. If you don't, it doesn't know where z=0 is (or thinks it's in the wrong place) so the heightmap ends up offset
                  • TRATOONundefined
                    TRATOON @engikeneer
                    @engikeneer I just needed to set the Z Offset, what you are saying doesn't make sense, as the printer won't probe unless all axis are homed.
                      engikeneer @TRATOON
                      @tratoon yes thats right.
                      However if you use a G92 Z0, or home Z with an endstop instead of the probe, it will allow you to run mesh, but you may get the error
                      Also, now you have created a mesh, you don't have to reprobe the whole bed every print, you can just load the existing heightmap that is now saved to the SD card with G29 S1. I have a 400 point mesh for my printer that takes over an hour to run, but is stable enough that I only have to redo it if I take the printer to pieces. I just have to make sure I home z with the BLTouch before I load the heightmap for each printer.
                      • TRATOONundefined
                        TRATOON @engikeneer
                        @engikeneer , @infiniteloop, @Günter-Jibben I just started a print, and I used baby stepping to lower the nozzle during the first layer. However, when the second layer started printing, the nozzle was too low and was scraping the part, and that caused my filament sensor to pause the print as it was at 2% extrusion. Why is it that the nozzle had to be lower for the first layer but higher for all the layers after that. For the first layer, the babystep offset was -0.20, and for the layers after that, it had to be 0.04 is this normal, because I don't have this issue on my other 3D printers.
                        • infiniteloopundefined
                          infiniteloop @TRATOON
                          @tratoon said in Prints are warping:
                          For the first layer, the babystep offset was -0.20, and for the layers after that, it had to be 0.04 is this normal?
                          Definitely not. Either the steps/mm for Z are wrong, or the nozzle pushed the bed down on the first layer. A third reason I can imagine are wrong settings in the slicer (1st layer height?).
                          • TRATOONundefined
                            TRATOON @infiniteloop
                            @infiniteloop first layer height is 0.3 rest are .25
                            • TRATOONundefined
                              TRATOON @TRATOON
                              Nozzle didn't push bed down as the nozzle was 2mm higher than the bed
                              • TRATOONundefined
                                TRATOON @TRATOON
                                And on the fifth layer or so, it completely stopped extruding. And I had to push filament into the extruder and then it would extrude. What is going on?
                                alankilianundefined Norderundefined 2 Replies Last reply Reply Quote 0
                                • alankilianundefined
                                  alankilian @TRATOON
                                  @tratoon Is it possible you have the wrong filament diameter set in your slicer?
                                  Or you have extrusion set to some amount other than 1.0?
                                  Can you post the STL and GCODE for your 20mm block again and I'll compare to my settings.
                                  • TRATOONundefined
                                    TRATOON @alankilian
                                    @alankilian Which 20mm block?
                                    • TRATOONundefined
                                      TRATOON @alankilian
                                      @alankilian Here is a XYZ calibration cubeCube.gcode
                                      20220711_XYZ_Calibration_Cube.stl
                                      • TRATOONundefined
                                        TRATOON @alankilian
                                        @alankilian My filament diameter is correct. I looked up "extrusion" in Cura no relevant setting, so by that, I think you mean flow, which is set to 100%
                                        • SpoonUnitundefined
                                          SpoonUnit
                                          Some thoughts...
                                          Would be interesting to see a print of only the first layer. If the nozzle height isn't right, and the first layer isn't spot on, that can lead to warping.
                                          I can't see at a glance from the thread whether you ever put the filament you're using in. The level of warpage makes me think it's ABS. Having the right bed heat and the right nozzle temp are crucial whatever the filament, but ABS I find to be quite picky on PEI. Also, the temp the bed reports is not always the actual bed surface temp. Personally I print ABS at 250C on a bed temp of 125 for the first layer and it prints pretty well as long as the geometry isn't fighting a good print.
                                          Sharp corners can lead to warping. While you're tuning, trying working with a cube with rounded edges instead of square edges. If you absolutely, positively, MUST print square corners, make your first layer super slow to try to avoid lifting.
                                          • TRATOONundefined
                                            TRATOON @SpoonUnit
                                            @spoonunit I'm almost 90% sure I fixed the warpage issue as before I could see warping on the 3rd layer, but now it is gone. My problem now is that somehow, my Z-Offset is different for the first layer and filament stops coming out at the 5th layer, and I have to reload the filament and resume the print. I'm printing PLA at 205C (nozzle) and 65C (bed). Any help would be greatly appreciated.
                                            SpoonUnitundefined 1 Reply Last reply Reply Quote 0
