    Prints are warping
    73
    4.3k
    • TRATOONundefined
      TRATOON @engikeneer
      @engikeneer I just needed to set the Z Offset, what you are saying doesn't make sense, as the printer won't probe unless all axis are homed.
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @TRATOON
        @tratoon yes thats right.
        However if you use a G92 Z0, or home Z with an endstop instead of the probe, it will allow you to run mesh, but you may get the error
        Also, now you have created a mesh, you don't have to reprobe the whole bed every print, you can just load the existing heightmap that is now saved to the SD card with G29 S1. I have a 400 point mesh for my printer that takes over an hour to run, but is stable enough that I only have to redo it if I take the printer to pieces. I just have to make sure I home z with the BLTouch before I load the heightmap for each printer.
        i3 clone with a bunch of mods
        TRATOONundefined 1 Reply Last reply Reply Quote 0
        • TRATOONundefined
          TRATOON @engikeneer
          @engikeneer , @infiniteloop, @Günter-Jibben I just started a print, and I used baby stepping to lower the nozzle during the first layer. However, when the second layer started printing, the nozzle was too low and was scraping the part, and that caused my filament sensor to pause the print as it was at 2% extrusion. Why is it that the nozzle had to be lower for the first layer but higher for all the layers after that. For the first layer, the babystep offset was -0.20, and for the layers after that, it had to be 0.04 is this normal, because I don't have this issue on my other 3D printers.
          • infiniteloopundefined
            infiniteloop @TRATOON
            @tratoon said in Prints are warping:
            For the first layer, the babystep offset was -0.20, and for the layers after that, it had to be 0.04 is this normal?
            Definitely not. Either the steps/mm for Z are wrong, or the nozzle pushed the bed down on the first layer. A third reason I can imagine are wrong settings in the slicer (1st layer height?).
            • TRATOONundefined
              TRATOON @infiniteloop
              @infiniteloop first layer height is 0.3 rest are .25
              • TRATOONundefined
                TRATOON @TRATOON
                Nozzle didn't push bed down as the nozzle was 2mm higher than the bed
                • TRATOONundefined
                  TRATOON @TRATOON
                  And on the fifth layer or so, it completely stopped extruding. And I had to push filament into the extruder and then it would extrude. What is going on?
                  alankilianundefined Norderundefined 2 Replies Last reply Reply Quote 0
                  • alankilianundefined
                    alankilian @TRATOON
                    @tratoon Is it possible you have the wrong filament diameter set in your slicer?
                    Or you have extrusion set to some amount other than 1.0?
                    Can you post the STL and GCODE for your 20mm block again and I'll compare to my settings.
                    TRATOONundefined 3 Replies Last reply Reply Quote 0
                    • TRATOONundefined
                      TRATOON @alankilian
                      @alankilian Which 20mm block?
                      • TRATOONundefined
                        TRATOON @alankilian
                        @alankilian Here is a XYZ calibration cubeCube.gcode
                        20220711_XYZ_Calibration_Cube.stl
                        • TRATOONundefined
                          TRATOON @alankilian
                          @alankilian My filament diameter is correct. I looked up "extrusion" in Cura no relevant setting, so by that, I think you mean flow, which is set to 100%
                          • SpoonUnitundefined
                            SpoonUnit
                            Some thoughts...
                            Would be interesting to see a print of only the first layer. If the nozzle height isn't right, and the first layer isn't spot on, that can lead to warping.
                            I can't see at a glance from the thread whether you ever put the filament you're using in. The level of warpage makes me think it's ABS. Having the right bed heat and the right nozzle temp are crucial whatever the filament, but ABS I find to be quite picky on PEI. Also, the temp the bed reports is not always the actual bed surface temp. Personally I print ABS at 250C on a bed temp of 125 for the first layer and it prints pretty well as long as the geometry isn't fighting a good print.
                            Sharp corners can lead to warping. While you're tuning, trying working with a cube with rounded edges instead of square edges. If you absolutely, positively, MUST print square corners, make your first layer super slow to try to avoid lifting.
