    Automatic Emergency Stop
    1.1k
      jay_s_uk @Sculpt Fabricator
      @sculpt-fabricator not much we can do now until the reset map is looked at.
        droftarts administrators @Sculpt Fabricator
        @sculpt-fabricator said in Automatic Emergency Stop:
        Error status: 0x04
        Error 0x04 = Output buffer starvation, I think. I'd guess that your SD card is either full or damaged. Please check your SD card by running the commands here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
        Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 1
        • Sculpt Fabricatorundefined
          Sculpt Fabricator @droftarts
          @droftarts
          The SD card was really full we deleted everything out of it. I will look into
          that more
            @sculpt-fabricator probably file fragmentation on the SD card slowing down read time, then.
            Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 0
              @droftarts
              I ran the tests from the documentation, It all seems to be fine -
              M39
              SD card in slot 0: capacity 7.95Gb, partition size 7.94Gb, free space 7.82Gb, speed 20.00MBytes/sec, cluster size 64kb```
              SD read speed for 10.0Mbyte file was 1.36Mbytes/sec
              SD write speed for 10.0Mbyte file was 2.34Mbytes/sec
              Testing SD card read speed...
              M122 P104 S10
              Testing SD card write speed...
              M22
              SD card 0 may now be removed
              M21
              SDHC card mounted in slot 0, capacity 7.95Gb
                dc42 administrators @Sculpt Fabricator
                @sculpt-fabricator some questions:
                • Do you have any M581 triggers configured?
                • Do you have a PanelDue connected? If so, does the PanelDue cable run close to any stepper motor cables?
                  Sculpt Fabricator @dc42
                  @dc42 We 3 M581, two for filament sensor and one for crash detector
                  ; Custom settings__________________________________________________
                  M950 J0 C"exp.e2stop"
                  M581 T1 P0 S0 R1
                  M591 D0 P7 C"e1stop" S1 L4.2 E10 R10:1000
                  M950 J1 C"exp.e3stop"
                  M581 T1 P1 S0 R1
                  M591 D1 P7 C"zstop" S1 L4.2 E10 R10:1000
                  ;M591 D0 P1 C"duex.e2stop" S1 ; Regular filament sensor for E0
                  ;M591 D1 P1 C"duex.e3stop" S1 ; Regular filament sensor for E1
                  M950 J2 C"duex.e4stop" ; create Input Pin 2 on Zstop for the M581 command.
                  M581 P2 T0 S0 R0 ; Crash Detector [Add-On]
                  We also have a front X motor which wires run along the same path as the PanelDue
                    Sculpt Fabricator
                    Found the problem, the Modix crash detector is a magnetic sensor and when
                    triggered it sends the same Emergency Stop that we were getting mid print. Even the one 20 min into the print. My guess is a faulty crash sensor, running
                    like normal now that it is temp. bypassed.
                    Phaedruxundefined ComedianTF2undefined 2 Replies Last reply Reply Quote 2
                      Phaedrux Moderator @Sculpt Fabricator
                      @sculpt-fabricator You may want to feed that back to Modix.
                      @ComedianTF2
                      • ComedianTF2undefined
                        ComedianTF2 @Sculpt Fabricator
                        @sculpt-fabricator Send a mail to support@modix3d.com with your information and we'll send you a replacement sensor.
                        I can also see you're running an interesting config file, we've done a fair few updates to the config/macro files, so look at the latest ones at https://github.com/Modix3D/Modix-V3-configuration-and-Macro-files/releases
