    Issues with pressure advance since RRF 3.4
    308
    39.4k
    • Norderundefined
      Norder
      @argo
      My guess, after looking at the photos all once, is that the problem might be the value of the overlap between fill lines and outside perimeters set in the slicer.
      On all photos where the corner was pushed out, a fill line ends directly on that corner.
      Here, Here and Here
      Pay attention to this area in the last photo...
      One (two ?) photo where it isn't is a Z-seam that has pushed the outside perimeter outwards.
      HERE and probably also HERE !?
      So I would suggest... print the same rectangle WITHOUT the Infill to see if it could be due to the overlap of the infill and the outer wall.
      Or change the percentage of infill so that the infill doesn't end up in the corners.
      If you compare the two pressure parts in the first photo, I would say that the flow is too high in the lower pressure part.
      (The reason could be a different temperature or a different filament diameter or similar.)
      Therefore, determine the flow for the respective filament again and then determine the PA value again.
      You suspect that the update of the RRF can be the reason for this problem.
      Can you say with certainty that you used the exact same filament (same spool) and that ALL the settings were identical?
      A filament can have a different diameter per spool.
      Because other people and even your other printer do not show these problems, I would assume that something has changed between these two printouts, except for an update of the firmware.
      It's just my guesses. 😉
      Text was translated using Google Translate, so some sentences may be harder to understand.
      DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
      Thingiverse
      CCS86undefined Viscoelasticundefined 2 Replies Last reply Reply Quote 0
      • CCS86undefined
        CCS86 @Norder
        @norder
        He can repeat the test printing external perimeters first, to rule that out.
        Norderundefined 1 Reply Last reply Reply Quote 0
        • Norderundefined
          Norder @CCS86
          @ccs86 said in Issues with pressure advance since RRF 3.4:
          @norder
          That would also be a possibility.
          I would omit the infill completely for the test, then the result would be "unadulterated".
          In my opinion, printing the outer walls before the infill would then be a refinement process to optimize the print.
          Thingiverse
          • CCS86undefined
            CCS86
            @norder said in Issues with pressure advance since RRF 3.4:
            @norder
            Why omit the infill? I thought one purpose of this testing was to confirm or deny that PA was working differently in his infill and perimeters?
            If you print external perimeters first, they will not be influenced by the infill, or by perimeter overlap. This should show more directly how PA is handling these outside corners.
            • Viscoelasticundefined
              Viscoelastic @Argo
              @argo said in Issues with pressure advance since RRF 3.4:
              @viscoelastic
              3 corners out of 4 never have any retraction with the test objects I print. Seam is set to aligned so the seam gets placed always at the same corner. To show that the retraction isn’t the culprit I showed one of the other corners which looks the same. This would with my understanding rule out retraction issues. Or did you mean something else and I misunderstood you?
              I think you may have misunderstood me, but not to worry 😊 The only reason I am bringing up retraction (and more specifically negative extra restart distance when doing retractions) is because of the role that will play in trying to assess optimal PA factors and the PA factor in turn then would play a major role in limiting bulging at corners. The retraction settings mentioned before therefore end up playing only an indirect role in determining what can happen at corners. What I am aiming at is to try to get to the highest possible PA factor that will allow proper printing of infill but also produce the greatest reduction of bulging at corners.
              At this stage it is a bit difficult to say from the last image posted whether there is still any scope for increasing PA. This is because when looking at the infill I can see that line starts are still wider than line ends. If the line start widths are reduced by adding a negative extra restart distance to retractions it will be easier to see from the line ends whether you can actually increase the PA factor any further.
                Viscoelastic @Norder
                @argo
                Good observation. It does look as if there may be an excessive infill overlap on the corner which may be pushing it out a bit. If you get your line starts and ends printing correctly then you should also be able to reduce the infill overlap you are using without running into problems with infill not connecting to the perimeter.