                            • TRATOONundefined
                              TRATOON @SpoonUnit
                              @spoonunit I'm almost 90% sure I fixed the warpage issue as before I could see warping on the 3rd layer, but now it is gone. My problem now is that somehow, my Z-Offset is different for the first layer and filament stops coming out at the 5th layer, and I have to reload the filament and resume the print. I'm printing PLA at 205C (nozzle) and 65C (bed). Any help would be greatly appreciated.
                              SpoonUnitundefined 1 Reply Last reply Reply Quote 0
                                SpoonUnit @TRATOON
                                @tratoon Personally, I print PLA at 220 for layer 1 and 210 for subsequent layers on a bed of 85 for first layer and 65 for subsequent layers. How confident are you that your bed is reaching temperature? The reason I ask is that, for my bed, the temperature reports as 85 much sooner than the surface of the bed actually reaches that temperature. Adding a significant pause to allow the heat to soak in can help, or, as I do, you can hook up a thermistor to the bed and configure this as a chamber in the Duet and await it to actually reach the target temperature.
                                The fact the filament stops coming out suggests that you are encountering a jam. There are many possible reasons, but one is that the hot end isn't reaching the temperature you set. Another potential reason is over-agressive retraction settings.
                                • Norderundefined
                                  Norder @TRATOON
                                  Check if the extruder is clean... maybe the teeth of the conveyor rollers are clogged with abrasion?
                                  Check whether the pressure (spring tension) of the conveyor rollers is still OK.
                                  Maybe the nozzle was also clogged, this often happens when the retract is set too high, especially with TPU it is the case, so you should print TPU without retract if possible.
                                  Do a PID tuning for the hotend and for the print bed and enter the results in the config.g.
                                  I would also meticulously measure the steps of all axes and the extruder again and correct the values in config.g if necessary.
                                  To rule out problems with the slicer settings, use a standard profile or use a different slicer.
                                  Google Translate
                                  ----- Original Text -----
                                  Kontrolliere ob der Extruder sauber ist... vielleicht sind die Verzahnungen der Förderrollen mit Abrieb verstopft ?
                                  Kontrolliere ob der Andruck (Federspannung) der Förderrollen noch OK ist.
                                  Vielleicht war auch die Düse verstopft, das passiert gerne mal wenn der Retract zu hoch eingestellt ist, besonders bei TPU ist es der Fall, daher soll man TPU wenn möglich ohne Retract drucken.
                                  Mache ein PID-Tuning für das Hotend und für das Druckbett und trage die ermittelten Ergebnisse in der config.g ein.
                                  Ich würde auch die Steps aller Achsen und des Extruders noch einmal penibel vermessen und die Werte wenn nötig in der config.g korrigieren.
                                  Um Probleme der Slicer-Einstellungen ausschließen zu können, nutze ein Standart-Profil oder nutze auch gerne einmal einen anderen Slicer.
                                  DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
                                  Thingiverse
                                  • TRATOONundefined
                                    TRATOON
                                    @günter-jibben @SpoonUnit How do I calibrate steps for all axis and my retraction distance is 0.75mm (I am using E3D's Hemera), at a speed of 45mm/s. I have already tuned hotend and bed.
                                    • TRATOONundefined
                                      TRATOON @TRATOON
                                      @günter-jibben @SpoonUnit Not sure if you looked at my previous posts. I also have an issue where the Z-Offset is varying between layers, How would I solve that problem?
                                      TRATOONundefined Norderundefined 2 Replies Last reply Reply Quote 0
                                      • TRATOONundefined
                                        TRATOON @TRATOON
                                        I just finished calibrating steps, using calibration cube.
                                        • TRATOONundefined
                                          TRATOON @TRATOON
                                          @günter-jibben @SpoonUnit @infiniteloop , I just printed a 0.4 mm high Z-Offset calibration print. The Z-Offset was fine this time, on all the layers. Before the print I tightened the eccentric nut on my carriage so there was no wobble. However, I have noticed that after a few minutes of printing, the carriage wobbles again. What is causing the carriage to wobble, even after adjusting the eccentric nut? And how do I fix it?
                                            @tratoon
                                            … after a few minutes of printing, the carriage wobbles again. What is causing the carriage to wobble, even after adjusting the eccentric nut? And how do I fix it?
                                            Use one wrench to hold the eccentric bolt in position, use another one to tighten the nut. Good-quality tools are the key to success.
