    Automatic Emergency Stop
    1.1k
      jay_s_uk @Sculpt Fabricator
      @sculpt-fabricator also, does it reset if you simulate the job?
      Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 0
        @sculpt-fabricator and have you always used global variables or have you only recently started to use them?
        • Sculpt Fabricatorundefined
          Sculpt Fabricator @jay_s_uk
          @jay_s_uk I have never run a job simulate. I don't know how to do that ?
            @sculpt-fabricator right click on the job and simulate
              @jay_s_uk
              I haven't changed any g-code or any setting in 4 months, printer was working
              perfectly sense 3.3 update and getting all the code dialed in. Machine has been
              running 24/7 for 4 weeks
                @jay_s_uk
                It made it 100% thought simulation.
                  @sculpt-fabricator not much we can do now until the reset map is looked at.
                    droftarts administrators @Sculpt Fabricator
                    @sculpt-fabricator said in Automatic Emergency Stop:
                    Error status: 0x04
                    Error 0x04 = Output buffer starvation, I think. I'd guess that your SD card is either full or damaged. Please check your SD card by running the commands here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
                    Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 1
                      Sculpt Fabricator @droftarts
                      @droftarts
                      The SD card was really full we deleted everything out of it. I will look into
                      that more
                        @sculpt-fabricator probably file fragmentation on the SD card slowing down read time, then.
                          @droftarts
                          I ran the tests from the documentation, It all seems to be fine -
                          M39
                          SD card in slot 0: capacity 7.95Gb, partition size 7.94Gb, free space 7.82Gb, speed 20.00MBytes/sec, cluster size 64kb```
                          SD read speed for 10.0Mbyte file was 1.36Mbytes/sec
                          SD write speed for 10.0Mbyte file was 2.34Mbytes/sec
                          Testing SD card read speed...
                          M122 P104 S10
                          Testing SD card write speed...
                          M22
                          SD card 0 may now be removed
                          M21
                          SDHC card mounted in slot 0, capacity 7.95Gb
                            dc42 administrators @Sculpt Fabricator
                            @sculpt-fabricator some questions:
                            • Do you have any M581 triggers configured?
                            • Do you have a PanelDue connected? If so, does the PanelDue cable run close to any stepper motor cables?
                              Sculpt Fabricator @dc42
                              @dc42 We 3 M581, two for filament sensor and one for crash detector
                              ; Custom settings__________________________________________________
                              M950 J0 C"exp.e2stop"
                              M581 T1 P0 S0 R1
                              M591 D0 P7 C"e1stop" S1 L4.2 E10 R10:1000
                              M950 J1 C"exp.e3stop"
                              M581 T1 P1 S0 R1
                              M591 D1 P7 C"zstop" S1 L4.2 E10 R10:1000
                              ;M591 D0 P1 C"duex.e2stop" S1 ; Regular filament sensor for E0
                              ;M591 D1 P1 C"duex.e3stop" S1 ; Regular filament sensor for E1
                              M950 J2 C"duex.e4stop" ; create Input Pin 2 on Zstop for the M581 command.
                              M581 P2 T0 S0 R0 ; Crash Detector [Add-On]
                              We also have a front X motor which wires run along the same path as the PanelDue
                                Sculpt Fabricator
                                Found the problem, the Modix crash detector is a magnetic sensor and when
                                triggered it sends the same Emergency Stop that we were getting mid print. Even the one 20 min into the print. My guess is a faulty crash sensor, running
                                like normal now that it is temp. bypassed.
                                Phaedruxundefined ComedianTF2undefined 2 Replies Last reply Reply Quote 2
                                  Phaedrux Moderator @Sculpt Fabricator
                                  @sculpt-fabricator You may want to feed that back to Modix.
                                  @ComedianTF2
                                  • ComedianTF2undefined
                                    ComedianTF2 @Sculpt Fabricator
                                    @sculpt-fabricator Send a mail to support@modix3d.com with your information and we'll send you a replacement sensor.
                                    I can also see you're running an interesting config file, we've done a fair few updates to the config/macro files, so look at the latest ones at https://github.com/Modix3D/Modix-V3-configuration-and-Macro-files/releases