                Argoundefined 1 Reply Last reply Reply Quote 1
                • Norderundefined
                  Norder @CCS86
                  I wanted to get to the bottom of the problem of the bulging corners, but the PA doesn't interest me at first.
                  Even if the outer walls are printed first, it can still happen that when the infill is printed, the wall can be deformed as it might still be soft, especially when printing very quickly.
                  And in order to eliminate all these possible falsifications from the outset, one should print without infill.
                  Which really shouldn't be a problem.
                  If the corners then look the way you want them to, you know where the error is and you can try to optimize them with some settings in the slicer, for example by printing the walls before the infill or by setting the infill so that the corners are not deformed can etc. pp
                  Thingiverse
                  • Argoundefined
                    Argo @Viscoelastic
                    @viscoelastic @Norder
                    I’ll just do both tests.
                    One without infill and one with the setting „perimeter first“.
                    But I’m away from my printer right now until tomorrow. So please be patient >)
                    • Argoundefined
                      Argo @Argo
                      Printed all three test object at once. PA was set to 0.055 which is a bit too high imo (see infill lines) but infill / perimeter quality is always a compromise and I try to favour perimeters in this case. Input Shapers are off btw. Enabling those and things get even uglier.
                      Standard settings:
                      @Norder @Viscoelastic
                      Test object without infill:
                      @CCS86
                      Test object with setting "perimeter first":
                      CCS86undefined Norderundefined 2 Replies Last reply Reply Quote 1
                      • CCS86undefined
                        CCS86 @Argo
                        @argo why do you point at the infill intersection break as evidence for PA tuning? There is no PA action at that point, since those are uninterrupted straight lines, which cross.
                        More important would be at changes in direction, but it would be much more helpful if you labeled the direction of travel for each infill line you are considering, since without it you can't guess.
                        Argoundefined 1 Reply Last reply Reply Quote 0
                        • Argoundefined
                          Argo @CCS86
                          @ccs86
                          Because it’s a very good indicator to rate infill quality. At the end PA is a compromise between infill and perimeter quality.
                          One last example with input shaper enabled to show how much it decreases quality further:
                          For me the test and demonstration journey ends here. I could wire the extruder Motor directly to the board though so it does not run over CAN but I feel tired testing and experimenting for now.
                          Until I enjoy experimenting again there is hopefully something that might be a fix or I’ll switch over to Klipper.
                          CCS86undefined 1 Reply Last reply Reply Quote 0
                          • Norderundefined
                            Norder @Argo
                            @argo
                            That looks a lot better.
                            Outside perimeter first and not letting the fill lines end right in the corners delivered a wonderful result.
                            To me it's proof that the extreme bulging was caused by the fill lines ending right in the corners.
                            If you have time and desire to further optimize your printer, turn the IS and PA OFF and first take care of the right flow for each filament you use.
                            A flow that is ideal for all filaments is rather unlikely.
                            In this photo it is wonderful to see that the flow is set too high.
                            (Note the flat surface, it is very uneven, a sign of too much flow)
                            When you set the flow, start at the beginning... extruder steps... filament diameter... test cubes (Link see below) with 100% flow and 100% infill... measure the wall thickness and convert the 100% flow into the correct percentage.
                            If the flow is right again, which it isn't right now, then the appearance of the corners will improve as well.
                            Test cube (20mm x 20mm x 20mm) with four walls of different thickness (0.4mm / 0.8mm / 1.2mm and 1.6mm), ideal for calculating the flow.
                            Calculation of the flow based on the wall thickness...
                            We know how thick the walls are ideally... if we measure 0.46mm for the 0.40mm wall, for example, then we calculate...
                            0.40 x 100 / 0.46 = 86.95
                            NOMINAL value (0.4mm) multiplied by 100 (100%) divided by ACTUAL value (0.46mm) equals new value (86.95%) for the flow
                            The new value for the flow in the slicer would be exactly 86.95%.
                            I would enter 0.87 in the slicer and use this value to print the cube again and measure again.
                            Then break the cube to possibly set 0.9 in the slicer if the cube or the 0.4mm wall doesn't seem stable enough to me.
                            The feeling plays a role here.
                            P.S.:
                            And only when the flow is optimally set for the respective filament would I determine the value for the PA.
                            In the PrusaSlicer you can set the flow for each filament and also the PA value.
                            For me there is also the information how strongly each of the filaments pulls together in order to set an oversize in the slicer if I want to have exact printed parts.
                            Google Translate
                            --- Original Text ---
                            Das sieht doch schon viel besser aus.
                            Außen-Perimeter zuerst und die Fülllinien nicht direkt in den Ecken enden lassen hat doch ein wunderbares Ergebnis geliefert.
                            Für mich ist es der Beweis das die extremen Auswölbungen von den Fülllinien die direkt in den Ecken enden, verursacht wurden.
                            Wenn Du wieder Zeit und Lust hast Deinen Drucker weiter zu optimieren, dann stelle das IS und das PA AUS und kümmere Dich zuerst um den richtigen Fluss für jedes Filament was Du nutzt.
                            Ein Fluss der für alle Filamente ideal ist, ist eher unwahrscheinlich.
                            Auf diesem Foto ist wunderbar zu erkennen dass der Fluss zu hoch eingestellt ist.
                            (Achte auf die ebene Fläche, sie ist sehr uneben, ein Zeichen für zu viel Fluss)
                            Wenn Du den Fluss einstellst, dann fang ganz vorne an... Extruder-Stepps... Filamentdurchmesser... Testwürfel (Link siehe unten) mit 100% Fluss und 100% Infill... messen der Wandstärke und umrechnen des 100% Flusses in die richtige Prozentzahl.
                            Wenn der Fluss wieder stimmt, was er momentan nicht macht, dann verbessert sich auch das aussehen der Ecken.
                            Testwürfel (20mm x 20mm x 20mm) mit vier unterschiedlich dicken Wänden (0,4mm / 0,8mm / 1,2mm und 1,6mm), ideal um den Fluss zu berechnen.
                            Berechnung des Flusses anhand der Wandstärke...
                            Wir wissen wie dick die Wände im Idealfall sind... messen wir zB für die 0,40mm Wand 0,46mm, dann rechnen wir...
                            0,40 x 100 / 0,46 = 86.95
                            SOLLWert (0,4mm) multipliziert mit 100 (100%) dividiert durch ISTWert (0,46mm) gleich neuer Wert (86.95%) für den Fluss
                            Der neue Wert für den Fluss im Slicer wäre exakt 86.95 %.
                            Ich würde 0.87 im Slicer eintragen und mit diesem Wert den Würfel noch einmal drucken und erneut messen.
                            Danach den Würfel zerbrechen um eventuell 0,9 im Slicer einzustellen, falls der Würfel bzw die 0,4mm Wand mir nicht stabil genug erscheint.
                            Hier spielt das Gefühl etwas mit.
                            P.S.:
                            Und erst wenn der Fluss optimal eingestellt ist für das jeweilige Filament, würde ich den Wert für das PA ermitteln.
                            Im PrusaSlicer kannst Du für jedes Filament den Fluss festlegen und auch den PA Wert.
                            Bei mir steht dort auch die Info wie stark sich jedes der Filamente zusammen zieht, um im Slicer eine Übergröße einzustellen wenn ich exakte Druckteile haben möchte.
                            Thingiverse
                            • Argoundefined
                              Argo @Norder
                              @norder
                              Sorry don’t get me wrong but I’m tired running in circles here. The printer is calibrated and PA does not work for me right now.
                              I have explained enough and posted many examples and answered every question several times. It is not the extrusion multiplier and it is not a slicer setting nor the slicer itself.
                              It is how PA works right now. I have asked for pictures from a printed rectangle in the Voron RRF discord and have not seen one print example from others that do look perfect in my eyes. Only answer I got was that RRF has different priorities than looking at corner quality with a magnifying glass.
                              Enabling input shaper and the quality gets worse, not only for me.
                              So yes, maybe I’m too picky but I know what my others printer can do especially that one that doesn’t run RRF.
                              That is why I end it here. If there is promising FW fix in the following weeks that promises PA improvements I’ll try that out. If not I’ll have a small little project to come for the winter season. 🙂
                              • gloomyandyundefined
                                gloomyandy
                                Going back to your original post, I've been trying to investigate what may be happening here (I work on the STM32 port of RRF in my own time and have no formal connection with Duet3D). In your original post you said that the problem had got worse when you switched from RRF3.3 to RRF3.4. If/when you feel inclined to have another look at this (I understand that running tests with no seemingly good outcome is frustrating), I wonder if it would be worth investigating this case more. In particular if it would be worth running a back to back test between 3.3 and the latest 3.4 (on both the main board and on the toolboard), to see how things look now?
                                At the moment I'm concentrating on looking at how PA works when using a toolboard to control the extruder v using the main board (I'm investigating this using my toolchanger that has tools setup using both configurations), but I'm trying to gather as much information as possible to get a better picture as to what is happening.
                                • CCS86undefined
                                  CCS86 @Argo
                                  @ccs86
                                  Can you explain how you think PA affects the intersection of infill lines printed at steady-state speed?
                                  • Argoundefined
                                    Argo @gloomyandy
                                    @gloomyandy
                                    When I switched to RRF 3.4 (beta) I also installed a Duet 1LC toolboard. So my conclusion was it has something to do with RRF 3.4 as I did not think the toolboard had something to do with it. So I compared an old print (without toolboard) and RRF 3.3 with a print that I made with RRF 3.4 (+ Duet 1LC).
                                    Both printed with RRF 3.3 and RRF 3.4 with the toolboard installed:
                                    Difference is only marginal between both FW versions. My suspicious for now is the CAN toolboard.
                                    @CCS86
                                    Just print a small rectangle object with any filament and double the PA value you usually use. Infill lines won't connect with walls and also not within each other when using "Grid" filament type. Images from test prints are already in this thread from me.
                                    • CCS86undefined
                                      CCS86 @Argo
                                      @CCS86
                                      Connect to the walls sure, because there are direction changes there, where PA is active. But, grid intersections some number of millimeters from a wall should not be affected.
                                      • Argoundefined
                                        Argo @CCS86
                                        @ccs86
                                        You can see here what happens when PA is far too high:
                                        • brunofportoundefined
                                          brunofporto
                                          I am having several issues with PA too.... The test using the python script have bulges AND under extrusion even on very high values of PA.
                                          Here an example for PLA from 0.5 to 0.9 - The bulge NEVER disappear even when the under extrusion after starts to show.
                                          In the past there always a clear transition where the slow segments had the same width and no under extrusion after.
                                          Also I simply cannot find a value of PA + Retract that lead to good results. It starts to to cause excessive retraction and blocking issues much before solving any oozing.
                                          I reviewed all my hardware looking for possible issues and after finding this thread I think it is related.
                                          It is very severe with small details and curved surfaces (like round small posts for retraction tuning) it is so severe that sometimes and entire layer is mission while others spurts excessive material. For straight lines - like a small cube walls - only the bulge is apparent and the under extrusion after the bulge for higher PA.
                                          I had not updated my board for a long time and the issues started after the update to 3.4 - I do not remember what older version I had before.
                                          But the issues are the same: Excess extrusion even with very high PA with under extrusion right after for higher PA. I had not of these issues before.
                                          I will test 3.4.2 now and then roll back to 3.3 and repeat the Python script test to compare.
                                          brunofportoundefined dc42undefined 2 Replies Last reply Reply Quote 2
                                            brunofporto @brunofporto
                                            @brunofporto
                                            Ok... No differences at all from the same gcode from PA 0.5 to 1.3 with 3.3 and 3.4.2 😥
                                            Phaedruxundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
